Road Noise in Stock 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HelloMyNameIs, Nov 29, 2018.
  1. Nov 29, 2018 at 8:07 AM
    HelloMyNameIs
    HelloMyNameIs [OP] I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I have had my '18 DCLB Off Road since September and took it back to the dealership once to fix a whistling noise that ended up being an improperly sealed window. I can't really recall if it was present before that, but the road noise on the drivers side is becoming an annoyance of mine. If it was there when I test drove the truck or the first few weeks of ownership, then I can't recall it. When I am driving and a car passes me on the left it literally sounds like the window is cracked open or the door is not shut all the way, but neither of those is the case.
    So I'd like a consensus; is this the case for everyone? I am half temped to test drive another just to see if it is the same there. How is road noise for your stock trucks?
  2. Nov 29, 2018 at 8:24 AM
    tlp.wc
    tlp.wc WC Member
    California
    2018 DCLB SR5 SW
    Mine is very quiet (18' SR5 DCLB) on the freeway and inside roads. When I drove my cousin's '16 I did notice a difference between road noise from mine to his which you explained.
  3. Nov 29, 2018 at 8:35 AM
    phsycle
    phsycle Well-Known Member
    CA
    Nope. Road noise is best out of any gen Tacoma. Maybe check your seals. Make sure the door alignment is good.
    shakerhood likes this.
  4. Nov 29, 2018 at 8:42 AM
    OnePuttBlunder
    OnePuttBlunder Well-Known Member
    AZ
    2018 TRD Offroad DCSB Premium +GFC
    I have a slight whistle in the drivers side. It gets much worse at 70+ not a massive annoyance something I will have addressed at my 5k service in January. Road noise not really an issue even with beefier tires on
  5. Nov 29, 2018 at 8:50 AM
    HelloMyNameIs
    Thanks guys, this tells me that it is definitely something I should expect to not be dealing with and will have it addressed.
  6. Nov 29, 2018 at 9:02 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Super quiet in my 2018 DCLB Off Road.
  7. Nov 29, 2018 at 4:25 PM
    Sgrif513
    Sgrif513 Well-Known Member
    2019 Cement TRD Sport DCSB
    My double cab short bed has been quiet since I got it 2 months ago. This is on side roads or the freeway.
  8. Nov 29, 2018 at 7:16 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Another vote for quiet here. I even have a Prinsu and think it's quiet. Maybe test drive another taco to compare.
  9. Nov 29, 2018 at 7:27 PM
    perryp
    perryp Well-Known Member
    Perry
    Great White North
    2013 TRD Off Road
    Its probably just a misaligned door ( lock mechanism) not set tight enough.
    Gorilla test= close the suspect door with about 10 sheets of newspaper...you get the picture..
    and test drive. noise gone?...door not properly sealed or not set tight enough.
