Ripcord's Spruce Mica Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Ripcord, Jun 1, 2018.
  1. Oct 7, 2018 at 8:43 PM
    #101
    eon_blue
    Azusa, CA
    Nice, I was out that way recently a couple months ago doing Coyote Flats, one of my favorite camping/off roading areas in CA. I'll have to check that trail out next time.
  2. Oct 8, 2018 at 11:36 AM
    #102
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    Went on some fall colors trips recently.
    First one with the BroCo group on the Halfmoon gulch trail.
    My friend Drew's 1st gen 4Runner
    Alex's 3rd gen 4Runner
    Will's 4Runner
    And another trip, just some camping near Leadville, CO.
    Me showing me face.
    My girl
  3. Oct 8, 2018 at 11:41 AM
    #103
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    I never did coyote flats, that was next on my list before I ended up moving.
    The best part of the wheeler crest trail, other than the great crawling on the trail, is the lake you can camp at if you continue up the sand canyon trail beyond the entrance to wheeler crest.
    eon_blue[QUOTED] likes this.
  4. Oct 8, 2018 at 11:41 AM
    #104
    ChadsPride
    Sponsored by TacomaWorld.com
    Gorgeous truck!
    Ripcord[OP] likes this.
  5. Oct 8, 2018 at 11:44 AM
    #105
    ctmedic
    ctmedic Well-Known Member
    2018 TRD OR DCSB
    Wow! That's one sexy 2nd gen.
    Ripcord[OP] and ChadsPride like this.
  6. Oct 8, 2018 at 11:51 AM
    #106
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    DAMN I wish I could've got Spruce Mica when I bought my truck. Nice rig buddy.
  7. Oct 8, 2018 at 11:54 AM
    #107
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Thanks everyone!
    ChadsPride likes this.
  8. Oct 23, 2018 at 3:40 PM
    #108
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    |October 18, 2018|
    A few changes recently
    Bolted Fender Flares:
    First, I had to change how I was mounting my fender flares. The plastic clips just weren’t going to cut it. I had one flare come off completely on the highway (recovered it) and another that nearly did the same. The only method I could think to solve this was to replace the plastic clips with through bolts, so that’s what I did.
    Parts / Retail Cost:
    $25 - 1” diameter Neoprene Foam cord (McMaster Carr: 1298N9)
    $15 - 1/4" or 5/16” flat head bolts & nuts. 1.25" length [Get Stainless steel, trust me]
    Tools:
    -Drill
    -5/16” drill bit
    -Countersink drill bit
    -Hacksaw
    -½” wrench
    Time:
    -Took me like 2 hours
    Parts listed above:
    Go ahead and break off any remaining plastic clips you have. Mark where the center of each clip was.
    Drill a 5/16” hole where you marked the center of each clip to be.
    Countersink them bitches.
    Cut the foam into small ½” pucks, then drill out the center with the 5/16” drill bit (not pictured)
    Start assembling
    Result:
    [​IMG]IMG_0528 by Phoenix Black, on Flickr
    Next, I got some new tires. Went with Cooper STT Pro, same size at 315/70/17. I have a few friends that run these and love them, especially in Colorado’s deep snow which is something I want to try more of. Similar to the duratracs I had before, these tires a fairly lightweight at only 67 lbs per tire.
    Since getting them, I have tested them on the highway for many hours and a weekend in Moab, I can say that I am very impressed with these tires. They have amazing grip on rocks, just gotta try them in snow now.
    Fleece mattress cover:
    As the temps get colder, a downside of the roof top tents becomes more apparent. They are cold, especially the cold plastic cover on the mattress. I usually sleep just with blankets instead of a sleeping bag and I would have to have just as many under me as on top of me because that cover was so cold. Also it was very slippery.
    To remedy this, I decided to make a fleece cover for it!
    $20 - 2 yd x 3 yd fleece
    $15 - Quilting pad material
    Tools:
    -Sewing machine (and some who knows how to use one, lol)
    Time:
    -This was a slow process, about 5 hours while watching TV.
    Here is the sheet laid out with the mattress for scale.
    Sewed the padding to the fleece.
    After that step, I sewed the fleece/padding combo to the plastic cover itself.
    The finished Product! It is amazing, so soft and warm. Also I never slide around anymore like I did on the plastic cover. Highly recommended to all RTT owners.
