Roaring Power Steering Pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by anvilhead, Aug 25, 2009.
  1. Aug 25, 2009 at 2:25 PM
    anvilhead
    anvilhead [OP] Active Member
    I have a 2001 toyota tacoma. The power steering pump roars when the truck is idling. I turn the wheel slightly and it stops. The fluid resevior is full. I have never had a leak or any problem with loosing fluid. I figure the bearing is gone in the pump. Has anyone replaced thier power sterring pump? Any suggestions? Any information will be appreciated.
  2. Aug 28, 2009 at 7:27 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    My tacoma had a horrible power steering pump squeal,i tried lucas power steering fluid and it was so thick it made cold mornings impossible to steer it said it would get rid of the squeal but only for a second. i replaced it with a reman pump at about $170.00 then ran the truck filling it with steering fluid and pumping old fluid out of the return lines until the fluid was same color as what i was putting in. i did that the shut the truck off before i ran out of fluid, topped off the fluid and has been quiet ever since. to drain and refill i had to have help.
  3. Aug 31, 2009 at 5:20 AM
    anvilhead
    I replaced my pump last week. It fixed teh problem. I think I might put an inline filter on the return line. What do you think?
  4. Aug 31, 2009 at 12:18 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    I wouldnt bother, just flush the system and your good.
