Road Noise Just Started
Discussion in '2nd Gen. Tacomas (2005-2015)' started by texastacoboy, Jun 4, 2011.
  1. Jun 4, 2011 at 1:28 PM
    texastacoboy
    texastacoboy [OP] Member
    I have an '07 Taco with 90,000 miles on it that I bought new. I've never noticed any road noise until about 3,000 miles ago. I've been running BFG T/A's, but just switched today to Grabber AT2's. I've searched thru the forum and couldn't seem to find this exact question. Does anyone know why the road noise would be more apparent now? I believe it's comming from the tires as the noise increases as the speed goes up. Any help would be greatly appreciated. Thanks.
  2. Jun 4, 2011 at 1:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Quite a few guys on here have had to replace their front hub bearings before the 100K mark. That may be what you are hearing.
  3. Jun 4, 2011 at 1:47 PM
    texastacoboy
    Would the hub beaarings go out all of a sudden?
  4. Jun 4, 2011 at 2:15 PM
    hedz0r
    hedz0r Member
    yup i also think it could be a hub bearing.
    can you tell what corner the noise is coming from?
  5. Jun 6, 2011 at 8:54 AM
    texastacoboy
    Not sure what corner the noise is comming from. I have the dealership looking at it now. I'll update when the dealer tells me his B.S.
  6. Jun 6, 2011 at 8:56 AM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    My AT2's are very quiet so I doubt its the tires.
  7. Jun 6, 2011 at 8:59 AM
    texastacoboy
    I'm sure now that it's not the tires, but i thought that if my bearings are going out, the noise or vibration would change. For example, going around corners. The only time the noise / vibration changes is when the speed changes.
  8. Jun 6, 2011 at 9:07 AM
    Norcan
    Norcan What we don't have we make.
    Jerry
    Elora, ON Canada
    11 Tacoma Double Cab TRD
    Bakflip F1, BakBox, Sportwing Colour matched door mouldings, Weathertech floor liners, Toyota running boards,Toyota Hood Deflector,Pop N Lock power tailgate lock, Custom Otterbox defender mount for IPhone 4, Blu Logic Large button kit, BonGiovi DPS, fog light on with parking light low beam and high beam mod, TRD Exhaust, Muth heated signal mirrors, Liquid Metal Rhino Wheels in Black!, Redline Elite hoodlifts, EZ down tailgate,
    Sounds like a wheel bearing to me. They can be very loud when they go.
  9. Jun 6, 2011 at 9:16 AM
    texastacoboy
    Just spoke with the dealer. My front left bearing is going out. If it's just the bearing, it will be 4 hours in labor and $662.00. He's not sure if the bearing froze to the hub...if that's the case, I'm looking at $878.00.
    CRAP!
  10. Jun 6, 2011 at 9:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ay Caramba :eek:
    My driver side is going too and I am at $38 k miles so they sure a crap.
    Glad I dont have to pay for the change will do it myself.
    BTW ask them if new bearings are Koyo. When I am changing my wheel bearing, I am going with Koyo pack from NAPA. They should last little longer.
  11. Jun 6, 2011 at 9:37 AM
    hedz0r
    hedz0r Member
    holy christ! im glad my truck is still under warranty..
