RisingWithoutWings - 2016 TRD Off Road-Build
Discussion in '3rd Gen. Builds (2016-2023)' started by RisingWithoutWings, Aug 9, 2016.
  1. May 27, 2018 at 9:06 PM
    #61
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Love the amor...if you noticed but for your fuel capacity, notice any drop or are you still able to get 18 ish gallons filling up after the light comes on (considering that you don't run it all the way empty)? Reading that the the tank has to be a bit compressed to get it installed.
  2. May 28, 2018 at 9:55 AM
    #62
    wedgefry
    wedgefry Active Member
    Jordon
    Vancouver, Canada
    2017 Tacoma TRD Off Road DCSB
    Now that you've got a suspension lift and body lift done. Was there any issues with needing to extend brake lines or steering spacers, etc?
    At the moment I've got a 2" lift in the front and 3" in the rear (lots of constant weight in the bed), but I'm thinking of doing a 1" body lift as well.
  3. May 29, 2018 at 3:24 PM
    #63
    RisingWithoutWings
    RisingWithoutWings [OP] Well-Known Member
    SoCal
    2016 Tacoma TRD Off-Road
    I definitely did not notice a decrease in the amount of gas I can put into the tank. I don't think "compressed" is the right word, it just needs to be installed with an empty tank to make the install easier. I installed mine with more than half a tank of gas and it was difficult to thread the bolt and nuts together because of the weight of the tank. I'd highly recommend installing it with less than a quarter or so of gas to make the install easier
  4. May 29, 2018 at 3:27 PM
    #64
    RisingWithoutWings
    SoCal
    I have not ran into any issues needing new brake lines or steering spacers. The truck actually feels amazing now that i switched the Icon AAL for the Dakar HD kit. The Nitro re-gear is to thank for the amazingness now too
  5. May 29, 2018 at 3:49 PM
    #65
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Gotcha...next time, if you don't mind and the opportunity presents itself, how many gallons to fill up with the light on....curious minds would like to know. Thanks for your feed back..I'm still considering the tank skid but I did just received my mid skid pro version from them.
  6. May 29, 2018 at 4:09 PM
    #66
    RisingWithoutWings
    SoCal
    Yeah no worries, forsure it is 18. I've actually almost ran out the reserve and have pumped 20.5 once. I'll get back to you in a day or two.
  7. May 29, 2018 at 4:55 PM
    #67
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
  8. May 30, 2018 at 2:42 PM
    #68
    RisingWithoutWings
    SoCal
    I pumped 17.6 today just after the light turned on. Forsure I still had a few gallons left that would have lasted 27 or so miles
    _gray_knight_[QUOTED] likes this.
  9. May 30, 2018 at 4:05 PM
    #69
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Thx buddy! Yeah i was able to get 18.5 to 19 depending how much further I'll go, usually it's only 10-15miles right after the light comes on. That 1-1.5gal difference can be huge depending on their rig setup.
  10. May 30, 2018 at 9:00 PM
    #70
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I swear the manual claims like a 21.5 or 22.5 gallon tank. I’ve put as much as 20 gallons in mine.
  11. May 30, 2018 at 10:06 PM
    #71
    RisingWithoutWings
    SoCal
  12. May 31, 2018 at 6:10 AM
    #72
    H3llRid3r
    SLcUT
  13. Jun 6, 2018 at 12:18 PM
    #73
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    Would like to see more details on the aprs/tablet setup and the solar charging setup. Where in Socal are you?
    Psybain likes this.
  14. Jun 7, 2018 at 9:01 PM
    #74
    RisingWithoutWings
    SoCal
    This is my new ham radio setup
    This is the mount I went with :
    https://www.ballsoutoffroad.com/product-page/3rd-gen-tacoma-accessory-mount
    Details in this thread:
    https://www.tacomaworld.com/threads/in-dash-hidden-universal-mount-ram-compatible.507347/page-27
    I made a custom bracket which is nothing but a L shaped piece of metal
    Also custom switch panel :
    https://www.tacomaworld.com/threads/custom-switch-panels.533747/
    Details
    - 7 switch
    - Toyota Switch Mic Mount
    https://www.shapeways.com/product/9...l&utm_campaign=payment-received&utm_content=3
    - Toyota Switch with keystone
    https://www.shapeways.com/product/2...l&utm_campaign=payment-received&utm_content=4
    - custom keystone from local HAM radio outlet to extent cable
    Psybain, H3llRid3r and _gray_knight_ like this.
  15. Jun 7, 2018 at 9:18 PM
    #75
    RisingWithoutWings
    SoCal
    Solar setup is on page 2 of this thread. Basically the solar panel wires up to the solar controller which wires up to the bluesea fuse box that connects to my aux battery.
    APRS tablet is a Microsoft Surface running APRSISCE/32 http://aprsisce.wikidot.com/
    I don't have the tablet anymore but here is my old setup before my new mount. The mount I was using was the Un-Holey Dash Vent mount
    The tablet was wired via usb to the ham radio and also a gps dongle. The GPS dongle would should me where on the map I was and the HAM radio communicate to the tablet the APRS becons so I was able to see other APRS users, trucks, etc.
    This is someone else's setup where they describe how it works:
    Old mount I was using:
    http://www.hondogarage.com/index.php/product/landing/un-holey-dash-mount-tacoma-2016
  16. Jun 7, 2018 at 9:23 PM
    #76
    RisingWithoutWings
    SoCal
    Changed out my sPOD touch screen for the sPOD HD Panel. This is mounted in the square above the center cup holder.
    H3llRid3r likes this.
  17. Jun 7, 2018 at 9:24 PM
    #77
    RisingWithoutWings
    SoCal
    ARB Fridge monitor and National Luna Dual Battery Controller mounted under parking break
  18. Jun 7, 2018 at 9:27 PM
    #78
    RisingWithoutWings
    SoCal
    Added snorkel and wrapped hood in a matte black to remove hood glare and add protection.
  19. Jun 12, 2018 at 11:49 AM
    #79
    NOLAMedic
    NOLAMedic Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    Pics of your fridge mounted? Is it on a slide mount? Trying to figure out if I can Mount a fridge and slide under a tonneau cover.
  20. Jun 12, 2018 at 6:53 PM
    #80
    RisingWithoutWings
    SoCal
    I don't have any pictures right now but it's mounted to the smaller arb drawer that slides out. My particular setup wouldn't fit under a tonneau cover
