rjbiii's 6-Speed Supercharged 4X-Runner Build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by BassAckwards, Jun 17, 2018.
  1. Jun 17, 2018 at 3:02 PM
    BassAckwards
    BassAckwards [OP] formerly rjbiii
    Robert
    SATX
    '09 5spd PreRunner & '13 6spd 4wd
    2013 TRD Sport 4x4
    - Double Cab Short Bed
    - Barcelona Red Metallic (3R3)
    - 6 speed manual (RA60F)
    - Bought used w/ 24,500 miles on 4-21-17 @ CarMax
    Goal for this is to build a 4-door X-Runner style AWD street truck that I can enjoy as my daily driver.
    Want to give a big shout out to all the folks who I have drawn inspiration from and have helped me with my build!
    @Roostfactor@Athlaos@o0opackersfano0o@Texoma@loginfailed@BillDaCat8@MattCowsmasher@ChadsPride@12TRDTacoma@White lightning boosted@Torspd@JuanitoBunito@TRON@snowsk8air2@XPOTRPR@JacksonTacoma@hoverlover@gunny1005@ALI3N_123@b_r_o@74cam
    Current pic
    The day I brought her home
    Videos:
    https://youtu.be/F_xR7WNOLG0
    https://youtu.be/ih-mvtqdU04
    Interior/Cab:
    - Wet Okole seat covers w/ red Tacoma imprint 8-28-17
    - OEM all weather flooring 1-6-18: thanks to @gunny1005
    - 6spd TRD shifter 4-14-18: thanks to @hoverlover
    - OEM floor mat clips 7-7-18
    - TRD shifter color matched lettering: 7-27-18
    - Flexpod gauge mount: 8-8-18
    - Lotek a-pillar gauge mount: 11-17-18
    Wheels/Tires:
    - TRD Sport 17x7.5” wheels (28.9lbs/wheel)
    - 265/65/17 Michelin LTX Defenders P-rated(40.74lbs/tire) 5-17-18: thanks to @lilred95
    Lighting/Electrical:
    - Northstar 27F deep cycle battery 8-25-17
    - Fog light anytime mod 12-12-17: thanks to @nd4spdbh
    - 7-Pin trailer harness relocated above rear bumper: 7-14-18
    - AEM 52mm boost gauge: 8-8-18
    - AEM 52mm fuel pressure gauge: 8-8-18
    - JDM Astar H11 LED amber fog lights: 11-9-18
    - (2) AEM 52mm AFR gauges: 11-17-18
    - PIAA 520 SMR: 2-28-19
    Suspension:
    - Stock Bilstein 4600s: thanks to @Texas-Shrapnel
    - SOS performance 3.5" rear lowering kit: 5-19-18
    - Energy suspension poly sway bar bushings: 11-11-18
    - SOS performance front 2" drop w/ 2nd gen TRD OR progressive coils: 3-9-19
    - SOS performance front poly bump stops for 2" drop: 3-16-19
    Exterior/Bed:
    - AVS bug deflector & in-channel rain deflectors: installed by previous owner
    - OEM bed extender: installed by previous owner
    - De-badged bedsides: 6-15-17
    - Tan Softopper: 8-21-17
    - Faux Pro grille insert: 5-18-18: thanks to @CaliRaisedLed
    - Front license plate relocated to skid pan: 5-19-18
    - Trimmed mud flaps; fronts 5", rears 4": 6-22-18
    - Hood repainted: 6-20-18
    - BRM X-Runner badges: 7-7-18
    - 4wd Tundra badge color matched: 7-15-18
    - Color matched TRD Pro grille lettering: 7-15-18
    - Red anodized valve stem caps: 11-10-18
    - TRD aluminum skid plate: 11-17-18
    - Homertaco lower valence wire mesh: 11-24-18 thanks to @ChadsPride
    - Color matched TRD OR tow hook: 11-24-18 thanks to @Graf_Taco
    - Avid Off-Road front bumper guard: 1-6-19
    Performance: Max MAF to date 345.3g/s= ~407hp
    - Secondary air pump 1" Unifilter 9-11-17
    - Magnuson supercharger 6-23-18
    - Walbro 255 LPH fuel pump 6-23-18
    - 170 degree thermostat 6-23-18
    - Pulleyboys Qwikchange S/C pulley hub: 6-26-18: thanks to @12TRDTacoma
    - S/C snout trimmed for smaller pulley clearance 6-26-18
    - TRD short shifter (PTR04-35052): 7-12-18
    - URD TCAI: 7-31-18
    - aFe 3" Rebel series catback exhaust: 9-6-18
    - JFR equal length y-pipe made by @Roostfactor 9-15-18
    - URD Spec-U equal length headers: 9-15-18
    - Vibrant 1142 3" ultra quiet resonator: 9-15-18
    - URD stage 3 clutch: 11-9-18 thanks to @Athlaos
    - Lightweight flywheel: 11-9-18
    - TOB repair/sleeve kit: 11-9-18
    - 4.10 rear gears: 12-2-18: from my Turtle
    - Detroit TruTrac: 12-2-18: install thanks to @Texoma
