Ripcord's Spruce Mica Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Ripcord, Jun 1, 2018.
  1. Oct 14, 2020 at 12:33 PM
    #321
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    |September 22, 2020|
    Cowl Intake:
    I have always hated the snorkel I have. The only reason I added it was after I removed the wheel well liners the intake was exposed so I needed to route the intake to somewhere with clean air. This cowl intake accomplishes the same function, and I can remove the dingus from the side of my truck!
    Parts:
    4” to 3” 90° silicone elbow https://amzn.to/32QwHHC
    3” 30° silicone elbow https://amzn.to/3kFJxP1
    3” spectre flange (PN 8148) https://amzn.to/2IFE8tP
    3” OD steel or aluminum tube
    3”-4” hose clamps
    Tools:
    3”+ hole saw
    Drill
    screwdriver
    Time:
    1 hour
    I didn’t take very many pictures during this process, but I have made a youtube video about it which is even more useful!
    https://www.youtube.com/embed/jXeze6KzmDo
    Here is the final product:
    Due to the fact that I had a snorkel already, I needed to get a replacement fender. Had this painted by a local auto body shop. I also removed my factory antenna and covered the hole with a plug for a 79-93 mustang tail light.
    FAQ on the Cowl intake mod:
    *What are you doing for an Air Filter?
    -The factory air filter housing is unchanged, only the piping leading to it is altered.
    *Are you concerned about water getting in the intake?
    -No, I went over water intrusion in the video.
    *Is this as effective as a snorkel?
    -Yes, the primary reason I had the snorkel was to get my intake to an area with clean air. This also suits that purpose and is great for water fording depth at the same time.
    *Is there intake noise transmitted to the Cabin?
    -Yes, but it sounds pretty good IMO. Could always put a separating plate between the two intakes to lessen the noise.
    *Does this pull air from the HVAC system?
    -No, I had a concern that it would but the fan blows just fine even at WOT.
  2. Oct 14, 2020 at 12:33 PM
    #322
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    |March 21, 2020|
    C4 Fab Bumper:
    I mentioned above that I had a winch failure on the trail. The cause of the winch failure was that I did not have a large enough washer on it and the bolts just pulled through the bumper. This caused torsion to build up in the winch assembly (bad) and it basically exploded. Due to this winch failure also causing some damage to the bumper, I felt the need to replace the front bumper.
    Here is a picture of the winch…
    I picked up a newly released bumper from C4 Fabrication.
    I did do some modification to the new bumper, such as:
    -Trimming some off of the top plate, to remove the need for trimming the grille supports
    -Cutting 3” off of the wings and capping them to better line up with my trimmed fender flares
    -Drilling license plate holes
    After that, I had it powdercoated at a local shop.
    I also got some new Baja Designs lights for it, since this bumper was specifically made for them. An S8 30” Combo pattern light bar and the Squadron Wide-cornering pods.
    For the winch, I went with a Smittybilt X2O 10k synthetic winch.
    All together with the snorkel deleted
    Road Bull, Tacman19, Ngneer and 3 others like this.
  3. Oct 14, 2020 at 12:33 PM
    #323
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    |Sept 19, 2020|
    And more trips with this new front end look…
  4. Oct 14, 2020 at 6:19 PM
    #324
    AlHago
    AlHago Well-Known Member
    Alan
    Huntsville, AL
    12 DCLB MGM
    Stock as all get out.
    so are you gonna be selling that snorkel kit? I may be interested
  5. Oct 14, 2020 at 6:51 PM
    #325
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    That is all sold, sorry!
    Tacman19 likes this.
  6. Oct 21, 2020 at 2:06 AM
    #326
    caleebra
    caleebra Well-Known Member
    Arne
    Norway
    2010 Hilux D-Cab
    2" OME, 33" Tyre, DIY Canopy, RTT
    Catch'd up on your thread, I follow you on both IG and Flickr, as well as Youtube, but reading through the thread and viewing the photos in a larger format makes it so much better!
    Props to you Jim! The build looks stunning as always!
    Ngneer likes this.
