Road trip Gremlins - PLEASE HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OcoeeG, Dec 21, 2022.
  1. Dec 21, 2022 at 5:26 AM
    OcoeeG
    OcoeeG [OP] Member
    08 Tacoma SR5 Double cab long bed
    Aftermarket Exhaust, add a leaf, K&N air filter,
    So great to have a community like this to bounce things off of. Please excuse the long post.
    I have a 2008 Tacoma V6 DCLB 4x4 with 170,000 miles.
    2 months ago we were going camping and the battery light came on I knew it had to be something to do with the alternator. I giggled the green plug that goes into the side of the alternator and the light went out and the engine noise changed a bit which I assumed was the alternator coming back under load. The light didn't come on again until last night as we were driving to my parents house for the holidays.
    So we were driving down the interstate and the battery light flickered, and then flickered more and then stayed solid. I pulled over giggled the green plug and the light went out and the engine noise pitch changed. Good to go! Back on the road, or so I thought. It seemed like every 10 mile the light would come on and would then go off when I giggled. Soon it was every 5 miles and the giggle turned into a smart rap with the flashlight on the back of the alternator by the voltage regulator. This carried on for 100 miles and at least 15 or 20 giggle/rap/tap stops. I had no choice, it was 11:00 PM in the middle of nowhere. We made our predetermined hotel stop by the hair on our chinny chin chin.
    Here is the funny thing. We would have to drive numerous miles with the light on because the wife would not let me pull over on the side of the interstate, which I understand. The longest stretches being 5-10 miles with the lights, and heater on and the truck never faltered. Our home stretch into the hotel might have been 10 miles. But the truck started fine in the morning. I was surprised.
    I went to Orieley bought an alternator. Before I put it in I stopped at a local auto repair shop and talked to the guy and got some advice. We were able to get the light to go out and measured the charged voltage and it read 14.2V, when the battery light was on the voltage still read 13.8, which is still pretty good. He convinced me that it would probably be fine. So we rolled the dice and went for it. We drove with the light on for about 125 mile, including a couple rest area bathroom breaks no issues. Then about 115 miles into the trip random lights came on, cruise stopped working and the truck started to falter and stranded us on the side of the interstate. SHIT!
    Got it towed to a mechanic to put the alternator that I should have put on it in the first place. Here is the crappy thing. The guy changed the alternator but he said the battery light is still on and it is now only charging at 13.5 volts. Not very confidence inspiring considering this is worse than the situation that stranded us on the side of the interstate and cost me a $400 tow bill.
    Help!
  2. Dec 21, 2022 at 5:33 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Did the garage load test the battery?
    Auto parts stores sells replacement alternator wiring plug, if needed.
  3. Dec 21, 2022 at 5:34 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Sounds like a loose connection to me. I'd pull the plug, look for worn pins or corrosion, and clean appropriately.
    And while under there, do a cursory inspection of the wiring for abnormal abrasion or wear.
    Bivouac and Steves104x4 like this.
  4. Dec 21, 2022 at 8:16 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah its probably a bad connection at that 4 pin plug. Have a look. PULL THE PINS PROPERLY and gently push out the spring tab. Clean it up apply a lil dielectric grease.
    TreeFortRichard and Steves104x4 like this.
  5. Dec 21, 2022 at 8:19 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m sorry op. Good luck!
  6. Dec 21, 2022 at 9:31 AM
    OcoeeG
    OcoeeG [OP] Member
    Nope, they only sell them online.
    Venom[QUOTED] likes this.
  7. Dec 21, 2022 at 9:32 AM
    OcoeeG
    OcoeeG [OP] Member
    Thanks! Stressful to say the least.
  8. Dec 21, 2022 at 1:34 PM
    OcoeeG
    OcoeeG [OP] Member
    UPDATE
    Only paid$243 to get the alternator put on which isn't bad. Better than doing it myself for the first time, in the freezing cold with my barely adequate travel tool kit.