    - Snow performance water/methanol injection w/ stage 3 controller: 12-9-18
    - Roush S/C belt tensioner: 1-5-19
    - Smoothflow 2.6" pulley w/ rip mod: 1-19-19
    - 69.5" Fleetrunner belt: 1-19-19
    - TB to S/C inlet port matched 1-19-19
    - Bypass valve restrictor jet removed 1-22-19
    - 455cc TRD injectors: 2-3-19
    - UCon EMS w/ stage 2 tune: 2-16-19
    - Devil's Own water/methanol filter: 2-21-19
    - Fuel line check valve: 3-1-19
    - 4.10 geared front diff: 3-16-19
    Weight Removal:
    - OEM bed extender: 7-14-18
    - OEM tow hitch removed ~50lbs 7-14-18
    - Bed rack over Softopper 1-27-18: thanks to @cglasco
    Awaiting Install:
    - front clamshell w/ 4.10s
    - Dry out fog light and seal w/ silicone
    - paint front sway bar
    - ADD delete
    - FJ Cruiser auto t-case (VIN: JTEBU11F970038158):
    - Roostfactor wrap idler
    - 2.5" Pulley w/ Carbinite coating
    - TRD tailgate emblems (PT413-35120-02:red PT413-35120-03:gloss black)
    - Paint TRD emblem BRM
    - Oil catch can
    - TRD radiator cap
    - TRD skid plate sticker
    - Methanol controller IPW wiring
    Future List (in order of priority):
    - TRD catback exhaust
    - 3" to 2.5" Vibrant reducer
    - X-runner rear sway bar (48812-AD030) w/ SOS mounting brackets
    - 76mm throttle body w/ URD adapter plate
    - New serpentine drive belt (truck)
    - trans cross member reinforcements (51225-04040)
    - X-brace Part number (51207-04010)
    - NST lightweight pullies
    - Port matched intake manifold
    - 3rd gen TRD skid plate (PTR60-35190)
    - Tundra oil filler neck
    Part numbers:
    12196-38010 Tundra oil filler tube seal
    12185-38011 Tundra oil filler tube
    PTR04-12108-02 TRD oil cap​
    - Rokblokz mud flaps
    - TRD logo for skid plate 13" red
    - Sound deadening
    - Coupe modified shifter
    - Port intake manifold, S/C, & 76mm TB
    - Pop & lock tailgate handle
    - Locking gas cap
    - Viking performance double adjustable rear shocks
    - Lock for rear sliding window
    - Redline tuning hood struts
    - Sprint booster
    - Valentine 1 or Escort radar detector
    - Retrofit headlights w/ amber halos
    - Coupe battery tie down
    or aluminum battery tray replacement
    - Custom gauge mount in front of shifter
    - Oil temp gauge- AEM
    - Oil pressure gauge- AEM
    - Coolant temp gauge- AEM
    - Red anodized lug nuts
    - HPS radiator hoses
    - HPS heater hoses
    - CSF radiator
    - 160* thermostat
    - Lexus LS 460 electric fan conversion
    - SOS performance rear disc brake conversion w/ sequoia master cylinder
    - Front big brake kit or Stock brake upgrade
    - Paint calipers red
    - SS red brake lines
    - Front lower valence color matched or painted silver
    - Tailgate reinforcement
    - Corbeau front seats
    - Ultimate headlight upgrade
    - IEDLS poly/solid carrier bearing
    - Black polyeurethane around carrier bearing
    - Solid motor mounts made by @Bonzen
    - Black methanol tubing
    - Poly UCA & LCA bushings
    7th Injector
    Fuel cooler
    Larger S/C intercooler
    URD Stage 3+ Clutch
    Canton S/C coolant reservoir
    Canton S/C coolant reservoir lid
    Rear diff backing plate
    Color match supercharger
    Inferno paint job (4X0)
    Wider tires- Nitto 420s (275/60/17; 37.59lbs/tire)
    S/C Rebuild
    Ceramic coating for S/C rotors
    Solid coupler
    Snake bite regear​
    Long Range Automotive Fuel Tank (34 gallon)
    Leer 100xq
    Jump start pack
    PIAA 510s
    Deka/Braille 20lb battery
  2. Jun 17, 2018 at 3:03 PM
    BassAckwards
    Robert
    SATX
    Colorado December '17
    OEM all weather vinyl flooring and Wet Okole seat covers
    Painted shift pattern on TRD shifter
    Trimmed mud flaps front and rear
    Upgrade Walbro 255LPH fuel pump with external filter conversion
    Intake manifold off
    Exhaust cam gears upgraded for the UCON
    The final product!
