roaring going down the road
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Feb 1, 2011.
  1. Feb 1, 2011 at 7:57 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    Guys I got a 2001 tacoma 4x4 with 165,000 and just replaced the tires thinking they were doing it but nope it's still there. The roaring will increase with the rpm's and decrease when you let off. Any suggestions on what it could be. I grease it myself once a year and never go off road. If there are some suggestions how can I find out if that is the problem. Thanks Rick
  2. Feb 1, 2011 at 8:11 AM
    HeadPin21
    HeadPin21 Member
    Alexandria, VA
    04 SR5 TRD Dbl Cab
    Rough Country 2.5"
    Possibly the drive shaft or wheel bearings???
  3. Feb 1, 2011 at 8:13 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Where does it sound like the roaring is coming from? Engine bay, tire area, underbody, etc...
  4. Feb 1, 2011 at 9:08 AM
    Ricky B
    Arkansas
    1998 XCAB
    sounds like its coming from the back underneath. I'm thinking driveshaft, but don't know and I hate to say this but how do you know? Rick
  5. Feb 1, 2011 at 9:18 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well is it going away with rpms or speed? try going down a hill and taking it out of gear to make sure it's not the trans. It dose sound like it might be the wheel bearings.
  6. Feb 1, 2011 at 7:20 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Does it sound like a fan type thing? This sounds dumb but could you have something wrapped around your driveshaft that's whipping around making noise?
  7. Feb 1, 2011 at 7:26 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    your truck is so badass it shows it by roaring as you accelerate
  8. Feb 1, 2011 at 9:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    With the engine turned off, open the hood and see if you can rotate the big cooling fan between the radiator and the engine. It should spin freely. If you can't easily spin the fan by hand, the fan clutch has failed.
    When the fan clutch fails you will hear a roaring sound as the engine RPMs increase. It will sound normal at idle.
  9. Feb 2, 2011 at 8:01 AM
    Ricky B
    Arkansas
    1998 XCAB
    Thanks for the replies. It's not the fan belt and thanks for the information. I start hearing it around 50mph and I started paying close attention to the noise and it's still there going down hills. Like I said you have to get over 50 to hear it from just road noise. Thanks Rick