    The battery light is still on, but it doesn't sound like a huge deal as long as it is charging in the 13.5 to 14V range which it is, even with a bunch of accessories on full blast. I drove 55 minutes from the shop, and the battery is still fully charged. Mind you, I didn't run any accessories on the way to my destination just to make sure I got there. I feel pretty good about it, I really have no choice at this point. I bought a NOCO jumper box and a new battery, just in case. I willl probably return the battery when we finish our 10 hour road trip after Christmas. The battery in the truck is a red top, and tests just fine.
    I will dig into the battery light issue when I get home as there's lots of good info on here and the internet.
    Thanks everyone for the help.
    TreeFortRichard likes this.
  9. Dec 21, 2022 at 1:45 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Mmm, I don’t think you can return batteries but glad to hear you’re rolling
  10. Dec 21, 2022 at 1:59 PM
    OcoeeG
    OcoeeG [OP] Member
    Even completely unused, with the red cap still on it? It says nothing on the receipt about no returns.
  11. Dec 21, 2022 at 2:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Returning it at the same store and not used within… let’s say 72 hours, maybe but I was told no. I now have 5 batteries charged up at my house
  12. Dec 21, 2022 at 2:46 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You do understand with the light being on you have no idea if things fail again .
    You will find yourself along the side of the road again.
    Once the System Voltage falls below the thresh hold voltage the ECM shuts down.
    You still have not fixed the problem.
    Worse case get a Volt meter and wire it in to give you a warning to find shelter.
    Best of Luck
    Dm93 likes this.
  13. Dec 21, 2022 at 4:03 PM
    OcoeeG
    OcoeeG [OP] Member
    You could be right. But if you search for "tacoma battery light" on Tacomaworld you will read about many examples of people who drive around with
    the light on for extended periods of time without issue.
    I hope I am in that group of people, at least until I can get home from this road trip. I am gonna dig in a bit deeper tomorrow to see if I can get that light off.
    Great idea on the voltmeter.
  14. Dec 21, 2022 at 4:11 PM
    Bivouac
    Lots of clueless people as well
    Not having any idea where you might be it might not be a big deal.
    But a night in the truck at-50 F in West Yellowstone Montana I never take chances.
    goforbroke123 likes this.
  15. Dec 21, 2022 at 4:20 PM
    Venom
    Kevin
    Massachusetts
    I don't know how accurate these are but it's easy to install.
  16. Dec 21, 2022 at 4:22 PM
    Bivouac
    Better then nothing If OP can find one where they are at.
    OcoeeG[OP] and Venom[QUOTED] like this.
  17. Dec 21, 2022 at 4:22 PM
    Venom
    Kevin
    Massachusetts
    We have a private owned part store that carry the alternator plug, in stock. It's quite popular item.
  18. Dec 21, 2022 at 4:25 PM
    Venom
    Kevin
    Massachusetts
    Here, Autozone used to carry them in store. I haven't been to Autozone in years. Since there's 5 autopart stores right next to each other.
  19. Dec 21, 2022 at 4:28 PM
    OcoeeG
    OcoeeG [OP] Member
    I live in Tennessee, so yeah not as big of a deal. But still very inconvenient.
    I kind of misread your message. Yes , I agree the battery light being on, no matter how innocuous, is far from ideal. You have no idea if you are having an issue until it is too late. I will be trying to get it to go out asap and I am going to get a volt gauge. Some very easy solutions for voltage gauges.
    Just ordered a volt gauge on Amazon.
    I found the plug online, but it doesn't help me now.
    Bivouac likes this.
  20. Dec 22, 2022 at 1:36 PM
    OcoeeG
    OcoeeG [OP] Member
    OK, got a one of thosecig lighter adapters with the voltage gauge and a NOCO 1000A jumper at Autozone. Gauge is showing 12.3V off and
    14.1 when driving. Feel OK about that.
    Lady at Autozone said can take that battery to any Autozone in the world and return it if I want! So I am going to hold onto it until I get home to be on the safe side.
    Thanks for the help everyone.
    Venom and Steves104x4[QUOTED] like this.
