RIPP HIGH PERFORMANCE COIL PACKS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brostjoe, May 13, 2020.
  1. Apr 22, 2023 at 5:39 AM
    #101
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    At some point I think we have all fell for a Snake oil product. Or something that wasn't intended for a stock car.
    Malvolio, SoCaltaco65 and Scotfree like this.
  2. Apr 22, 2023 at 6:20 AM
    #102
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Smiles per gallon goes a long way when it comes to comforting the soul, even if it’s useless. I will keep digging on the inter webs for the 2.7 since there isn’t a tune for that yet. I’m shooting for fuel efficiency, the 5000 lb turtle isn’t exactly a rocket.
    ndoldman59 likes this.
  3. Apr 22, 2023 at 10:38 AM
    #103
    ndoldman59
    Murray
    West Fargo, ND
    It's interesting the 2.7 is solid but I wouldn't want it. I'm for the bigger engine just in case I need the power for towing and hauling in this area we have stupid winds and I had to drop to 4th and 3500 rpms just to maintain 70 in high wind conditions with out all the shifting bs.
  4. Apr 22, 2023 at 11:48 AM
    #104
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm still running my ripp performance coils and they work great
    Steves104x4 likes this.
  5. Apr 22, 2023 at 7:45 PM
    #105
    Scotfree
    2021 sr 4x4 2.7
    Mpg gains?
  6. Apr 22, 2023 at 10:46 PM
    #106
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    none. If someone says they gained MPG. They’re lying.
    TS4x4, jmneill and Scotfree[QUOTED] like this.
  7. Sep 7, 2023 at 3:05 PM
    #107
    Whitelife
    Whitelife Member
    2000 Tacoma TRD 4x4 5spd
    Nothing yet
    Issues I have had in the past with higher voltage spark was with MSDal and it fried my ECM different vehicle, so to much spark can be bad for PCM computer brains of vehicles, sure in the other vehicle I felt a difference but was not worth it
  8. Dec 8, 2023 at 7:37 PM
    #108
    Sixgun
    Sixgun Well-Known Member
    Mobile, Alabama
    2024 DCSB TRD OR
    Bought a truck second hand that had these. Just had one fail. Back to OEM.
  9. Feb 19, 2024 at 5:29 AM
    #109
    shotgunbilly420
    100k + mi on mine and still going strong
  10. Feb 29, 2024 at 5:41 PM
    #110
    shotgunbilly420
    Hay guys wanted to throw a update out there on this product.
    So when I installed these coils on my truck I was at 108k miles ok. Just recently like a week ago I had three ripp performance coils die on me . I was at 229k miles. Now I made sure to hold on to my OEM coils just in case . I threw the oem coils back into my truck and after about 4 tanks of 92 octane, I have lost 3 to 4 mpg. At first I thought well I did reset my lv on the ECU and transmission and reflashed my tune. Well after 4 tanks of fuel truck seems to run fine , but I barely see 6th gear anymore and loss of mpgs seemed very drastic. Understand my truck weighs 5400 lbs with 315/75/16s and stock gearing . I can get 19+ mpgs all day long with the ripp coils and hold 6th gear . Fml
    I'm currently in contact with ripps technical support and waiting to hear back from them. I hope that they might swing me a deal if not I'll buy again. Can't stand the drivability I was so accustomed to be a loss. So far the best mpg I can get right now is like 16.5ish which blows all to hell . Make me kinda hate my truck right now .
    Disgruntled Scientist likes this.
  11. Mar 1, 2024 at 2:51 PM
    #111
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    Interesting have to research this more.
    shotgunbilly420 likes this.
  12. Jun 26, 2024 at 1:11 AM
    #112
    dougluvgold
    dougluvgold Member
    Douglas
    2023 tacoma SR5 dbl cab off road /OTT tune mild spicy stock height. Barselona red
    OTT TUNE med spicy , k&n air filter
    I've got an ott tune installed ripp coils and E3 spark plugs that's talked up on ads . We'll the E3 I think are crap I never checked plug gap but you really can't it's a cage around the spark point basically, I coukd feel the missfires and stutter. So pit original factory plugs that has 9 k milesnon theme and with ripp coils, ran smooth well smoother but I had new plugs of denso iridium but didn't match part number yet Amazon said they fit 2023 tacoma 3.5 L . Put those in today no lithium grease just dry with ripp coils and plugged in an obd2 reader a cheap one
    But checked out the misfire and wow in less than 10 minutes of driving I had 60 misfires . Nit code misfire just the mainstream view . . Performance I coukd tell was lagging . I sat on drive way in park slowly reved till 2k rpm and held it there
    It humming along I would check total miss fire go back and recheck to update over and over and went from 0 to 60 misfires in 20 seconds did it again quickly it would change and had 300 in less than a minute . It never felt like any misses setting still holding it. Maybe a Suttle bit but nothing significant. So I gonna do more tests but I think they do help on instant need but ecu and all wants to change too much and results are different literally every time you start new trip . Even during one trip . Idk if the tune coukd be tweaked to account for things maybe go up a level to medium spicy .
