Road noise coming from back seat
Discussion in '3rd Gen. Tacomas (2016-2023)' started by limited4x4, Dec 12, 2016.
  1. Dec 21, 2016 at 6:38 AM
    MitchK
    MitchK Well-Known Member
    16 TRD OR
    I put sound deadening mat on my back wall and it makes a huge difference.
    shakerhood likes this.
  2. Dec 21, 2016 at 9:02 AM
    limited4x4
    limited4x4 [OP] Member
    2016 tacoma limited
    I took my truck in to toyota and had the mechanic ride with me and he agreed that it was loud. They put some insulation and it helped a little. I think it needs more but I guess I will have to do it to make it right. Toyota is trying to make it right but for a $41000 truck it should have been quiet from the factory.
    Boghog1 likes this.
  3. Dec 23, 2016 at 7:42 PM
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    2020 TRD OR Premium-Auto
    I had / have the same issue and have do lots to reduce the road noise, took it to Toyota and they said, "what noise". Mine too sounds like the rear access cab door is partially open. I pulled the real bulkhead panel, had to remove the rear flip down seats to pull the wall. I dynomat'd the entire back wall and caulked around the vents and as above put a small bead on each of the rubber vent flaps. That helped a bit. Next I put a long piece of foam rubber pipe wrap across the bottom and top of the bed between the bed and the cab body. Again, a bit of improvement. Then I pulled out the rear storage compartment behind the seats, dynomat'd the floor area very well and then, get this, sprayed foam insulation in the corners closest to the doors where there is a huge void on either side of each lower door area. Let that dry for two days with the windows partially open. The last effort made a huge improvement. It's still noisier that it should be but much improved. And you cant seal off the rear bulkhead vents all together without having serious issues with airbag deployment and overall cab circulation. No question Toyota sucks when it comes to Tacoma cab noise management compared to GM/Chevy. Next spring I'll pull the access cab door trims and insulate inside the doors.
    RichVT likes this.
  4. Dec 26, 2016 at 10:50 PM
    2017TACOPRO
    2017TACOPRO Well-Known Member
    Billy
    Delaware
    White 2017 Tacoma TRD PRO TACO
    TRD exterior cab badges, 3D TACOMA tailgate emblems, Weather Tech trailer hitch step / bumper guard.
    Thanks for the information sure with you would ave taken or posted pics of all of your work for us. It's definitely a problem and your local dealer most likely won't attempt to fix it. The will just tell you they can't hear anything or it's a truck, deal with it!
    I would love to add insulation and/or sound deadening material but I really don't want to tear out my seats and carpet. Wonder if placing more insulation behind the rear seats along with dynamat would help? I would like to get access to a decibel meter and gauge what the sound difference is so you can see how many decibels you have dropped after your work.
  5. Dec 28, 2016 at 6:08 AM
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    I personally don't think you need to remove the seats and carpet although I have heard a couple guys pulled their head liners and insulated up there. For me the majority of the noise is isolated to the rear bulkhead and access door areas. In the spring, it's full blown winter here, I plan on removing the access door interior panels and dynomating and insulating as my last attempt to eliminate road noise. Best of luck all. It certainly is a big issue with the Taco and as a first time owner (have had lots of access cabs from other OEM's) I'm really disappointed. And yes, I know it's a truck but it's loud as hell inside at highway speed.
  6. Dec 28, 2016 at 6:14 AM
    panda_taco
    panda_taco Well-Known Member
    SWFL
    '16 TRD Off-Road 4x4
    The rear diff howl is super faint, but anyone with an ear for that kind of stuff will pick it up - I've learned to live with it.
  7. Dec 31, 2017 at 3:16 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    This noise was in my 2nd Gen as well. I used some dynamat and mass loaded vinyl sound proofing material and put it on the back wall of the truck. I also dynamatted the rear doors and floor area underneath the rear seats. It made a pretty big difference. I personally wouldn't touch the vents. The soundproofing in conjunction with using the recirculate button should reduce the noise substantially.
  8. Dec 31, 2017 at 3:30 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I completely covered the rear panel wall with mass loaded vinyl. Day and night difference, completely eliminated the wind rush sound from the rear of the cab. Unfortunately it makes the coarse engine tone more noticeable. It did reduce the exhaust tone at idle and low speeds which is what I was looking for.
  9. May 2, 2018 at 2:08 PM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    Same problem here so I pulled everything out off the back wall area. I'm going to sound deaden everything including under the carpet. I've already done the insides of back doors but after reading this thread I'm going to leave the vents to the outside open. I sure don't want to create problems with air bag deploy.
    I have a 2016 4Runner Limited that is as quiet as a church mouse. That's what I'm looking for.
  10. May 2, 2018 at 2:19 PM
    mr smolow
    mr smolow Active Member
    Mesa, AZ
    2018 Silver TRD Off Road Access Cab
  11. May 2, 2018 at 3:10 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    I put sound deadening on back wall and on floor of rear seats. Take seats out, peal back carpet and apply. Fixed the issue for me
    Tocamo likes this.
  12. Jan 18, 2019 at 8:27 AM
    ArkBadBob
    ArkBadBob New Member
    2017 Tacoma Limited
    The vents on the cab rear bulkhead are for emergency venting upon airbag deployment. Should you seal these up you may be bleeding from your ears if the air bags deploy.
  13. Jan 18, 2019 at 8:30 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    For $41,000 you should have test drove it more. :stirthepot:
  14. Jan 18, 2019 at 9:39 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    His last post was over 2 years ago... I don't think he's coming back.
  15. Jan 18, 2019 at 10:36 AM
    #35
    Trouble_The_Tacoma
    Conrad
    Probably switched to ridgeline
  16. Jan 18, 2019 at 10:37 AM
    #36
    Comb
    Comb Known Member
    Possibly. Hopefully he test drove it first.
  17. Jan 18, 2019 at 10:41 AM
    #37
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'll take Toyota's problems over a Colorado's problems any day..... :bucket:
  18. Jan 18, 2019 at 10:51 AM
    #38
    Trouble_The_Tacoma
    Conrad
    “I tEST dRoVe tHe RidGeLiNe. It WaS tOo QuIeT.”
  19. Jan 18, 2019 at 10:56 AM
    #39
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    3rd Gen essentially has the problems of 2 vehicles
