rjbiii's 6-Speed Supercharged 4X-Runner Build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by BassAckwards, Jun 17, 2018.
  1. Mar 15, 2019 at 11:07 AM
    #901
    MattCowsmasher
    MattCowsmasher Sounds like a horrible idea, what time? TTC #0010
    Temple
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, scuba ready, pizza cuttin tires, debadged with a hood skewp.
    100:D
    hoverlover and BassAckwards [OP] like this.
  2. Mar 15, 2019 at 11:13 AM
    #902
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    6 sided 35mm socket. There's some 19mm heads, 17mm heads, and internal torx bolts. You'll want all new seals.
  3. Mar 15, 2019 at 11:30 AM
    #903
    BassAckwards
    BassAckwards [OP] formerly rjbiii
    Robert
    SATX
    '09 5spd PreRunner & '13 6spd 4wd
    10-4 about to paypal ya
    Axle seals i presume? and any idea as to the difficulty of this job on a scale from 1-10? im guessing it's pretty similar to the rear diff, just more stuff to take off
    hoverlover and MattCowsmasher like this.
  4. Mar 15, 2019 at 11:31 AM
    #904
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    For me, difficulty of 2-3
  5. Mar 15, 2019 at 11:32 AM
    #905
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Yes, axle seals
  6. Mar 15, 2019 at 11:33 AM
    #906
    BassAckwards
    Robert
    SATX
    Do you know what the part numbers for those are by chance? im thinking ill stick with toyota ones to be safe..
    hoverlover likes this.
  7. Mar 15, 2019 at 11:34 AM
    #907
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I got new ones at the house and can get ya a pic when I get home
  8. Mar 15, 2019 at 11:35 AM
    #908
    BassAckwards
    Robert
    SATX
    You are the man! Appreciate it Chris:fistbump:
  9. Mar 15, 2019 at 11:36 AM
    #909
    BassAckwards
    Robert
    SATX
    Should be there brudda
  10. Mar 15, 2019 at 11:38 AM
    #910
    MattCowsmasher
    Temple
    It is your fast with it
  11. Mar 17, 2019 at 12:58 PM
    #911
    BassAckwards
    Robert
    SATX
    For the switch, I decided to try and make it as clean as possible, so I drilled a hole in bottom of the factory switch blank, and ran the wiring for the switch down through there. I'm pretty pleased with how it turned out
    Final product
    Did a review on these lights. Here are a few pics, theyre really bright, im loving them
    For reference, these pictures were taken without covers installed
    Dims
    High beams
    High beams w/ PIAA 520s
    Also regeared the front clamshell to 4.10s that i got out of a wrecked Reg cab 4wd 4cylinder. Truck feels so much more solid now with 4wd back. As usual, @Texoma did a stellar job and even went the extra mile to swap my ADD/diff tube to my new diff. Really appreciate all your hard work and for working me into your schedule brother! :hattip:
    The new diff and my old diff puked 75w90 and 85w140 all over my bed, so i gotta figure out the best way to clean that up.. Suggestions?
  12. Mar 17, 2019 at 4:10 PM
    #912
    BassAckwards
    Robert
    SATX
    @05Taco4x4 i think you have an auto fj case with a single stick behind your r155f so maybe you can help me..
    Is it normal when the case is in the 4high position for the shifter to be able to float around a little bit from left to right? Or does yours lock into place?
  13. Mar 17, 2019 at 6:25 PM
    #913
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    4x4 Conversion, FJ case, Manual Hubs, 2017 Suspension, TSB Leafsprings, 2015 Interior update, 2017 Head unit, Lock on start, Mirror Riser
    I honestly couldn't tell you, I've only used 2HI and 4LO (I only need it on the sand here).
    I can say that I initially installed the shifter wrong into the spring and when shifting down to 4HI (on way to 4LO) it would swing over to the right, instead of stay left.
  14. Mar 17, 2019 at 6:27 PM
    #914
    05Taco4x4
    2TR-FE Enthusiast
    I'd say check that you've installed the shifter in the spring correctly, also possible your spring needs replacing.
  15. Mar 17, 2019 at 6:32 PM
    #915
    05Taco4x4
    2TR-FE Enthusiast
    Transfer Select Return Spring
    36349-35010
  16. Mar 17, 2019 at 6:38 PM
    #916
    BassAckwards
    Robert
    SATX
    Will definitely check this out, thanks for the great info!:hattip:
  17. Mar 18, 2019 at 9:07 AM
    #917
    MattCowsmasher
    Temple
  18. Mar 18, 2019 at 9:12 AM
    #918
    BassAckwards
    Robert
    SATX
    Morning sir!:hattip:
    Haha dig the jeremy clarkson gif:laugh:
  19. Mar 18, 2019 at 9:13 AM
    #919
    MattCowsmasher
    Temple
    Morning!! I did to that’s the face I imagine you have driving that sexy bisch.
  20. Mar 18, 2019 at 8:37 PM
    #920
    BassAckwards
    Robert
    SATX
    Hahah its perfect, probably pretty accurate somtimes too:rofl:
