Roadside help needed!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigSkyTRD, May 3, 2017.
  1. May 3, 2017 at 9:05 PM
    BigSkyTRD
    BigSkyTRD [OP] Active Member
    Bozeman, MT
    '17 TRDOR DCSB QS
    I checked the temperature of both drums. It didn't seem that one was hotter than the other.
  2. May 3, 2017 at 9:08 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Posted a link to this thread in the Southwest forum. I tagged you in it.
    BigSkyTRD[OP] and GPsevinSixx like this.
  3. May 3, 2017 at 9:08 PM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    We are at a state park 10 miles east of Park city. I'm going to try to find a local shop in the morning to see about getting a diagnosis, hoping to save a trip over the mountains to the dealer. Not sure if I should be driving this thing.
  4. May 3, 2017 at 9:09 PM
    smitty99
    Scottsdale
    Good Luck! Sorry I can't help much more from Phoenix.
  5. May 3, 2017 at 9:10 PM
    Glenn_R
    Glenn_R The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Made a post in the Utah thread.
  6. May 3, 2017 at 9:11 PM
    toyguyic
    toyguyic Well-Known Member
    kdog
    Iowa City, IA
    2017 Tacoma Limited White
    TRD Pro Grill, Lo Pro QT, Morimoto HID
    Probably have it already but here's roadside number. (800) 444-4195
  7. May 3, 2017 at 9:15 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Just updated my post (#11) previously. Forgot to add the link for the redneck stethoscope method in case you decide to try. Be careful when under there while vehicle is unsupported by jack stands!
    BigSkyTRD[OP] likes this.
  8. May 3, 2017 at 9:16 PM
    bluenv
    bluenv Well-Known Member
    That is the smart move. I've found the shops and the Toyota dealer were extremely helpful when they know you are traveling.
    Mercer Automotive gets good reviews from travelers on Yelp
    1155 Iron Horse Dr
    Park City, UT 84060
    BigSkyTRD[QUOTED][OP] likes this.
  9. May 3, 2017 at 11:43 PM
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    My initial guess would be bearing (as it was said before). They take some time to fix. I would take it to Larry H. Miller and have it looked at. Unfortunately through that mountain pass. Try giving Karl Malone a call. They are a network of dealers and they might be able to help. There is a Karl Malone Toyota on the other side but also a Karl Malone Jeep Dodge Ram dealership in Heber City. Easier drive than going through the canyon pass. I'm actually taking my tacoma in tomorrow for service so I can't be of much help. Sorry OP. Best of luck!
  10. May 4, 2017 at 12:11 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Good luck at Larry miller next day. That's my dealer. :(
  11. May 4, 2017 at 5:24 AM
    BCSpazer
    BCSpazer Well-Known Member
    2020 Tundra TSS Off Road
    Free bump - and in for the cause of the noise :D
  12. May 4, 2017 at 5:49 AM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    Thanks to everyone for the assistance. Overnight I thought about a defective tire, going to swap on the spare and see if that helps. I'm hoping for a simple solution.
    Would a bad bearing be silent when the wheel is spinning freely in the air?
    Well, in hoping for a simple solution I got one. Went to take off the left rear wheel and most of the lugs were loose. Yes, I'm a bonehead, but I wouldn't expect that from a truck with 1800 miles. I know for a fact that there could've been an epic failure while driving and or pulling our trailer. I'm grateful that a crisis was averted and grateful for all the help from those on this forum. Thanks again!
  13. May 4, 2017 at 7:52 AM
    smitty99
    Scottsdale
    So the dealer didn't PDI your truck? Wonder why lugs were loose
    Garrett75x, Joe D and George1441 like this.
  14. May 4, 2017 at 7:56 AM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    Smitty
    I'm wondering the same thing. They are definitely going to hear for me when we get back!
  15. May 4, 2017 at 7:57 AM
    #35
    smitty99
    Scottsdale
    Have you run your VIN for the Rear Diff Recall? Have you inspected your Rear Diff for leaks. Watch the dealer hold your truck now.... :facepalm::laughing:
    George1441 likes this.
  16. May 4, 2017 at 7:57 AM
    #36
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    someone trying to steal tires and got interrupted...
    Plain Jane Taco likes this.
  17. May 4, 2017 at 8:19 AM
    #37
    steveoh
    steveoh Well-Known Member
    SLC
    08 ACLB SR5 4x4
    Yes, loose lug nuts will give you a high pitch squeak on a revolution. If you turn the car to one side or the other (effectively pulling and pushing the wheel on the posts) the squeak will stop in one direction.
    You will probably break all your posts and lose your wheel if you don't tighten them up soon.
  18. May 4, 2017 at 8:24 AM
    #38
    GPsevinSixx
    Ros Angerus
    That was easy! Glad it all worked out and an easy solution was found.
  19. May 4, 2017 at 10:03 AM
    #39
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    I just read this thread from beginning to end. I was pretty worried. I'm really glad it all worked out. Thank's for posting the root cause. I will be making a mental note.
  20. May 4, 2017 at 12:44 PM
    #40
    Sand_taco
    Sand_taco Well-Known Member
    2016 quicksand Trd off road
    They have to do a pdi (remove all of the plastic and such) and they wont check that all of the lugs are torqued to spec, they might at most install wheel locks