    3 days after the blower went on, decided I need more.. so pulleyboys 2.8 qwikchange & snout cut down for smaller pulley clearance. Snout cutting took me about 30 minutes from start to finish with a ratchet and the URD tool
    URD TCAI
    Equal length y-pipe being custom made
    New equal length URD spec u headers, equal length JFR ypipe, and vibrant resonator fitted to my aFe 3" catback exhaust
    The master at work
    Pic of the flux inside the piping to keep the weld pure
    The finished product. Y-pipe>V band>resonator>aFe exhaust
    Snow Performance Stage 3 water/meth injection added. Moved ultragauge to the left of the tach. Dual AFR gauges on the flex pods, boost & fuel pressure moved to Lotek a-pillar. Low level LED indicator for the methanol also on the a-pillar. Added an in-line water/methanol stainless steel filter right after the pump.
  3. Jun 17, 2018 at 3:03 PM
    BassAckwards
    Robert
    SATX
    Part Numbers/Links/Discounts/References:
    Discount Codes
    URD:
    5% off: tacomaworld.com
    5% off: forummember
    Snow Performance:
    10% off: RACER2018
    Non-Stop-Tuning:
    10% off: NST10
    20% off: SANTA
    20% off: NEW
    20% off: FLASH20
    20% off on 2/1/19 & 2/2/19: HOG
    Jegs:
    Resources
    2005 Tacoma Factory Service Manual
    OBDII Trouble Code List
    Torque Spec Guide
    Supercharger Installation
    Custom gauge face plates
    DIY Threads
    - OEM All Weather Flooring
    - 6spd clutch install write-up
    - CSF Aluminum Radiator
    - Bosch 4.9 AFR Denso replacements
    Part Numbers
    - 1GR-FE Stock Air Box Engine Air Filter:
    17801-0P010
    TCAI Air Filter
    - Cabin Air Filter:
    87139-YZZ09​
    - Front diff drain plug copper crush washer
    90430-24003​
    - Injector port insulator/damper
    23291-23010​
    - TRD Performance Brake Pads:
    PTR09-89111​
    - Barcelona Red X-Runner Badges:
    75471-04040-D1: Toyota badge
    75427-04020-D1: Tacoma badge
    75475-04010-D1: X-Runner badge​
    - Oil drain plug crush washer:
    - TRD 6spd 4wd short shifter
    - 4.0 MAF Sensor (Denso):
    22204-22010​
    - AFR/front o2 sensors 4.0 (Denso)
    89467-04090​
    - Transmission drain plug washer (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs
    - Transmission fill plug washer (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs
    - Clutch master cyl hard line
    31481-6A050​
    - Floor mat clip
    08210-00820​
    - Yellow clips for dash/radio
    90467-10203​
    - Vacuum switching valve (90910-TC001)
    - K&N fuel filter
    Miscellaneous Information
    Hewitt SAIS bypass for 2012
    - Sound deadening
    - 265/70/16 Michelin Defender P-rated weight: 37.76lbs/tire
    - Redline MT-90
    - Canton Fuel Cooler
    - Softopper buckles: Sea-to-summit buckles w/ metal pins
    - Fuel rail fitting for 7th injector/fuel rail tap
    - OEM connector catalog/part numbers
  4. Jun 17, 2018 at 3:04 PM
    BassAckwards
    Robert
    SATX
    Maintenance/Replaced Parts:
    @24,500 miles: 4-23-17
    - M1 Ext. performance oil change w/ Toyota filter
    - greased u-joints:
    @29,233 miles: 6-30-17
    - M1 High mileage oil change w/ Toyota filter
    - greased u-joints
    @35,612 miles: 9-23-17
    - M1 oil change w/ Toyota filter
    - greased u-joints
    @39,980 miles: 12-15-17
    - greased u-joints
    @42,768 miles: 1-5-18
    - replaced engine air filter
    - new spark plugs
    @45,165 miles: 4-15-18
    - replaced cabin air filter
    @47,270 miles: 6-17-18
    - Michelin LTX Defender M/S 265/65/17
    @47,406 miles: 6-21-18
    - M1 Ext performance oil change w/ Toyota filter
    @47,525 miles: 6-23-18
    - Magnuson s/c
    - Walbro 255
    - UCON Flex EMS
    - 170 Degree thermostat
    - Coolant drain and refill
    @48,411 miles
    - Greased u-joints
    @50,064 miles
    - rotated tires x
    @50,125 miles
    - new Denso MAF sensor
    @50,335 miles
    - Trans fluid changed to Redline MT-90
    @50,559 miles
    - new Napa gold 3296 fuel filter
    @52,500 miles
    @53,880 miles
    - Trans fluid changed w/ Redline MT-90
    @54,119 miles
    - two new AFR sensors
    - six new Denso ikh22 spark plugs
    - cleaned MAF sensor & throttle body
