rjbiii's 6-Speed Supercharged 4X-Runner Build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by BassAckwards, Jun 17, 2018.
  1. Mar 8, 2019 at 7:57 AM
    #861
    BassAckwards
    BassAckwards [OP] formerly rjbiii
    Robert
    SATX
    '09 5spd PreRunner & '13 6spd 4wd
    Got most of the wiring for my fogs in last night. Got dark and i was tired, so called it quits. Will wire up the switch when i get home today. Mounting the relay was the most difficult since everything from the S/C seemed to be in the way. Got that figured out though, so shouldnt take long to finish up now!
    Also, picking this A/T FJ T-case up tomorrow! :taco:
    May try doing the install this weekend.. @hoverlover you have any plans for after CnC?
  2. Mar 8, 2019 at 8:38 AM
    #862
    hoverlover
    hoverlover Destination: DIESEL. TTC #54
    Alex
    C-137, Earth, USA, Texas, San Antonio
    13 TRD O/R DCSB 6 SPD
    Mostly Zip-Ties
    Nice! Sounds productive enough to me!
    Yea, unfortunately I've got a full day of work. I'll have to leave CnC no later than 930 to make it in on time. After work, packing up and heading do to Lake Corpus Christi for some overnight fishing and camping, then literally hitting the road to Utah from there. It's going to be a stupid busy day tomorrow.
  3. Mar 8, 2019 at 8:40 AM
    #863
    BassAckwards
    Robert
    SATX
    Sounds good no worries! May just go home and tear things apart since i've got my other truck running good. Sounds like you've got a very nice trip planned also
  4. Mar 8, 2019 at 8:48 AM
    #864
    hoverlover
    Alex
    Mostly Zip-Ties
    Gonna go adding an FJ case without me eh? I see how it is...
    Just pulling your leg, take lots of pictures then you can come solve any problems I might run into :rofl:
    Also, can I borrow that 30mm socket when you're done with it? :p
  5. Mar 8, 2019 at 8:59 AM
    #865
    BassAckwards
    Robert
    SATX
    Lol just a maybe at this point, gonna see how i feel..
    Will do if i end up tearing into things!
    What is the 30mm socket for? driveshaft flange nut? and of course you can borrow it mang! Gotta get one first though lol
  6. Mar 8, 2019 at 9:01 AM
    #866
    hoverlover
    Alex
    Mostly Zip-Ties
    Yep, gonna need it to split the case. That was my hang up last night. I was tempted to put some big ass channies or vice grips on it and tap it loose but decided that was a stupid idea lol
  7. Mar 8, 2019 at 9:05 AM
    #867
    BassAckwards
    Robert
    SATX
    hmm i wonder if lowes or home depot has those. Their websites dont show "in store" may have to hit up Gibsons and see if they have it.. If they dont have it, you gotta order it online lol
    MattCowsmasher likes this.
  8. Mar 8, 2019 at 9:39 AM
    #868
    hoverlover
    Alex
    Mostly Zip-Ties
    orlly?
    I thought I'd seen it at advanced auto parts. Good to know before I go tearing into shit!
  9. Mar 8, 2019 at 9:43 AM
    #869
    BassAckwards
    Robert
    SATX
    Yeah may just be something they dont list on their website tho. Whenever i find one, ill let u know where i got it from. Id be willing to pay the ridiculous 100% markup from an auto parts store if no one else has it. We shall see though
    hoverlover and MattCowsmasher like this.
  10. Mar 9, 2019 at 8:09 PM
    #870
    BassAckwards
    Robert
    SATX
    @hoverlover got a 30mm 6 sided socket at Vatozone tonight.. May give it a go tearing into the FJ case tomorrow. Still trying to figure out the best way to cut my floor for the shifter.. Wonder if a dremel would work with the right tip?
    MattCowsmasher and hoverlover like this.
  11. Mar 9, 2019 at 8:45 PM
    #871
    hoverlover
    Alex
    Mostly Zip-Ties
    2.5" hole saw should do a very nice, clean job of things
  12. Mar 9, 2019 at 8:45 PM
    #872
    hoverlover
    Alex
    Mostly Zip-Ties
    That's my plan at least
  13. Mar 9, 2019 at 8:46 PM
    #873
    hoverlover
    Alex
    Mostly Zip-Ties
    Or an angle grinder and a new cutoff wheel
  14. Mar 9, 2019 at 9:03 PM
    #874
    BassAckwards
    Robert
    SATX
    Hole saw sounds pretty easy, may end up doing this! Also think i got a lead on a 6spd FJ trans and t-case so may be going AWD sooner than later.. Its in pasadena if it's still available.
    Also, If i swap in my fj case without deleting the ADD, will i still have 2low, just no 4wd technically because the add wouldnt be engaging and only the tcase would engage high/low range? Trying to figure out if id be able to test if everything was working if i put the fj case in tomorrow or if i should just wait. The suspense is killing me
  15. Mar 9, 2019 at 9:05 PM
    #875
    BassAckwards
    Robert
    SATX
    Gonna try and buy the driveshafts and everything so that i can have those retubed and i wont be down
  16. Mar 9, 2019 at 10:38 PM
    #876
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    4x4 Conversion, FJ case, Manual Hubs, 2017 Suspension, TSB Leafsprings, 2015 Interior update, 2017 Head unit, Lock on start, Mirror Riser
    Don't know if this will help you but
    https://www.tacomaworld.com/threads/prerunner-to-4x4-conversion-guide.534480/#post-17168337
    My suggestion:
    Butt the bellhousing against the engine, raise it a bit and mark center of where the shifter will be on the bottom of floor pan. Remove the trans and drill a hole up into the floor at that mark, then go in the cab and use that hole as center for a 4" Hole Dozer. I'd even drill 1/2" back from that hole, knowing what I know now.
    hoverlover and BassAckwards [OP] like this.
  17. Mar 10, 2019 at 6:53 AM
    #877
    BassAckwards
    Robert
    SATX
    Definitely going to use that guide, appreciate the link man! I am going to try and do what you said, but only without pulling the trans (because so much crap has to come off to drop the 6spd). I think it should be able to be done, may just take a little more time/fitment.
    Do you know if my theory about installing the fj case without modifying the ADD would work temporarily? I wouldnt have 4wd obviously, but would i be able to engage low to test functionality of the case?
    hoverlover likes this.
  18. Mar 10, 2019 at 9:08 AM
    #878
    BassAckwards
    Robert
    SATX
    Re-read this this morning haha.. Big ass channies.. Never heard channel locks referred to as that :rofl:
  19. Mar 10, 2019 at 9:54 AM
    #879
    05Taco4x4
    2TR-FE Enthusiast
    Sorry, I was thinking you were doing 4x4 conversion too but you already have it, you're just swapping t-cases. I would do the same with the t-case: drop the other, butt new against transmission and mark center of shifter ...
    Yes of course but you should be able to turn it by hand uninstalled and see the outputs' rotation difference
  20. Mar 10, 2019 at 9:57 AM
    #880
    05Taco4x4
    2TR-FE Enthusiast
    I'm considering swapping my 5-speed/FJ t-case for the A340 and 4Runner V6 t-case but haven't looked yet what i'll need to do to get the case to work properly, I've figured the auto swap out. I don't have ADD so I would have to figure that out
