Roar after maf cleaner in intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotabra, Apr 8, 2023.
  1. Apr 8, 2023 at 11:49 AM
    yotabra
    yotabra [OP] Member
    98 Tacoma white
    I recently sprayed some mass air flow cleaner in my intake and now my engine is really loud it sort of roars and doesn’t idle so well. I know I have a below recommended psi in my 3rd cylinder. Is this ok or is there an easy fix to this?
  2. Apr 8, 2023 at 11:58 AM
    eon_blue
    Azusa, CA
    You sprayed it into the intake? Supposed to remove the sensor, spray it directly and let it dry before reinstalling. I don't think MAF cleaner is meant to be used directly into the intake like Seafoam or the like.
    s92dvr likes this.
  3. Apr 8, 2023 at 1:27 PM
    yotabra
    yotabra [OP] Member
    98 Tacoma white
    Yeah I sprayed a couple quick blasts into into the intake after removing it from the filter box. I didn’t unplug the wire bundle but I did wait a few minutes for the spray to evaporate before starting the engine.
  4. Apr 8, 2023 at 3:22 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Mine pops out. I squeeze blasted the filaments with 70% alcohol spray.
  5. Apr 8, 2023 at 8:54 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    It's not an intake spray. You spray it directly onto the sensor wire inside the MAF sensor. Nowhere else around the intake.
    That said, the symptom is much like that of a MAF sensor that needs to be cleaned that way. Or maybe the CPU needs time to cycle since you unplugged it? I eventually got a CEL after cleaning it, and it turned out the electrical contacts on the MAF sensor unit were corroded. I cleaned those with electrical cleaner and then it behaved good.
