Risks of running snow tires? :(
Discussion in 'Wheels & Tires' started by DylansBase, Sep 26, 2014.
  1. Sep 26, 2014 at 7:54 PM
    DylansBase
    DylansBase [OP] Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    I have an extra set of studded snow tires that I want to run on my 4Runner but I've read around and there are certain things that can become hazardous. The studs are fairly small. Does anyone know anything about the subject? Is it too early to put them on. Did I say they are a bigger tire? :)
  2. Sep 26, 2014 at 7:57 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Does it snow in Sacramento?
  3. Sep 26, 2014 at 7:59 PM
    DylansBase
    Dylan
    Murfreesboro TN
    No haha, but I plan on taking multiple trips up to tahoe this season. Just wondering if it would be horrible to run them between trips up there so I wouldn't have to swap wheels before every trip
  4. Sep 26, 2014 at 8:01 PM
    AeroCooper
    NH
    Ah...well, they are very noisy on dry pavement, for one thing. I'd also check your local laws, as mentioned above.
  5. Sep 26, 2014 at 8:01 PM
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    if you are in an area that doesn't receive snow and you have a set I would just remove the studs and use the tires. The only thing is snow tires tend to wear a lot faster due to their softer rubber. Thats what I do up hear in Alaska, use my studded tires for a couple winters and then when the stud wear out just remove them and transform them into my summer tire
  6. Sep 26, 2014 at 8:03 PM
    akkyle
    Kyle
    Alaska
    I also run blizzaks which don't have studs and do amazing in the winter, however wear incredibly fast on dry pavement
  7. Sep 26, 2014 at 8:45 PM
    DylansBase
    Dylan
    Murfreesboro TN
    I was thinking about removing studs. Is it difficult?
  8. Sep 26, 2014 at 8:50 PM
    akkyle
    Kyle
    Alaska
    it takes a little elbow grease for sure, I use pincer pliers to get around the stud and then I pull, might need to rotate and pull at the same time, but it will get them out, just takes a little time to do 4 tires
  9. Sep 26, 2014 at 9:01 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  10. Sep 27, 2014 at 5:01 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I pulled studs on 4 mud tires in about 30 mins. Not too bad.
  11. Sep 27, 2014 at 5:25 PM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    Snow tires are a much softer compound and so wear quite a bit faster than standard tires. The studs will make a noise on pavement but unless you do something else to attract attention I can't imagine anyone will catch you using them.
    When studs were first outlawed in NJ - slightly used studded snow tires were available for virtually free. I bought a whole stack of them and ran them year round on a 1971 Toyota shortbed and a 1966 VW Beetle for several years without incident.
    That VW Beetle was literally unstoppable in any weather - I could drive as fast as I wanted on snow and ice, drive across a field to get around stuck cars, anything - with those four studded snow tires it didn't even pause. <g>
    I don't know how CA police are but around here they sure as hell aren't watching for your tires. <g>
    PHM
  12. Sep 27, 2014 at 5:32 PM
    DylansBase
    Dylan
    Murfreesboro TN
    Well they are CA legal from November to April as stated above. I don't see any harm running them a month early
  13. Sep 28, 2014 at 7:08 AM
    Poodle Head Mikey
    I don't remember when but I wanted to buy an "illegal" set to use in NJ a two or three years ago and was told that studs are legal again - like CA; from November through April.
    PHM