    @54,750 miles
    - six new Denso coil packs
    @55,507 miles
    - cleaned intake piping, MAF sensor, & throttle body
    @55,722 miles
    - URD stage III clutch
    - Lightweight steel flywheel
    - URD sleeve kit & oversized TOB
    - T-case fluid change w/ Lucas 80w-90
    - Rear diff fluid change w/ Lucas 85w-140
    - Front diff fluid change w/ Lucas 80w-90/85w-140 mixed
    - Greased all u-joints
    @57,790 miles
    @57,911 miles
    - TRD tuned ECU installed
    - Tires cross rotated front to back
    @58,160 miles
    - Detroit trutrac added
    - 4.10 rear gears installed
    @59,000 miles
    - M1 high mileage oil change w/ Toyota filter
    - Snow performance water/meth injection installed
    @59,077 miles
    @59,950 miles
    - New UCon
    @60,069 miles
    - Trans fluid changed w/ Nissan 75w-85
    - Thermostat housing replaced
    - 70.2" fleetrunner belt installed
    @60,375 miles
    - Roush S/C tensioner installed
    @60,902 miles
    - greased rear driveshaft u-joints (3)
    @61,300 miles
    69.5" belt
    2.6 pulley
    61lb deka injectors
    @61,660 miles
    - Denso IKH24 spark plugs
    @62,200 miles 2-3-19
    - 455cc injectors
    - TRD tune
    - FPR mod
    - URD o2 simulators
    - Added 1/2qt Nissan MTF fluid
    @62,638 miles 2-10-19
    @62,775 miles 2-13-19
    - New Gates fleetrunner 69.5" belt
    @63,135 miles 2-16-19
    - UCon Stage 2 tune w/ 455cc injectors
    @63,435 miles 2-21-19
    - Water/methanol filter
    @63,662 miles 3-1-19
    - Tranny fluid changed w/ Redline MT-90
    - K&N fuel filter
    @63,765 miles 3-2-19
    - Tranny fluid changed w/ Lucas 85w-140
    @64,200 miles 3-9-19
    - SOS front 2" drop installed w/ Bilstein 4600s
    - Rear Bilstein 4600s replaced
    - Tire rotation- front to back
    @64,250 miles 3-11-19
    - Alignment
    @64,700 miles 3-17-19
    - regeared front diff to 4.10s (diff from 2006 tacoma reg cab 4wd VIN:5TEPX42N56Z231513)
    - SOS performance shorter front poly bump stops
  5. Jun 17, 2018 at 3:04 PM
    BassAckwards
    Robert
    SATX
    Troubleshooting info:
    Heres what ive done in chronological order:
    - replaced k&n filter w/ paper OEM filter
    - cleaned MAF (old one multiple times, then replaced and have cleaned the new one as well)
    - cleaned throttle body
    - Double checked all hoses from pcv, brake booster, VSV, passenger valve cover vent to intake, fuel pressure regulator, bypass valve, etc were tight and are not routed incorrectly
    - added hose clamp to vaccum tubing from bypass valve to the back of s/c - did not add one to the hose end attaching to the bypass valve, it was pretty tight on there
    - Replaced MAF Sensor (w/ oem denso)
    - recalibrated VSC after lowering the truck
    - removed bypass restrictor jet
    - Changed intake from stock airbox to URD TCAI
    - replaced fuel filter w/ napa gold 3296
    - added fuel pressure gauge (holds 41-42psi to redline)
    - UCON was sent to Gadget and he tested it on his truck for a week; was unable to replicate above mentioned problems)
    - replaced headers & y-pipe (Running no cats)
    - replaced fuel bowl (original got a hole cut in the side during install)
    - racetronix plastic fuel hose upgrade
    - re-installed bypass restrictor jet
    - blew out all connections on injectors, coil packs, ECU, UCON, MAF sensor, & throttle body w/ compressed air
    - replaced both front AFR/o2 sensors (w/ OEM denso)
    - did compression test; #s below
    #6 200psi
    #4 195psi
    #2 202psi
    #5 199psi
    #3 200psi
    #1 197psi​
    - replaced all spark plugs with new ones gapped to .032" about 1500 miles ago (denso ikh22)
    - looked over all injector bushings and everything looked normal
    - replaced all coil packs with OEM denso units (was having a p0300 as well as all the individual misfire codes a while back, and havent had any after replacing the coil packs; also had a p0353 that hasnt come back- all of these codes were intermittent and did not occur during the problems discussed above while at WOT)
    - cleaned all intake piping, MAF, throttle body again
    - took ucon & stock ECU out, cleaned all connectors w/ contact cleaner, reconnected, disconnected, repeated twice.
