Rivnuts vs. well nuts for securing MOLLE panel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rcsez, Nov 4, 2022.
  1. Nov 4, 2022 at 2:52 PM
    rcsez
    rcsez [OP] Well-Known Member
    Ray
    2022 Blue Tacoma TRD
    I need to secure the bottom section of a driver's side MOLLE panel in the bed of my 22 TRD Sport. Since there's no longer a storage option, I have to make my own holes for a fastener.
    So... rivet nuts vs rubber expansion nuts, are they functionally equivalent, or is one better than the other (just for securing a MOLLE panel to the composite bed)?
  2. Nov 4, 2022 at 3:19 PM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I have used a couple dozen M5 and M8 rivnuts into my composite bed while building out my ACCC. They work wonders.
    I would skip the rubber expansion nuts and go with the rivnuts.
  3. Nov 4, 2022 at 3:32 PM
    rcsez
    Ray
    Any particular reason you'd skip the expansion nuts?
  4. Nov 4, 2022 at 3:45 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Wellnuts will allow some float and damping. Rivnuts need a good installation pattern tolerance, are a firm mount, and should use thread lock.
  5. Nov 4, 2022 at 4:57 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    …why not through bolt and use some rubber/plastic washers?
  6. Nov 4, 2022 at 5:20 PM
    rcsez
    Ray
    TBH I hadn’t even thought of that. How easy/hard is it to get a wrench behind the bed on the sides?
  7. Nov 4, 2022 at 5:25 PM
    GBourne
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Not hard in the lower areas. Annoying up high in the middle and front.
  8. Nov 4, 2022 at 5:37 PM
    rcsez
    Ray
    I have to secure one fastener near the front of the bed on both driver and passenger side, might as well just use rivet or well nuts everywhere. I don’t want to waste time trying to get a nut in the right spot inside the body cavity.
  9. Nov 5, 2022 at 4:24 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    rivnuts all the way. the rubber well nuts always pull through, or fall apart over time for me.
  10. Nov 5, 2022 at 5:00 PM
    SunRunner
    SunRunner Rub some dirt on it!
    Scott
    Pennsylvania
    ‘19 ORLB
    I used rivnuts for this exact application and it’s been solid for the past 1 1/2 years.
