RIP?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by themex2002, Nov 21, 2020.
  1. Nov 22, 2020 at 4:35 AM
    #61
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Kept it and went full in on it. Didn’t notice anything different about it afterwards aside from its value went down about $10k and the rear hatch in just the right light after a wash looks a slightly different shade of white.
    Her now.
  2. Nov 22, 2020 at 5:49 AM
    #62
    themex2002
    themex2002 [OP] Active Member
    Luis
    TRD Pro
    None
    Looks amazing!!!!
  3. Nov 22, 2020 at 5:57 AM
    #63
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
  4. Nov 22, 2020 at 6:16 AM
    #64
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    CaliKat and themex2002[OP] like this.
  5. Nov 22, 2020 at 6:22 AM
    #65
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    without knowing much about your neighborhood i would keep an eye out for damaged vehicles in your area. (parked in the backyard/garage) if possible. couldnt tell if you traded any paint with the perp but i would be pissed off enough to walk around a few blocks.
  6. Nov 22, 2020 at 6:38 AM
    #66
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Its not totaled. If airbags blew it would be. Frame will be fine. Still sucks seeing that happen.
    themex2002[OP] likes this.
  7. Nov 22, 2020 at 6:48 AM
    #67
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Probably under 10k to fix if it only needs one fender. No way that's totaled.
    Hooper89 and themex2002[OP] like this.
  8. Nov 22, 2020 at 6:50 AM
    #68
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    I didn't know this - so airbag deployment is the standard whether a vehicle is totaled or not? When I was a paramedic I saw some pretty insignificant MVA's that had airbag deployment.
  9. Nov 22, 2020 at 6:57 AM
    #69
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Depends but if airbags are deployed, the cost to replace them typically exceeds the cost of the vehicle, hence totaled.
  10. Nov 22, 2020 at 6:59 AM
    #70
    VeeSix
    Tennessee, USA
    2011 Tacoma 4x4
    Fascinating. I had no idea.
  11. Nov 22, 2020 at 7:01 AM
    #71
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Try and make sure it goes to a reputable shop for repairs. Toyota certified shop? Toyota OEM parts for repair and go over it with a fine tooth comb when fixed. If you don't know what to look for take a person who you know that knows trucks and what to look for after it's repaired. The good thing is most if not all the repairs are just a matter of unbolting and bolting on new parts,no structural damage hopefully.
    Blackbeard83 and themex2002[OP] like this.
  12. Nov 22, 2020 at 7:05 AM
    #72
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A couple of thoughts.
    It is likely not totaled. The damage appears to be all sheet metal.
    Get the police report. The report should detail the information from the video.
    Get a copy of the video from the neighbor's camera.
    You may be able to identify the specific Penske truck with a plate or truck number.
    Talk to the local Penske truck rental. Have your police report in hand. You want to discover the renter of the truck.
    Get all the info you can about the renter.
    Send them a registered letter with the police report, copy of the video and ask them to submit to their insurance. I suspect the Penske truck had some damage.
    If they balk or refuse or don't reply. The next path is small claims court.
    Meanwhile, turn all this information over to your insurance. They have bigger legal muscle. They would likely pursue because they don't want to payout.
    I have a long story about events along these lines. This is a lot of dinking around, but in the end it will place the responsibility onto the correct people.
  13. Nov 22, 2020 at 7:14 AM
    #73
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If you have a video or witness statement, the police need to have that info for the report. Your insurance company will do an investigation of sorts, usually to verify the details of the police report, so that they are sure of the circumstances, weather conditions, who is at fault, etc. In the cases of a hit and run/leave the scene, they are going to try to verify that fraud did no occur. The witness statement and video will make that very clear.
    My insurance covered the value of my "aftermarket" parts (TRD wheels, bilstein 6150/6100 and associated parts) by prorating value by date from when they were purchased. Receipts necessary. They even gave me value for the tires since they were close to new. Overall, I got almost $3k added to the valuation of the truck on its own. Coverage of "aftermarket" parts is not a standard policy device, so check your policy and keep that in mind when renewing or updating yours. The added cost is usually insignificant but depending on the coverage it may have a cap to how much it will pay out on those items. Basically, know the details of your policy. This will probably be a moot point since it looks like the cost to fix will be significantly lower than the value of the vehicle, so repair is likely, but good info to know since you are paying for it every month. Also, you can often get a good idea of total loss or not by using the state insurance laws that apply and requesting the collision shop's estimate to also be sent to you when the finish and send it to your insurance. Adding 10-15% to the estimate is a good idea to cover "hidden damage", your insurance will probably do the same when crunching the final numbers.
    https://www.carinsurance.com/Articles/total-loss-thresholds.aspx
    This year alone I have had 2 total loss accidents so I have learned much about the process and the system overall. My insurance has been great, all things considered. Neither time was I at fault, and my premiums only went up according to the value if the replacement vehicle.
    It's not a standard, but it adds a huge amount of cost to the repair.
  14. Nov 22, 2020 at 7:17 AM
    #74
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I agree with others here. Without proper tools or a visual on the frame, it appears to be just body panels that need replacing and she'll be good as new.
  15. Nov 22, 2020 at 7:19 AM
    #75
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    The bad news is what if the renter of the Penske truck didn't pick up the insurance when they rented it ? Maybe that's why they fled .
  16. Nov 22, 2020 at 7:24 AM
    #76
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    This day in age, frame damage doesn’t necessarily mean total. My 5 month old 4Runner had frame damage and I took it to Toyota’s body shop. They cut it out the damaged section and welded in a new rear section of the ladder frame.
  17. Nov 22, 2020 at 7:39 AM
    #77
    Knute
    @Bleep100
    While your statement maybe true. The renter remains responsible for the damage. NOT Penske or the OP.
    Not having insurance is NOT a reason to avoid restitution for damages caused by the renter.
  18. Nov 22, 2020 at 7:44 AM
    #78
    EvergreenOffroad
    EvergreenOffroad Well-Known Member
    Jacob
    Auburn, Wa
    2018 TRD OFF-ROAD
    Yes on top of them fixing it. They never offer it they just hope people are uninformed and don’t know about it! Only can be used when you’re not at fault though.
  19. Nov 22, 2020 at 7:46 AM
    #79
    EvergreenOffroad
    Jacob
    Auburn, Wa
    2018 TRD OFF-ROAD
    I work in a body shop and we had a 4Runner come in with rear frame damage and Toyota OEM procedures said you couldn’t section it...any chance you could get me a copy of the final bill so I can check it over for you?
  20. Nov 22, 2020 at 7:46 AM
    #80
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    And in USAA’s case, of you’re the policy holder and they are paying for the repairs. I couldn’t seek diminished value through USAA since they paid under the uninsured motorist coverage.
