Robertocritser LT, 4 link, and 37s build
Discussion in '2nd Gen. Builds (2005-2015)' started by Robertocritser, Aug 26, 2014.
  1. Feb 23, 2017 at 5:15 AM
    #761
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I love lamp.
    ChadsPride likes this.
  2. Feb 23, 2017 at 7:11 AM
    #762
    Robertocritser
    Robertocritser [OP] Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    We know...
  3. Feb 23, 2017 at 8:01 AM
    #763
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oh .... well then good talk!
  4. Feb 23, 2017 at 8:52 AM
    #764
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    We need to hang out one weekend...
  5. Feb 23, 2017 at 10:25 AM
    #765
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    We will. March 16-19
    11TRDTX likes this.
  6. Feb 23, 2017 at 11:17 AM
    #766
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    No like Katie and I come down one weekend and watch berry drink the moonshine haha.
  7. Feb 23, 2017 at 12:22 PM
    #767
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah that will work
  8. Feb 23, 2017 at 10:40 PM
    #768
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Sweet build. Love the front bumper design, might have to copy some elements of that.
  9. Feb 23, 2017 at 10:43 PM
    #769
    Mxpatriot
    For what it's worth, I snapped a Currie 4340 CV axle while locked up front on an ARB without damaging the differential or CV ends.
    Not quite sure how that all worked out, but thankful that it did. It was -20F out, that may have made the exposed axle weaker than usual.
  10. Feb 24, 2017 at 4:04 AM
    #770
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    The shaft snapped? What lt kit are you running?
  11. Feb 24, 2017 at 6:31 AM
    #771
    superwhite
    superwhite Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Don't see many shafts snap, mine have always been the outer cv joint
  12. Feb 24, 2017 at 6:55 AM
    #772
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I have always broke the outer cage
    superwhite[QUOTED] likes this.
  13. Feb 24, 2017 at 7:01 AM
    #773
    superwhite
    sean
    Western NC
    07 double cab 4x4
    I had a lot less issues after installing limit straps and welding onto my steering stops to limit the steering angle. It seems to me that the material is too thin, the torque usually busts a piece off the outer cup and drops the ball bearings. No issues with inner joint or shafts themselves so far.
  14. Feb 24, 2017 at 7:05 AM
    #774
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Those are the main reasons. I need to make a steering stop for my lcas before my next big trip.
  15. Feb 24, 2017 at 7:44 AM
    #775
    Mxpatriot
    Yep!
    All pro.
  16. Feb 24, 2017 at 8:46 AM
    #776
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    I know they have had a lot of problems in the past with their shafts. Most of them just bent though
  17. Feb 24, 2017 at 9:18 AM
    #777
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    They bend then they break. They end up bending then the cyclic loading cause a fatigue failure.
  18. Feb 28, 2017 at 4:34 PM
    #778
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Wonder if it has to do with the compound angle of the shaft by them moving the lower forward from stock.
  19. Feb 28, 2017 at 6:37 PM
    #779
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    If the kit wasn't strapped it let the shaft hit the edge of the inner cv housing and would cause it to bend at that point.
  20. Mar 6, 2017 at 2:38 PM
    #780
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
