ripped cv boot?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by captn.fat.beard, Jun 28, 2017.
  1. Jun 28, 2017 at 10:19 AM
    captn.fat.beard
    captn.fat.beard [OP] Well-Known Member
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    just had the cab mount chop done on my truck on the 12th. today I noticed this. grease all over everything on the driver side. i actually put on a latex glove and felt the boot, but i didnt feel anything that felt like a tear, but I know even a small pinhole could cause some grease to spill. Should I finger the shop, or sometimes this just happens?20170628_124927.jpg 20170628_124936.jpg 20170628_124939.jpg
  2. Jun 28, 2017 at 11:13 AM
    loco usmc
    loco usmc Well-Known Member
    Gabriel
    Houston
    2014 4X4 DCSB trd offroad
    this is common on lifted Tacos. Looks like all of it went on the brake lines though. Did you get some in your wheel well?
  3. Jun 28, 2017 at 11:14 AM
    captn.fat.beard
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    so if i replace the boot, or entire axle, how do i prevent this.
  4. Jun 28, 2017 at 11:16 AM
    eon_blue
    Azusa, CA
    Diff drop will help lower the angles a bit, I've also heard you can slide the boot a little further down the axle to create more space between the fins to prevent them from rubbing.
  5. Jun 28, 2017 at 11:16 AM
    Muddinfun
    Muddinfun Well-Known Member
    I wonder if a welding dingleberry melted a hole in it.
    VA SOFTACO likes this.
  6. Jun 28, 2017 at 11:19 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    diff drop only helps on 1st gens. You can buy a reboot kit at Toyota if you are mechanically inclined. otherwise you can get a whole new axle. Try use OEM and not some cheap aftermarket one.
    Mully likes this.
  7. Jun 28, 2017 at 11:19 AM
    loco usmc
    Gabriel
    Houston
    I've been driving around with a boot torn for years now. I off road a lot and still going strong.
    Mully likes this.
  8. Jun 28, 2017 at 11:21 AM
    captn.fat.beard
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    did it piss grease all over?
  9. Jun 28, 2017 at 11:21 AM
    captn.fat.beard
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    allegedly the diff drop was done when they put the suspension in
  10. Jun 28, 2017 at 11:24 AM
    loco usmc
    Gabriel
    Houston
    yup. cleaned it up a bit. like i said, still driving it and with no issues for years now. and ive taken it off road several times. and not just through dirt roads, crawling and what not. i have spares in my bed. when they fail, that's when i will change them.
  11. Jun 28, 2017 at 12:37 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    There are a couple threads and YouTube videos on double booting. Keep collar from current boot and put new boot over.
    Also @SDHQ OFFROAD sells regular and long travel cv boots. Good stuff!!!
    Mademan925 likes this.
  12. Jun 28, 2017 at 12:40 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
  13. Jun 28, 2017 at 12:47 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The shop probably got splatter on the cv boot and it made a hole
  14. Jun 28, 2017 at 1:32 PM
    renval
    renval Well-Known Member
    Renz
    SoCal
    I've noticed that one of my CV boots has a little cut but no grease is coming out "yet", i know i'm gonna be changing it very soon, but i don't want to change the entire axle, i have seen split cv boots that comes with the special glue, do you guys know where i can get them from?
  15. Jun 28, 2017 at 1:33 PM
    Radarninja
    Northern California
    06 taco
    Don't glue em. Buy the kit I listed above from eBay or Amazon. Make sure it comes with the inner and outer boot. Around $50.
    Aftermarket axles suck imo
  16. Jun 28, 2017 at 1:39 PM
    renval
    Renz
    SoCal
    Don't you have to remove the axle to install this cv boots, with the split CVs you only have to glue them together.
  17. Jun 28, 2017 at 1:41 PM
    Radarninja
    Northern California
    06 taco
    Yes you have to remove axle. For that kit. It's the correct way and will last the longest. I've done it twice. There are write ups and youtube to help. Good luck with whichever way you go
    renval likes this.
  18. Jun 29, 2017 at 4:25 AM
    captn.fat.beard
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    i went to the do it yourselfer carwash last night and powerwashed it. still couldn't find a hole or tear. just got to work and inspected. no grease. still probably going to replace the boots at least when i do front rotors and pads in the coming weeks.
  19. Jun 29, 2017 at 7:58 AM
    renval
    Renz
    SoCal
    For the work/money involved in this task, why not replace the entire axle? that's what i'm going to do when the time comes.
