Road Force Balance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasr1950, Jul 9, 2009.
  1. Jul 9, 2009 at 6:39 PM
    thomasr1950
    thomasr1950 [OP] 16 Tacoma TRD Sport
    central us
    16 Tacoma TRD Sport
    I've got some vibration around 60 to 70 mph. The dealer has balanced my tires once & it helped. Now it is coming back but not as bad. I've got 4700 mi on my 09 dbl cab. Today after work when i got on the Interstate it felt like i had a flat spot on one or more tires. I've noticed this a few times before then it seems to go away. Will the dealer do a Road Force Balance on my tires & is it covered under warranty?
  2. Jul 9, 2009 at 11:43 PM
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    My 09 Dbl cab just had an alignment at the 5000 mile service. I told them that when they rotated the tires I had the same problem as you. They did the alignment a few days later and found that the factory alignment was off by .36. This only means one thing. That all Tacoma's built and aligned on that machine or however they do it was fed the wrong specs. And yes it is covered under warranty.
  3. Jul 10, 2009 at 12:09 AM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    I think the road force balance is not a balance but a test of variances in the tire strength. The tire machine uses this pad that is held against the tire and the machine gives it a quick spin. It's checking the sidewalls for evenness. Some All terrain tires always fail that test though. What tires are you running.
  4. Jul 10, 2009 at 9:21 AM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    I had vibes in my Tundra when I changed the stock tires out and put on Revo's. I ended up doing the Road Force Balance and absolutely loved it! It solved my issues and felt it was the best money I've spent on Tundra as the ride significantly improved. What RF does is simulate a load on the tire and find the odd spots and balance them out properly. I recommend it!
    Rob
  5. Jul 10, 2009 at 2:43 PM
    satchsd
    satchsd Old Guy Member
    keller texas
    had same problem on my 2009 first time at dealer didnt fix it second time they road force balanced them worked perfect didnt cost me anything
  6. Jul 10, 2009 at 2:54 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    r ne of u guys running on aftermarket rims and tires or stock wheels
  7. Jul 10, 2009 at 5:04 PM
    satchsd
    keller texas
    Stock for now
  8. Jul 10, 2009 at 7:38 PM
    thomasr1950
    central us
    16 Tacoma TRD Sport
    I have Bridgestone Dueler H/T's.
  9. Jul 11, 2009 at 9:10 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Stock rims, revo tires 265/75-16, love em! Check my photos to view.
    Rob
  10. Jul 12, 2009 at 7:47 AM
    general61
    general61 Nope.....I wasn't there........
    Ohio
    13 TRD Sport V6
    Hi
  11. Jul 12, 2009 at 8:21 AM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Do you believe this is worthwhile and money well spent? Is it he best form of balancing in your experience? Always interested in what operators have to say. Thanks in advance!
    Rob
  12. Jul 12, 2009 at 9:05 AM
    warriors_03
    warriors_03 Active Member
    Mark
    San Marcos
    2012 Tacoma DCLB Sport 4x4
    Also,
    If there is a really heavy spot, would you dismount the tire, turn it, say 90 degrees, and re mount it, hoping that you got a heavy spot on the tire and rim in the same spot before and that they have now moved?
    Thanks
    Mark
  13. Jul 12, 2009 at 9:23 AM
    general61
    Ohio
    13 TRD Sport V6
    Hi
  14. Jul 12, 2009 at 9:32 AM
    general61
    Ohio
    13 TRD Sport V6
    Hi