    - cleaned ground near negative battery terminal
    - cleaned ground on rear section of passenger valve cover
    - TRD Flashed ECU installed
    - New UCon (old one turned out to be the issue)
  6. Jun 17, 2018 at 3:04 PM
    BassAckwards
    Robert
    SATX
  7. Jun 17, 2018 at 3:04 PM
    BassAckwards
    Robert
    SATX
    Exhaust info
    Alternate catback:
    - Vibrant 1141 2.5" resonator
    - Stainless Bros reducer
    Replacement aFe mufflers:
    - Borla
    - Magnaflow
    MattCowsmasher and TacoDude 72 like this.
  8. Jun 17, 2018 at 3:04 PM
    BassAckwards
    Robert
    SATX
  9. Jun 17, 2018 at 3:46 PM
    MattCowsmasher
    MattCowsmasher Sounds like a horrible idea, what time? TTC #0010
    Temple
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, scuba ready, pizza cuttin tires, debadged with a hood skewp.
  10. Jun 17, 2018 at 3:47 PM
    BassAckwards
    Robert
    SATX
    :wave: hey there buddy!
  11. Jun 17, 2018 at 3:47 PM
    MattCowsmasher
    Temple
    :hattip:Hey there, trucks looking good
  12. Jun 17, 2018 at 3:49 PM
    BassAckwards
    Robert
    SATX
    Thanks man!:D
    TacoDude 72 and MattCowsmasher like this.
  13. Jun 17, 2018 at 3:50 PM
    MattCowsmasher
    Temple
    Your welcome, Can we BS also? You ever get your dad that arb?
    redtaco512 likes this.
  14. Jun 17, 2018 at 3:52 PM
    BassAckwards
    Robert
    SATX
    BS is ALWAYS welcome :thumbsup:
    You talking about the trim piece for his ARB bumper?
    Got it cut, and going to paint it here in the next couple days and then slap it on there! will post up pics whenever i finish it up
  15. Jun 17, 2018 at 3:57 PM
    MattCowsmasher
    Temple
    Ya that’s the one my memory is kinda flaky here lately. Awesome can’t wait to see it.
  16. Jun 17, 2018 at 4:00 PM
    BassAckwards
    Robert
    SATX
    no worries! I need to get going on that.. been battling the exhaustion from traveling the past couple days. He's also getting the over softopper bed rack that i took off of my truck. Repainting that as well. Truck should look nice once everything's finished up
    redtaco512 and MattCowsmasher like this.
  17. Jun 17, 2018 at 4:02 PM
    MattCowsmasher
    Temple
    Niceeee:thumbsup: ya man get some rest driving like that takes its toll we’re the crosswinds a biotch for ya?
  18. Jun 17, 2018 at 4:06 PM
    BassAckwards
    Robert
    SATX
    The crosswinds weren't bad on the way back, but there was a 20-25 mph headwind so it absolutely killed my gas mileage.. got about 20mpg the whole trip till heading back. Dropped to 16-17ish on the way home
  19. Jun 17, 2018 at 4:08 PM
    MattCowsmasher
    Temple
    Rough well glad you made it back in one piece.
    redtaco512 and BassAckwards [OP] like this.
  20. Jun 17, 2018 at 4:09 PM
    BassAckwards
    Robert
    SATX
    You and me both! it was a haul for sure.. glad to be back in the great state of TX:headbang:
