Road vibrations felt in steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacocowboy, May 16, 2012.
  1. May 16, 2012 at 4:19 AM
    tacocowboy
    tacocowboy [OP] Well-Known Member
    Texas
    Prerunner grey and naked
    I took my truck to the dealer for a high speed vibration of the steering wheel. They think I have a bad tire up front. Had it checked, not so. Steering rack ap:confused:pears tight. Any thoughts?
  2. May 16, 2012 at 4:44 AM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    When you had the tire checked, did they do a road force balance on it?
  3. May 16, 2012 at 5:35 AM
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    I have the same problem periodically. I take it Discount Tire because that is where I bought my rims. They do some kind of balancing and it removes it every time.
  4. May 16, 2012 at 6:10 AM
    tacocowboy
    Texas
    Yes they did the roadforce balance. And my hubs are still good.
  5. May 16, 2012 at 7:07 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Sub'd...
    I've had steering wheel vibration ever since getting my new wheels/tires. I've had them balanced several times. I'm trying Road Force Balance next week. If that doesn't work, I'll be checking in to see if other solutions pop up in this thread.
    Good luck to the OP.
  6. May 16, 2012 at 2:49 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Road Force Balance.....I'm going to have to remember this. I've got it too and feel as if it's an easy fix. I'm going to try and get this done on Friday :D
  7. May 16, 2012 at 2:49 PM
    ItalynStylion
    Steven
    DFW, Tx.
    What's different about it vs and normal mount and balance?
  8. May 16, 2012 at 4:45 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Road for balance can check for broken belt, separated tire, heavy spot in tire. Basically if there is a defect in the tire it will notice it.
    It also tells you where to specifically rotate the tire once it is on the wheel. It places the heavy section of a tire opposite the lightest spot in on the wheel so they counter each other so less weights are needed.
    It works by actually placing about a 15" wide x 12" diameter roller against the tire to simulate the road. They charge more for this. Typically is not needed with a quality wheel and tire but when you get into so 32" plus tire sizes and wide widths it is a option to think about.
    Pics in link
    http://www.evsmotors.com/hunter-gsp9700-road-balancing-in-houston-tx-by-evs-motors/
    Typically shops just slap wheels and tires on vehicles with piss poor balancing. There is variations on how you can do it. Dynamic or static.
    Also when choosing aftermarket wheels please check hub bore to match to stock or use hub rings as needed. Conical lugs do squat if the bore is larger than stock. Same goes with wheel spacers they must be hub centric.
    All vehicles are the same way it is typically pronounced on vehicles with larger diameter tires since it amplifies the defect or improper setup.
  9. May 16, 2012 at 6:51 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Discount tire near me said they'd do it for $40. Just called them. Hoping to get it done soon.
  10. May 16, 2012 at 8:58 PM
    mws4ua
    Birmingham
    The place where I bought my tires (and where I have lifetime rotate/balance) said they'd do it for free since they can't seem to get rid of the vibration after having the tires balanced several times. Maybe it'll fix it, maybe not.
    I've also purchased all of the parts I need from this guy's fix. That damn shake will go away one way or another.
