Road drifter.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grist, Jun 13, 2010.
  1. Jun 13, 2010 at 6:55 AM
    grist
    grist [OP] Well-Known Member
    Kevin
    Northeast Pa
    2010 Tacoma Sport dc
    Weathertechs, access cover
    Does anyone know why my truck drifts on the road? I have stock bridgestone 17 duelers. I had the rear tsb done but it did it before I believe. Its starting to get on my nerves at 5000 miles.
  2. Jun 13, 2010 at 6:57 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Have you owned a truck before? You may not be used to the lack of weight in the back. Just take the turns slow and gentle and you should be fine.
    Is all the Traction control and vsc turned on or off to your knowledge?
  3. Jun 13, 2010 at 7:02 AM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
    2nd Gen Tacomas are somewhat notorious for wandering on the highway. Gets worse if you lift it and add bigger tires. I finally got my alignment dialed in just right so mine is pretty good now, do a search and you'll find several threads discussing this subject.
  4. Jun 13, 2010 at 7:05 AM
    Jason'sLawnCare
    Oh I think I misunderstood your problem. I thought you meant the back was slipping out when you turn hence drifting. I consider your problem wandering and yeah it probably needs to be aligned.
  5. Jun 13, 2010 at 7:05 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Alignment, proper tire pressure are both your friends.
    Trucks do not hold themselves in line as well on the interstate as other types of vehicles. They're tall, have a high center of gravity, a lot of wind resistance and crosswind, and have a light ass. An even lighter ass in the case of the Tacoma, with the composite bed.
    This is just trucks...some are worse about it than others, but it's never going to drive like a car or SUV.
  6. Jun 13, 2010 at 8:13 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    With 5000 miles on your truck you should just take it to the dealership and get it fixed under warranty. The alignment shouldn't be off with 5000 miles on your truck.
  7. Jun 13, 2010 at 8:25 AM
    sbeau1960
    Scott
    Indianapolis
    Your alignment could be off with 2 miles on the truck if you hit a major pothole or whacked a curb, this is why alignment isn't covered under warranty.
  8. Jun 13, 2010 at 8:32 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    Mine has wandered on the freeway since day one. There's a lot of "give" in the steering shaft assembly. A TSB for that has been discussed here, but I don't know if anyone's had it performed yet & if it helps at all. (http://www.tacomaworld.com/forum/2nd-gen-tacomas/96634-steering-column-rattle-tsb.html)
    It has improved a lot since I modded the rag joint, but it still could be better. (http://www.tacomaworld.com/forum/2nd-gen-tacomas/96634-steering-column-rattle-tsb.html)
    I'm planning to do an improved rag joint mod today. I'll post the details if it helps.
  9. Jun 13, 2010 at 8:41 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I have the same vehicle with 2k miles, except in Access Cab flavor. And I have the same Issue. Highway driving @ 65mph+, constant correcting left, then right, then left, seems like every few seconds. Tired after 10 miles. Brought to Dealer for that, plus Shudder, Tranny Hesitation, Leaf Springs/Harsh Ride. Both Service Tech and Service Mgr. Test drove it. Both put the truck on the "Crown of the Highway" and let for of the wheel. Damned if the truck didn't go Straight as an Arrow !!!. They found no problem with the steering. They also found no abnormal shudder, but I could feel it every time they accelerated. I Did get the Tranny TSB, and the Leaf Spring TSB done. The Spring TSB included a Post-Spring Install Alignment. I got the Printout. Alignment was perfect before and after.
    I attribute MY truck's wandering (Drifting) to a couple things.
    1) My 1st 4WD
    2) Maybe a little slop in the steering
    3) Maybe holding the wheel to tight, anticipating the wandering
    I don't seem to notice it that much any more or I'm not driving on the highway that much.
    Try letting go of the wheel on the Flat or on the Crown to see what happens, if you haven't yet. If it Wanders badly, get it aligned
    I posted the same question a while ago and really didn't get much response or a resolution
    Good Luck with it
  10. Jun 13, 2010 at 8:45 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Same requirements I look for in women! Score!
  11. Jun 13, 2010 at 8:45 AM
    grist
    Kevin
    Northeast Pa
    I had a 2008 frontier that held itself in one spot while on the highway. The taco drifts right or left without wind. If you take your eyes of the road for a second sometimes your in for a surprise.
  12. Jun 13, 2010 at 1:48 PM
    NelsonTacoma
    Tucson, AZ
    If you hit a curb, then there would be damage to the truck to show that. Otherwise warranty should cover it for 12,000 for adjustments. (I work at a dealership and have done MANY warranty alignments) I know not all dealerships will do it, but hey it's worth a try for a FREE alignment, right?
  13. Jun 13, 2010 at 2:03 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    My truck wanders too. Alot of this is caused by the ruts in the road from tire chains and studs where I live. On a freshly paved road my truck tracks straight as an arrow. On roads with ruts if I drive close to the center line the truck pulls to the left and if I drive close to the shoulder it tracks to the right. The truck did it before and after the lift, and after 3 alignments it still happens. I had the dealer drive it and they blamed it on the ruts. It does drive straight on good roads so I really think in my case it's a problem between the wide wheel base of the truck catching the ruts.
  14. Jun 13, 2010 at 3:04 PM
    jandrews
    "Some are worse about it than others"
  15. Jun 13, 2010 at 3:09 PM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    Yeppers!! :)
  16. Jun 13, 2010 at 10:21 PM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Well, my rag joint mod didn't happen. The rubber piece I wanted to use wasn't quite large enough.
    But I just did a high speed jaunt down the freeway yesterday, and I assure you that after the mods I did this truck wanders a lot less than before.
    Hopefully this new steering shaft TSB will straighten this out for people under warranty, but I'd sure like to come up with a good cheap fix for people whose warranty is expired.
    What I've done so far is cheap & it's a step in the right direction, but it is not enough.
  17. Jun 13, 2010 at 10:45 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    the grooves worn in the road. i bought my 08 -drove perfect out the box! lifted it 6in, aligned -perfect. no steering problems, no trans, suspension problems.
    its a truck not a cadi or bmw, drive it like one. otherwise just trade it if u dont like it.
  18. Jun 14, 2010 at 3:47 AM
    grist
    Kevin
    Northeast Pa
    This is my third Toyota truck and the most expensive so far. My wife has @ 4 runners and non of them wandered or drifted so much on the road. Drive it like a truck? Get real dude !!! This is 2010 not 1910 !!
  19. Jun 14, 2010 at 8:16 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Love it or leave it, eh? "Don't dare criticize what I bought," or bother to improve it...:puke:
    Look I've been driving over 40 years. Judging by the way you type, I suspect you're probably still a teenager. How the hell would you know if anything "drove perfect" or not? I've driven way over 100 different vehicles in my life. I say the new Tacomas steer like a lump of rubber!
    Also, I've been an engineer since 1975, I've examined the steering, and I know why they steer like a lump of rubber. When they jacked up the truck they put spacers in the rag joint instead of lengthening the steering shafts. It was a cost-savings measure, and it flopped. It steers straight as long as there's no side pressure on the tires, or side wind against the body. Once there is, the rag joint deflects & the steering "turns to rubber."
    They took a reasonable design, and modified it incorrectly, and now it's a failure.
    Now go back to your Playstation, and some day when you've driven 50 or 60 different trucks over a million miles of roads, come back and tell us us old farts how well something drives.
  20. Jun 14, 2010 at 8:37 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Hah. A grouchy old fart! 'At's a good thing...