  7. Oct 28, 2020 at 9:45 AM
    #327
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Thanks Arne!
    I appreciate the compliments!
    caleebra likes this.
  8. Nov 2, 2020 at 12:02 PM
    #328
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    You have very pretty nails! :rofl:
    Awesome job with that snorkel delete. Getting pretty much all of the benefits without an irreversible hole in the fender sounds like a no brainer. I think that's going to be my next mod after I fix the door dig from my last trip. :rolleyes:
    Tacman19 and Ripcord[OP] like this.
  9. Nov 3, 2020 at 10:39 AM
    #329
    T1gger
    T1gger Active Member
    Tyler
    Coeur d’Alene, ID
    2008 4x4 DCLB Tacoma
    Front suspension: -Fox 2.5 extended coil overs with 650lb, 14” springs -Tuff country upper control arms (will replace soon) Rear suspension: Fox 2.5 struts with Old man Emu heavy duty leaf springs Engine: K&N CAI Intake Tires: -Fuel XD800 Misfit rims wrapped in BFG KO2 Exterior: -Smittybuilt front and rear bumpers -Smittybilt X2O 10K Waterproof Synthetic Rope 10000lb Wireless Winch -Soft tonneau cover -30” in grill LED light bar
    Absolute favorite build! Inspiring me to build mine more like yours everyday!
    Ripcord[OP] likes this.
  10. Nov 19, 2020 at 7:52 PM
    #330
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    Impressive build! I am glad to have met you at ROCKtober Therapy and seen the Tacoma in person. Great job on the DIY Wedge Camper youtube video.
  11. Dec 16, 2020 at 11:24 AM
    #331
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    Love the build sir! Am looking at doing the exact same thing to my c4 bumper when it comes in in March. A couple questions:
    1) The image of the raw steel bumper shows where you trimmed the top plate, correct?
    2) I am a local CO guy (Littleton) and was wondering what powder coating shop you used and about what they charged you? My bumper won't be in for a while so I'm trying to gather as many quotes as possible.
    Thanks in advance and keep up the great work!
    PS: I also took a page out of your book and did the center console ram mount + wireless charger. I'm loving it!
  12. Jan 15, 2021 at 12:34 PM
    #332
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    Any issues long term with the 600lb springs and the bumper, winch, and added weight?
  13. Jan 15, 2021 at 2:29 PM
    #333
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Nope! They work well for how low I keep the truck (the cut fenders are deceiving, its like 1-1.5" of lift in reality)
    jeremy5000 likes this.
  14. Jan 31, 2021 at 10:57 PM
    #334
    BluebberyBrota
    BluebberyBrota Member
    All the things
    How has the intake relocation mod been working out? Any updates?
  15. Feb 1, 2021 at 7:13 AM
    #335
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    It is working great! The only downside if I have noticed is that it occupies the space normally used for 2nd batteries. But functionally it is what I hoped it would be.
    Ngneer likes this.
  16. Feb 1, 2021 at 11:05 AM
    #336
    vmadams
    vmadams Member
    2013 TX Pro
    Fab Four front and rear bumpers, XRC Wench, Yakima Roof Rack 2inch lift blocks
    Love the build man!
    What video camera setup do you use?
  17. Feb 1, 2021 at 11:37 AM
    #337
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Just saw this post sorry!
    Yes, those lines I drew in sharpie is where I cut. I test fit it before cutting to see where it would interfere with the grille support piece then cut that area away.
    I had it coated at a shop near my work for $225 I think it was (that included the brackets that come with it). Prices should be pretty standard anywhere you go.
    Thanks! I have a canon R.
  18. Feb 1, 2021 at 1:41 PM
    #338
    BluebberyBrota
    All the things
    Parts ordered! Thanks for the inspiration.
  19. Apr 2, 2021 at 5:48 PM
    #339
    Ngneer
    Ngneer Well-Known Member
    Totally agree and then some,awesome truck
  20. Sep 15, 2021 at 6:55 PM
    #340
    Ngneer
    Would have to agree, look at the sidewall action from a picture above, that’s a good seller to me.
