Rivets on bottom of Dakar leaf spring pack help
Discussion in 'Suspension' started by TacomaESQ, Feb 28, 2015.
  1. Feb 28, 2015 at 12:24 PM
    TacomaESQ
    TacomaESQ [OP] Well-Known Member
    Slewis
    Sacramento
    14 TRD OR
    Icon extended travel coilovers in front, Dakar leaf pack in rear with icon 2.0 resi's
    Yeah I thought about that too.
  2. Feb 28, 2015 at 12:28 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    My bad, I was thinking of springs on my old truck that had a hole in the spring above the bottom one for the head of the rivet.
  3. Feb 28, 2015 at 12:36 PM
    TacomaESQ
    Slewis
    Sacramento
    14 TRD OR
    Ok so this is my preliminary plan. Install them without the rear shackle. Call the vendor and try to get a new pack sent out. Any danger by driving on them for a few days?
  4. Feb 28, 2015 at 2:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Normal driving should be fine , just keep an eye on them
  5. Mar 23, 2016 at 3:47 PM
    TacoCasita
    TacoCasita Active Member
    Robert
    CenterPoint, Indiana
    15 Taco DC LB Sport 4X
    Front tow hook, bed tie downs, soon: OME lift, new tires, 17" Method Mesh wheels.
    I just ran into this problem myself. How did you resolve your issue?
  6. Mar 23, 2016 at 4:15 PM
    TacomaESQ
    Slewis
    Sacramento
    14 TRD OR
    I installed them without the shackle and called it a day. I haven't noticed any problems at all.
  7. Mar 24, 2016 at 4:27 AM
    TacoCasita
    Robert
    Good to hear. I ground down the head of an Allen bolt to fit the rivet hole. But a washer on it, stuck it in the retainer and drove it into the rivet hole. Then put a lock nut on it. Seems like it should do the trick
    Thanks for the quick reply.
  8. Mar 30, 2017 at 2:17 PM
    Garrett93
    Garrett93 Well-Known Member
    Garrett
    San Diego, CA
    2006 Tacoma: Overland Build
    Did you happen to get a pic of this? I have this same issue and curious of your workaround.
  9. Mar 30, 2017 at 9:47 PM
    TacomaESQ
    Slewis
    Sacramento
    14 TRD OR
    I've been running them without the retainer since I created this thread and have had zero issues. Just a heads up in case you can't get a photo from Taco.
  10. Apr 2, 2017 at 6:27 AM
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    I just discovered the same issue on my dakars i just installed. The rivet is loose and i heard the metal band/strap thing rattling while driving. havent called headstrong yet to see what they will do.
