Road Trip Tire Pressure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatal_Paradox, Sep 4, 2018.
  1. Sep 10, 2018 at 2:20 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    35 cold all the way around. Check the spare tire too.
  2. Sep 10, 2018 at 2:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do the chalk test as you will be loaded for travel, on cold tires. The answer isn't really 'front vs rear', the answer is about the most even contact patch. Odds are you may wind up with a few more lbs in the rear if you have the rear loaded up.
    Whatever you wind up with for your highest pressure, put 5 more Lbs in your spare. If you need it, it's easier to lower the pressure for the particular axle than worry about raising it somewhere after a change.
    Regardless of the anecdotal evidence offered here, the advice is poor. Don't do it. Google will find you lots of info on the topic. Here's a sample.
    https://info.kaltire.com/the-right-tire-pressure-why-the-maximum-isnt-the-best/
    Screw up the contact patch with the wrong pressure and you give away grip, the thing that creates the most safety a tire can offer.
  3. Sep 10, 2018 at 2:49 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    35 on all 4 is a good compromise between ride, wear, and mileage.
  4. Sep 10, 2018 at 3:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That just means you have E load tires. That's the MAX you should run if you're loaded down to the max weight of the tires (which a tacoma can't handle anyway, lol)
    I've put 100+ thousand miles on E load tires at 30-35 psi with no adverse tire wear.
    FLBAdrian[QUOTED] likes this.
  5. Sep 10, 2018 at 4:15 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I know two methods of calculating the optimal tire pressure:
    1. charcoal = empirical. Takes some time but does not require special tools or knowledge
    2. Door sticker + calculation. Door sticker gives the vehicle weight, tire type and pressure. From that you can easy calculate the load factor. Knowing the load factor of the new tire (tire max allowed load and tire max allowed pressure) you can easy recalculate the pressure for the trie different than what is on the door sticker.
    I am to lazy to use charcoal method, so I use calculation. When I switched from P-type stock size Michelin 235x75/R15 to LT-type KO2 30x9.5/R15 (the biggest I could fit on my 15x6 rims) I calculated the KO2 pressure at 30psi front (Michelin was 26psi) and 33psi on rear (Michelin was 29psi). That is with my normal weight. Calculation shows that for fully loaded truck at maximum gross weight I should go for 33psi front and 35psi rear. All from excel spreadsheet :)
  6. Sep 10, 2018 at 5:46 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Thank you
  7. Sep 11, 2018 at 2:06 AM
    RysiuM
    Rysiu
    I don't have much experience with different brand of tires but KO2. For the same size KO2 there is not much difference in operating pressure for 4Runner between E and C. E tire can be inflated to higher pressure and therefore can take more load but for the same load the calculated pressure is the same. E has benefit of being stronger so it takes rocks better but also stiffer so less comfort on highway.
  8. Sep 11, 2018 at 5:52 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I run 35 psi all the time. The tire shop filled em to 55 psi one time. The brakes felt super weird as there wasnt as much road contact, I cant imagine going any higher.
