Ripped UCA ball joint cover
Discussion in 'Suspension' started by sdheda, Aug 22, 2010.
  1. Aug 22, 2010 at 10:06 AM
    sdheda
    sdheda [OP] Well-Known Member
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    I bought a set of used LR UCA from a fellow member here, and the ball joint cover is ripped.
    Is it okay if I install it, or would I need to get a new ball joint?
  2. Aug 22, 2010 at 10:16 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Is it installed or are you going to install it?
  3. Aug 22, 2010 at 10:17 AM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    It hasn't been installed yet. A fellow member was going to help me install it today, and when I was getting my stuff ready I noticed that it was ripped.
  4. Aug 22, 2010 at 10:18 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    SUbbed, I just saw both my stockers are ripped :(
  5. Aug 22, 2010 at 10:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The boot holds in the grease. If/When it leaks out, the ball joint will wear out.
  6. Aug 22, 2010 at 10:20 AM
    tacomakid96
    Phil
    Out n' about
    Get a new boot, because its already ripped so it will rip more.
  7. Aug 22, 2010 at 10:22 AM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    Would i need to order the boot from Light Racing, or is it something I can find at a local parts store like Autozone or Kragen.
  8. Aug 22, 2010 at 10:24 AM
    tacomakid96
    Phil
    Out n' about
    autozone has them, I got mine for $3 per boot.
  9. Aug 22, 2010 at 10:27 AM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    Do you by any chance remember the part number? will this work with a LR UCA?
    If I take the UCA to autozone, will they know which boot will work?
  10. Aug 22, 2010 at 10:29 AM
    tacomakid96
    Phil
    Out n' about
    They will get the OEM replacement for it, which should be Duralast with them, I dont have the part number but if you just go in they can get the part on the computer, normally I wouldnt go to autozone but its just a boot so they should be able to get you hooked up with the right part.
  11. Aug 22, 2010 at 10:34 AM
    ToucanV13
    Do you just undo the bolt and lift up and slide the new one on?
  12. Aug 22, 2010 at 10:37 AM
    tacomakid96
    Phil
    Out n' about
    Should work.
  13. Aug 22, 2010 at 10:38 AM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    The boot on the LR is bigger than the stock. I don't think a stock replacement will fit.
  14. Aug 22, 2010 at 11:51 AM
    tacomakid96
    Phil
    Out n' about
    What kind of UCA's are they?
  15. Aug 22, 2010 at 12:06 PM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    they are ball joint, but the boot is larger than the stock from visual comparison.
  16. Aug 22, 2010 at 12:10 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Dude, call up fatbobsgarage.com and see if they replacement parts
    No place local is gonna carry that...
    801-395-2134
  17. Aug 23, 2010 at 10:05 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    One other thing - check full articulation and see if there is a reason it ripped. Typically they don't rip on their own.
    What brand are they?
  18. Aug 23, 2010 at 2:47 PM
    sdheda
    Sherj
    HB, Ca
    '10 TRD OR 4x4 DC
    In progress :/
    I haven't installed them yet, so I cant check for articulation. I also tried moving the joint by hand, but it doesn't want to move. Is it normally that hard to move the ball joint?
    Either way I just ordered 4 boots from SPC, the makers of the Light Racing UCA. Cost was ~3 per boot plus shipping, so it came out to $22.
    I really hope that nothing is wrong with the ball joint. Is there somewhere I can take it to be checked?
    I just want to install my lift and get it over with. There has been nothing but one problem after another. (I recently made a thread about a bent axle shim I received.) I can't wait for the surprises that will come with the install.
