Roadside help needed!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigSkyTRD, May 3, 2017.
  1. May 3, 2017 at 8:11 PM
    BigSkyTRD
    BigSkyTRD [OP] Active Member
    Bozeman, MT
    '17 TRDOR DCSB QS
    Hey all,
    I've been pulling an Rpod trailer for ~500 miles with my '17 TRDOR and I just arrived in Park City, UT. Unhitched and went to the store and am hearing grinding/groaning noise from the left rear wheel. It is definitely speed dependent. Lifted that wheel clear of the ground and spun it by hand, no noise heard. It has gotten progressively worse in the last 20 miles. Any thoughts or ideas would be greatly appreciated!
  2. May 3, 2017 at 8:14 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Wonder if your drum brakes fell apart inside the drum. That would suck. Check to make sure no plastic or anything is stuck under there.
    George1441 likes this.
  3. May 3, 2017 at 8:33 PM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    Thanks Smitty. I thought the same but braking is all good, and there's no noise when the wheel is spinning freely in the air or additional noise when braking. I am stumped!
  4. May 3, 2017 at 8:35 PM
    Joe D
    Joe D .
    Bump for home page vis
  5. May 3, 2017 at 8:36 PM
    smitty99
    Scottsdale
    If you need in-person help might be some guys in the Utah Section (Nevermind there is no Utah Section??) that can get to you....
  6. May 3, 2017 at 8:36 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Feel around on each hub and the rear. If it's grinding something will be hotter than everything else.
    TacoFister likes this.
  7. May 3, 2017 at 8:38 PM
    smitty99
    Scottsdale
  8. May 3, 2017 at 8:46 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Bearing failing at speed under a tow load. Get it replaced. No more towing!
    Check with a long skinny metal rod and use it like a stethoscope up against the rear drum backing plate near the bearing, while placing the other end of the rod on your ear.
    Maybe the jack tools are handy? Jack the rear end up again if you can (chock the front wheels) and have someone spin the free wheel that's off the ground. You should hear a grinding noise similar to what you heard in the vehicle. The sound will amplify through the rod if the bearing is bad. This is how we would do a quick check on bad bearings when on a lift before.
  9. May 3, 2017 at 8:47 PM
    smitty99
    Scottsdale
    :bowdown::bowdown::bowdown:
  10. May 3, 2017 at 8:51 PM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    GP
    Thank you much. I can check that in the morning with the jack tools. What I didn't mention was that it is a once per revolution sound, not constant.
  11. May 3, 2017 at 8:56 PM
    GPsevinSixx
    Ros Angerus
    Then not likely a bearing. Bearing noise is constant. So you're describing a tick sound?
    I was trying to find a YouTube link for you on this redneck stethoscope method.
    Check this vid in case you're curious as to what I was talking about. Go to 0:40-1:20 mark to skip the annoying AF host.
    https://youtu.be/U927cYhQXB4
    Check your tires also!
    InfernoTonka likes this.
  12. May 3, 2017 at 8:56 PM
    smitty99
    Scottsdale
    Check when local Stealership opens
    You may have to get it towed to the other side of the mountains. Only Toyota Dealerships showing up on google are ~10 to 20 miles West of you it looks like.
    Larry H Miller Toyota
    Address: 5650 State St, Murray, UT 84107
    Hours:
    Closed now Phone: (801) 590-0640
    Call them first thing in AM. Usually the local dealerships here open by 700 or 730AM
  13. May 3, 2017 at 8:58 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    You have Toyota roadside assistance. Give em a call for a free Tow.
  14. May 3, 2017 at 8:58 PM
    Tdkrum5
    Tdkrum5 New TRD OR for me.
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    Did you say it was a 17 TRDOR? I would head straight to the Toyota dealer. Should be covered under the warranty I would hope.
    shakerhood, wilcam47 and InfernoTonka like this.
  15. May 3, 2017 at 9:00 PM
    smitty99
    Scottsdale
    May not be able to drive it. Probably have to get it towed if it's a bad bearing. He said it's making a lot of noise and getting louder. Of course you know the damn dealer will probably take a day or two to get it fixed. Hope OP wasn't planning on going anywhere for a few days. (Hopefully Park City was his final destination)
  16. May 3, 2017 at 9:02 PM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    Smitty, if you could post up for me I'd appreciate it. I'm in a campground using cellular and it's pretty slow.
  17. May 3, 2017 at 9:03 PM
    bluenv
    bluenv Well-Known Member
    It must be Utah. I had a similar thing happen outside of SLC two years ago. Turned out to be rear brake cylinder that was in the process of failing. My brake drum was literally red hot though, so you would know if it was that.
  18. May 3, 2017 at 9:03 PM
    protaxidermist
    protaxidermist Well-Known Member
    North Carolina
  19. May 3, 2017 at 9:04 PM
    smitty99
    Scottsdale
    What is your exact location, do you need someone to come help you?
  20. May 3, 2017 at 9:04 PM
    GPsevinSixx
    Ros Angerus
    Good luck bigskyTRD
    BigSkyTRD[OP] likes this.
