Riping cv boot 8in lift need input
Discussion in '1st Gen. Tacomas (1995-2004)' started by 808army, Sep 15, 2013.
  1. Sep 15, 2013 at 12:27 AM
    808army
    808army [OP] Active Member
    Posting for friend. Truck lifted 6fabtech wit 2inch spacer so it stacked. He riping cv boot. Asking for input fix it he willing pull off 2 inch spacer so the front axle dose not have angle. Lookig input if there way we dont have pull off the spacer. Thanks guys
  2. Sep 15, 2013 at 12:36 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
  3. Sep 15, 2013 at 1:24 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's a reason serious offroad trucks don't have IFS with a bolt-on lift.
    Your friend has found out why.
  4. Sep 15, 2013 at 2:21 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Cut the small end of the boot loose from its clamp and just use zip ties lightly tugged down to keep the small end closed somewhat on the shaft. You want it to slip on the shaft and not be anchored. At that angle he's gonna go thru stock axles anyways because it is outside of the design parameters, so not a big loss.
  5. Sep 15, 2013 at 2:25 AM
    Coastie80
    Coastie80 Well-Known Member
    Kevin
    Charleston, SC
    '13 TRD Sport DCSB Super White
    I must admit, I like straight axles better, just because of the simplicity, ease and strength, but you should probably look at a lot of the rigs that compete in the King of the Hammers and re-think that statement.
  6. Sep 15, 2013 at 2:32 AM
    Mod
    CR, WA
    stock
  7. Sep 15, 2013 at 2:57 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    pull out spacers, get a 2" body lift:cool:
  8. Sep 15, 2013 at 4:44 AM
    bigtaco06
    bigtaco06 Well-Known Member
    Jared
    Nor-Cal
    13 TRD OR DBCB SB
    Floor mats, shorty antenna, brute force hybrid front bumper, ICON stage 3, method double standards, 285/75/16 KM2's, cool stickers
    Built vs. Fabtech = invalid comeback. I don't think anyone in the King of the Hammers is running a Fabtech drop bracket.
    For the Op tell him to take that spacer out sorry but problem solved.
  9. Sep 15, 2013 at 2:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bingo.
    The H1 Alpha has 4-wheel IS and does quite well, but the half-shafts do not enter the center of the spindle.
  10. Sep 15, 2013 at 2:28 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    get some empi boots or if you need they sell axles and boots all assembled and won't ever have a problem again Toyotas boots are crap!!
  11. Sep 15, 2013 at 3:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    With a 6" Fabtec and 2" spacers, he's still going to be replacing boots and CVs every year or two.
  12. Sep 16, 2013 at 1:01 AM
    Mr. Biscuits
    Mr. Biscuits gentleman, scholar, part-time delinquent
    Brennen J
    Bakersfield
    2000 PreRunner TRD V6
    -Bilstein 5100/ Eibach 3" lift -Custom 2" lift rear leaf pack -Crystal clear headlight housings -updated (01-04) rear tail lights -custom front tube bumper -custom rear tube bumper -Deckplate mod -Aero Turbine 2525 exhaust -Kenwood Headunit -Pioneer Speakers -black door handles -Debadged, rebadged black -Ultraguage
    8" of lift?? On 4WD nonetheless. Was that really necessary? As if the 6" DB want enough.
    Well like Rich said IFS isn't supposed to go that high. If he wants to stop blowing boots and keep the full 8" he'll need a body lift which normally I wouldn't suggest but seeing as how it's not much of an off road rig anyway, it might just be up his alley
  13. Sep 16, 2013 at 8:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Original comment clarified ;)