    TS4x4 likes this.
  13. Jul 26, 2024 at 5:19 PM
    #113
    cowtown-customs
    cowtown-customs Member
    2020 TRD Sport DCLB
    I'm going to finish reading the rest of the thread, but I had to laugh at this. C'mon man, it's one thing to ask questions, it's another to make a whole bunch of assumptions.
  14. Jul 26, 2024 at 5:26 PM
    #114
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    your quote was posted: May 14, 2020 at 6:00 AM
  15. Jul 27, 2024 at 7:30 AM
    #115
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Cut him some slack. Time moves differently in Cowtown.
    stoney1911 and cowtown-customs like this.
  16. Jul 27, 2024 at 8:16 AM
    #116
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Will this get me better mileage than my FuelShark?
    TS4x4, Speedfreak and Malvolio like this.
  17. Jul 29, 2024 at 2:59 PM
    #117
    cowtown-customs
    2020 TRD Sport DCLB
    You got that right, pardner. I reckon ain't nothing wrong with a lil slack.
    Malvolio[QUOTED] likes this.
  18. Nov 20, 2024 at 9:54 PM
    #118
    Quicksander17
    Quicksander17 Well-Known Member
    Austin
    2017 Tacoma TRD Off-Road 4x4 Quicksand
    METAL: RRW Rock Sliders - https://www.relationsracewheels.com/collections/rock-sliders Body Armor Low Profile Steel Winch Bumper Body Armor Rear Steel Bumper DiamondBack Heavy Duty Aluminum Tonneau Ridge Runner Bed Rack System DV8 Low Profile Aluminum Roof Rack TRD Aluminum Skid Plate CBI Gas Tank Skid Plate PERFORMANCE: K&N Cold Air Intake K&N Throttle Controller Front Camera Emblem Mount and Backup Cam Controller LED Headlight Bulbs Pop n Lock Power Tailgate Lock Rear LED Tailgate Strip Reverse Backup LED Bulbs Sport Wing Door Ding Guards https://www.sportwing.com/FE-TACDC-Toyota-Tacoma-Double-Cab-Painted-Body-Side-Molding
    Exactly. I'd be ashamed to post that I actually blew money on all of those things on my truck. Instead of saying you have, "plenty of power" after dropping over $1,000 on nothing that helps power except the tune (legit) on a better sounding exhaust with maybe 5-12HP gains is a joke.. Coil Packs and Throttle Body Spacers don't "make power". Period. Thank you for making me and all the others on here laugh though. :rofl: That was a good one.
    TS4x4 and stoney1911 like this.
  19. Nov 21, 2024 at 8:14 AM
    #119
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiefornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Industries Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. Body Armor Sliders. Icon Stage 4 Lift. Eibach 1" Lift Blocks. Overland Taylor Tune. Rough Country Spare Tire Bed Mount. 67 Designs stuff on the dash. Uniden Radar Detector Hardwired. Spod Lighting Controls. RC Black Series Bumper Lamps RC Black Series Grill Lamp. Body Armor Stealth Front Bumper. Extended Brake Lines. Greddy Shift Knob. More to come of course.
    Stickers add more power than colorful coil packs. I fell down this rabbit hole with my STI back in the day. I am sure they work fine but, I literally had my car dyno tuned before and after the fancy coil pack install and saw zero gains. If I was showing my truck, I'd put the fancy coil packs on for eye candy.
    Speedfreak, Chew and TS4x4 like this.
  20. Nov 21, 2024 at 8:56 AM
    #120
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    :der:
    For the love of Kiichiro Toyoda stop buying these things and resurrecting this thread. A quick search of the forum for "RIPP" reveals hundreds of pages with people throwing codes and having total ignition failure.
    They are junk snake oil plain and simple. Anyone who claims drastic improvements in MPG or HP is a liar or a dunce. Show me an independent dyno (not done by RIPP) that proves it.
    drizzoh, Speedfreak, Malvolio and 2 others like this.
