Roaring noise from front end on 05' DC 4x4 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aacomi, Jul 4, 2009.
  1. Jul 4, 2009 at 3:39 PM
    aacomi
    aacomi [OP] Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    Last week I noticed a roaring noise in my wife's 2005 4x4 DC taco. I have had new tires and alignment done. No slack in front front tires. Any Ideas of what might be causing this would be appreciated. It starts a winding type of roar when starting from a complete stop and gets louder as you increase speed until hwy noise takes over. It can only be heard inside the cab. Strange......Thanks for any info available......
  2. Jul 4, 2009 at 4:18 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Sounds like wheel bearings. Dunno....
  3. Jul 4, 2009 at 6:02 PM
    aacomi
    aacomi [OP] Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    My toy came with enkei rims that were on it new on the lot....could these have anything to do with a bad wheel bearing? I suspected the bearings, but then someone told me that it could be the cv..
  4. Jul 4, 2009 at 6:34 PM
    GoBlueFan
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    make sure your lugnuts are all tight. Could be CV as well. Does it change if you put it in 4WD?
  5. Jul 4, 2009 at 6:47 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    I've been dealing with this a bit on my Civic. Thought it was wheel bearings but it ended up being two lug nuts backed out and I was missing the spacers that go in.
    1. Check your lugs.
    2. See if your Enkeis have the spacers that go in the inside of the wheel hub like my civic. Mine wouldn't mount properly without them.
    3. Grab the tire/wheel and shake it in and out (not sure if this is what you meant by no slack)
    4. Jack it up, spin the wheel freely. If it rumbles and you can feel it, its more than likely the wheel bearing.
    5. If not wheel bearings, the last thing that spins is the CV axle, but I don't believe thats your source.
    How does it sound going around corners? CV's are prominent 'clicks'. Bearings are a 'rumble'. Most of this can be easily diagnosed at a slow speed. CV's you'll feel more on an acceleration, bearings more so on a deceleration.
    My $.10, I'd troubleshoot in that order. Or you can always just take it in on warranty.
    EDIT: I overlooked that you said you have new tires. This was my same scenario on the Civic. My tires just plainly roar, they're Proxes, and they're everybit as loud as my truck tires with are 33" KM2s! If you don't feel anything like I'm describing in here, its probably just the tires.
  6. Jul 5, 2009 at 7:28 AM
    aacomi
    aacomi [OP] Member
    Red Bay, Alabama
    2005 SR5 tacoma 4x4
    I have ruled out the cv due to no clicking, and the noise stays when locked in to four wheel drive as to unlocking it. This noise was present with other treads, so I changed tires. I will be changing the wheel bearings this week. Thanks for the replies.
  7. Aug 17, 2009 at 7:47 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Did new bearings fix your problem?
  8. Aug 17, 2009 at 7:52 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Help us out a bit:
    Does the sound change with engine speed -- or road speed??
    Did this just happen after the tires and alignment??
  9. Mar 31, 2011 at 6:31 PM
    curtis228
    curtis228 Member
    shane
    lburg
    2003 tacoma, 99 4runner, & 2002 duramax
    9 inch lift with 37s magnaflow exhaust and 5.29 gear
    i am having the same prob on my 2005 tacoma. the roaring does not change tones at all i just put new tires on and it did not fix it. did the wheel bearings fix the prob?
  10. Mar 31, 2011 at 7:44 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I vote wheel bearing.
  11. Jun 2, 2011 at 1:36 PM
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    So.. Any resolve on this? Was it the bearing? I am having the rumble now and feel thats what I am going to need.
  12. Jun 2, 2011 at 1:54 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    This thread is almost 2 years old, you might want to use the troubleshooting methods mentioned above to see what your issue is.
