RJALLDAY702's LT Build
Discussion in '2nd Gen. Builds (2005-2015)' started by RJALLDAY702, Oct 17, 2011.
  1. Sep 6, 2013 at 9:05 PM
    #2401
    MightyMouse-SCT
    MightyMouse-SCT Well-Known Member
    Gabriel
    O'SIDE CA
    MightyMouse-SCT - 2011 LT 4x4 Desert Runner
    Long Travel Total chaos kit, fox shocks, smp fab , dmz sua, glassworks, method wheels.
    White with up's ?
  2. Sep 6, 2013 at 10:21 PM
    #2402
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  3. Sep 6, 2013 at 10:40 PM
    #2403
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    What would paisa say?
  4. Sep 7, 2013 at 5:13 AM
    #2404
    RJALLDAY702
    RJALLDAY702 [OP] U MAD? OH U MAD
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    :rofl:
  5. Sep 7, 2013 at 12:47 PM
    #2405
    EL ROJO
    EL ROJO B==D~~
    Cory
    Camarillo
    Wuts up with that red beast??? U getting it?
  6. Sep 7, 2013 at 8:02 PM
    #2406
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    So fucking sick of Toyota rear ends.
  7. Sep 7, 2013 at 8:05 PM
    #2407
    triple6
    triple6 Well-Known Member
    oli
    Fallbrook, CA
    04 Double Cab Stock ;)
    all beaneer designz
    ford 9" time homie
  8. Sep 7, 2013 at 8:11 PM
    #2408
    nfs257
    nfs257 Well-Known Member
    San Diego
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    What did you do?!!??!?
  9. Sep 7, 2013 at 8:26 PM
    #2409
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    Something hit the top of the housing internally I think. It's driving fine, but she'll be getting home by trailer unfortunately.
  10. Sep 7, 2013 at 9:09 PM
    #2410
    tacokid09
    tacokid09 it's about the off-road miles
    Blang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    damn that sucks. i have to replace the gasket on mine, it just started leaking yesterday. did the place you brought it in for the re-gear have a warranty?
  11. Sep 8, 2013 at 5:21 AM
    #2411
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    JB Weld & drive :cool:
  12. Sep 8, 2013 at 6:40 AM
    #2412
    RJALLDAY702
    RJ
    Hermosa Beach
    08'
    6" Ruff Country DBL
    We were going to hammer it back in & reweld it, but couldn't that lead to more damage?
  13. Sep 8, 2013 at 7:06 AM
    #2413
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    ^^^^^^YES IT WILL!!!! However it would probably hold for quite a while and make the rear end stronger.
  14. Sep 8, 2013 at 7:30 AM
    #2414
    theduck911
    Max
    Locked and Geared!
    I wouldn't weld it, I would scrap it, inspect the third member & get a new housing,
    You could weld it for now (with a patch over top of defective area) make sure the inside is grind/polished smooth, but you' have to dismantle the diff first before doing this.
    Or just get a newly built 9" if everything is broke :cool:
  15. Sep 8, 2013 at 7:39 AM
    #2415
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    A new 9" would be a great bet or try to find an f250 ish series axle or dana 60 and put a truss it w/some chromo shafts. Gear it and call it a day. But for sure time to upgrade the entire assembly instead of just replacing the ring and/or pinion.
  16. Sep 8, 2013 at 8:04 AM
    #2416
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    Lander, Wyoming
    2012 TRD Off Road Double Cab V6 6Speed
    Don't try to weld that, in a few passing conversations with the master techs here I learned that welding that kind of shit on the housing requires a process and cooling in sand... My rear seal started leaking last week and the dealer wouldnt fix it because it had "scratches" on it, so I topped it off and drove home to replace all the studs and seal with FIPG, almost a week now and a road trip with no new leaks. Saved myself 800 the dealer was going to rape me for. I will say i'm tired of the toyota rear end already... Good luck
  17. Sep 8, 2013 at 3:15 PM
    #2417
    MightyMouse-SCT
    Gabriel
    O'SIDE CA
    RJ - gay
    Rear end 12" and $6k
  18. Sep 8, 2013 at 3:17 PM
    #2418
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2015 Tundra Double Cab
    See Build in Sig
  19. Sep 8, 2013 at 3:30 PM
    #2419
    lembowski
    lembowski Rompin Around
    Rolando
    09 LT, Caged, 4WD
    It's blew up more times since he had that shop change out her R&P then it ever did before!
  20. Sep 8, 2013 at 4:12 PM
    #2420
    anthony250f
    anthony250f Well-Known Member
    Anthony
    goleta/santa barbara, ca
    97 5 speed 4x4 v6
    lt
    i feel like everyone who has changed gearing is blowing up there diffs
