Road trip Gremlins - PLEASE HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OcoeeG, Dec 21, 2022.
  1. Dec 22, 2022 at 1:53 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just a word of warning about O'Reilly alternators. They're not noted for their quality. I've seen a number of them DOA right out of the box. Get your entire charging system checked.
    OcoeeG[OP] likes this.
  2. Dec 22, 2022 at 3:28 PM
    OcoeeG
    OcoeeG [OP] Member
    08 Tacoma SR5 Double cab long bed
    Aftermarket Exhaust, add a leaf, K&N air filter,
    Thanks for that knowledge! I will be getting it thoughoughly checked.
    I have the old alternator, if it is OEM should I keep it and get it rebult as a spare?
    Steves104x4 likes this.
  3. Dec 22, 2022 at 3:40 PM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    This is copy and paste from the web.
    At 12.4 volts the battery is considered 75% charged and can still ignite your engine. When the battery voltage lowers to 12.2 volts without the engine running, it is considered a bad battery that may start your engine but is no longer capable of holding a charge.
    Good idea to hold to the battery.
  4. Dec 22, 2022 at 3:41 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I sure would if you have a local auto electric shop. Do it yourself for the learning experience if there is anything wrong.
    I feel better knowing you can keep an eye on things.
    Have a good visit and safe trip home.
    OcoeeG[QUOTED][OP] likes this.
  5. Dec 22, 2022 at 4:16 PM
    Too Stroked
    Tom
    The problem with rebuilt / remanufactured components is that they're only as good as the process that's used to rebuild / remanufacture them - which is rarely as good as the process used to originally build them. (If you think most rebuilders are using factory parts, you'd be very wrong.) While I trust a Toyota remanufactured part - only sold through Toyota dealers - I don't trust most parts store remanufactured stuff.
    So, should you get your original alternator rebuilt? I'd recommend that you get a Toyota remanufactured unit and use yours as the core.
  6. Dec 22, 2022 at 4:23 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    +1 on the grease...I use that stuff anytime I unplug anything
