RIPP HIGH PERFORMANCE COIL PACKS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brostjoe, May 13, 2020.
  1. Jul 6, 2020 at 6:12 AM
    #41
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Yeah, @2dogs_and_a_taco went full rocket scientist terminology on us with that one ;)
  2. Jul 6, 2020 at 6:22 AM
    #42
    2dogs_and_a_taco
    2dogs_and_a_taco Well-Known Member
    Nick
    2020 Army Green Taco
    Yeah, throttle body spacer but I love that the swirling shape helps improve combustion. I mean the air has to travel through a bunch of intake runners in the upper intake, down the lower intake into the cylinder head then into the cylinder where it can be mixed with high-pressure fuel.. but I'm sure the air remembers that cool swirl it took. :D
    TB spacers are okay for nitrous injection or a location for a boost port if you need one.
    The truth is engines are giant air pumps. So you move air through the engine with fewer restrictions if possible and add fuel to match or you force air into the engine with turbo, supercharger, nitrous, etc. Most of these fancy air intakes, exhaust systems, other gimmicks are BS for power gains.
    Tunes can sometimes make a big difference. My C63 picked up 80HP/65lb Ft from just a computer flash but that's a weird deal. Mercedes doesn't like building a million engines so they share the same engine in many high-performance cars but detune the cheaper models. Now if I could just pull the big 6.3L V8 out of that thing and shoehorn it into the taco. That would be a SEMA truck for sure. 550HP naturally-aspirated taco anyone? :bikewheelie2:
    Quicksander17 and Myles G like this.
  3. Jul 6, 2020 at 6:25 AM
    #43
    2dogs_and_a_taco
    Nick
    LOL.. pre-coffee.
    wahoobie[QUOTED] likes this.
  4. Jul 21, 2020 at 5:48 PM
    #44
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Exactly, this is more inline with the overall effect of aftermarket coils. Power increase is simply a result of a "performance" coils (whatever that means) ability to maintain a constant voltage under load. Stock coil packs are perfectly fine for the job, however there has been lots of testing (not so much in the Toyota truck sector) about stock coils dropping off voltage in higher RPM ranges which coincidentally is where Tacomas make peak power. Tacomawold member hiPSI did a great read on performance which can be found HERE. In the end my .02 for whatever its worth is to think of these new to market Ripp Coil Packs not as a power adder but a pack that has the ability to remain more consistent through the power band which as a BONUS frees up a few ponies!
    I won't be buying a set for myself but everyone has been quick to attack these on the internet and I do believe if you understand more about electronic ignition there are some benefits. Whether or not you want to spend the $300+ is your choice in the end. Good read...
    https://www.rodauthority.com/tech-s...-misconceptions-about-ignition-coil-upgrades/
    http://kennebell.net/products/accessories/boost-a-spark/ Graph for a nice visual representation of voltage drop.
    CanadaToy likes this.
  5. Jul 22, 2020 at 7:17 AM
    #45
    mjanmohammad
    mjanmohammad Well-Known Member
    Moe
    I meant electronics efficiency in the truck, which has no effect on peak HP.
    The rev ranges where stock coils start dropping efficiency is well above the redline and fuel cutoff for the engines in the truck. I can pull one of the coil packs off the truck to test, but I'd guess they maintain acceptable voltage and spark until at least 10k rpm.
    Coil pack upgrades that claim to increase performance on an otherwise stock engine are snake oil and bullshit. Don't waste your money on this crap.
    Quicksander17 and TS4x4 like this.
  6. Jul 31, 2020 at 4:10 PM
    #46
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    Pulled out $300 bucks from my wallet...
    Dropped it into my turbo/supercharger jar...
  7. Feb 14, 2021 at 8:59 PM
    #47
    TRDnube
    TRDnube New Member
    3rd GEN Tacoma
    The faster that the gasoline is burned the more power extracted from the gasoline. A stronger or “better spark” will cause the gasoline to burn faster.
  8. Feb 14, 2021 at 9:05 PM
    #48
    mjanmohammad
    Moe
    Incorrect. The speed at which gasoline burns has nothing to do with creating more power in an engine. A better spark won’t cause the gasoline to burn faster anyways.
    Unless you’ve heavily modified your engine to run at higher RPM, like 10,000r or greater, you will not notice any benefit from performance coil packs.
    I explained it in an earlier post, but there is absolutely no reason to waste money on coil packs claiming to increase performance
  9. Feb 14, 2021 at 10:12 PM
    #49
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    RIPP OFF!
    Quicksander17, H6G, Skydvrr and 2 others like this.
  10. Feb 14, 2021 at 10:31 PM
    #50
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    RIPPED my pants, now my ass is hanging out
    shakerhood[QUOTED] likes this.
  11. Feb 15, 2021 at 9:13 AM
    #51
    OVTune
    OVTune Well-Known Member
    OVTune
    This is incorrect.
    Power is extracted from when the gasoline is burned. (Timing)
    Quicksander17, Auzea and hiPSI like this.
  12. Feb 16, 2021 at 7:32 AM
    #52
    Jim0thy
    Jim0thy Well-Known Member
    2020 Tacoma TRD offroad
    stock
    Can only run 91 octane with these, with placebo performance gains... noice
  13. Feb 16, 2021 at 7:47 AM
    #53
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    In the video, this guy refers to these trucks as ‘Fourth Gen’ (1:34)... Priceless!
  14. Feb 16, 2021 at 7:54 AM
    #54
    Jim0thy
    stock
    Imagine being the tacoma owner that lights money on fire for these, installs them, and blows even more money on 91 octante. All for nothing :duh:
  15. Feb 24, 2021 at 11:16 AM
    #55
    New4x4
    New4x4 Well-Known Member
    AZ
    2017 Tacoma 4x4 TRD Off Road DCSB
    All-Pro Sliders Dirty Deeds Industries Exhaust
    OK OK I will be the guinea pig. If everyone sends me a few bucks each to buy these I will try them out for you. But I will not go and put 91 in the tank.
    :threadjacked:
  16. Feb 24, 2021 at 2:11 PM
    #56
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Maybe someone could remote mount these and run some Nology Hotwires off them to the plugs. That should get at least another 50hp to the wheels.
    Skydvrr and Jim0thy like this.
  17. Jul 27, 2021 at 2:01 PM
    #57
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    So Has anyone actually tried these coils?
  18. Jul 27, 2021 at 3:06 PM
    #58
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    *Sigh* I'll be that guy. Yes, I have the Ripp coil packs, right off the bat I'll say It's not worth it. Whenever you do anything to your vehicle such as CAI, TB spacer, whatever, you automatically have a placebo effect and think it made a difference. Hence the Ripp coil packs, at first I noticed how much more responsive it was. Didn't really notice a "power gain", and over a short amount of time I was saying to myself, "it feels like the same old truck. The truck runs fine today, probably have over 20,000 mi on those coil packs and I do have the OV Tune. If your wallet and heart still want to try the coil packs I say go for it. Your experiences may differ from mine. Everyones tacoma seems to respond differently to different mods when it comes to lift, brand, electronics, engine mod, etc.
  19. Jul 28, 2021 at 3:17 AM
    #59
    TacoRob08
    Rob
    17 Sport DCLB
    Thanks for the honest and not sarcastic reply. Refreshing
    ClassyTacos, DanishTaco and Skydvrr like this.
  20. Jul 28, 2021 at 8:31 AM
    #60
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I've been running these for over a year and they work great.
    SFcoma likes this.