    Rubber leaf spring bushings:
    The polyurethane bushings I have had in the leaf springs are doing what polyurethane does… squeak like a MOFO.
    Most aftermarket leaf spring bushing ends are the same size as the OEM leaf springs, including the Energy brand poly bushings that press into them. What that means is you can use the OEM rubber leaf spring bushings instead of the polyurethane bushings!
    $48 - 8x OEM leaf spring bushings (90389-A0003)
    Tools:
    -Jack, stands, etc…
    -a BFH or a press if you take the springs all the way out.
    Time:
    Took me less than 2 hours to swap both sides.
    OEM rubber vs. the Polyurethane bushings
    Natural Rubber > Polyurethane
    Poly bushings out
    Rubber in
  9. Oct 23, 2018 at 4:27 PM
    #109
    ChadsPride
    Solid! Looks awesome!​
  10. Oct 24, 2018 at 7:24 AM
    #110
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Went to Moab last weekend. Met up with my usual guys plus a friend from California who was on his was back from picking up his GFC camper.
    Did 2 trails, Gold Bar Rim and Hell’s Revenge.
    [​IMG]_DSC2149 by Will Oliver, on Flickr
    On Hell’s, I finally did Hell’s Gate. I have been there with both of my 4Runners also but this was the first time I was willing to give this obstacle a shot.
    Also did the Golden Crack, walked right across.
    Had to winch this open-open 4runner out of the crack.
    [​IMG]_DSC1835 by Will Oliver, on Flickr
    One of our group was an 80 series on 40s with a 3-link front. Needless to say nothing really slowed him down.
    On Gold Bar Rim, there is also an obstacle called the Waterfall.
    We had to go both directions on this one, going down was scary enough but going up at night was a whole other ball game. Of our group of 10, only 3 trucks made it up without winching, I was one of them :D .
    This is a video, FYI.
    [​IMG]FLEM9418 by alex fleming, on Flickr
    Adam and his 5th gen Cavalry Blue
    Will
    Noah approaching the waterfall also.
    Alex, finishing the last 2 hours of the trail in the dark was really fun.
    My friend Jason who just got his GFC.
    Maxcustody, RTX Taco, NateMob and 4 others like this.
  11. Oct 25, 2018 at 12:04 AM
    #111
    Carl_z33
    Carl_z33 Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    Very creative on the bolted fender flares. I have been using zip ties on my Trimmed flares and haven’t had any issues besides them flopping on the freeway & that irks me. Might have to try your method of bolting them.
    Ripcord[QUOTED][OP] likes this.
  12. Oct 25, 2018 at 8:36 AM
    #112
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Thanks! The exposed bolt head look is still growing on me, might look into painting them.
    NateMob, Carl_z33 and ChadsPride like this.
  13. Oct 25, 2018 at 7:47 PM
    #113
    The_Black_Pearl
    The_Black_Pearl IG: the_black_pearl_tacoma
    Colorado Springs, CO
    2013 All Black Tacoma Double Cab Long Bed
    Can you upload photos of the flares and how the line up with the front and rear he bumper?
  14. Oct 26, 2018 at 7:31 AM
    #114
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    This is the best shot I have of that currently, from before the bolts but that doesn't really change anything in this aspect.
    The_Black_Pearl and ChadsPride like this.
  15. Oct 26, 2018 at 9:25 AM
    #115
    The_Black_Pearl
    When you get a chance could you take side shots closer to show the fenders aligning with the bumpers? Or I might just need to look at this rig in person!! Haha
  16. Oct 26, 2018 at 9:35 AM
    #116
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Try this one on for size. Keep in mind I did trim the rear bumper back to match the rear flare line (link to post is on page 1).
    ChadsPride and The_Black_Pearl like this.
  17. Oct 26, 2018 at 9:55 AM
    #117
    The_Black_Pearl
    Thanks!
  18. Oct 26, 2018 at 10:03 AM
    #118
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Man, without question Spruce Mica was the best color Toyota ever produced the Tacoma in. Awesome truck, sir.
  19. Oct 26, 2018 at 10:06 AM
    #119
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Thanks, I could not agree with you more!
  20. Oct 28, 2018 at 8:17 PM
    #120
    The_Black_Pearl
    How much of the fender sheet metal did you cut and how much flare?
