Robmonster117's Little Monster Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Robmonster117, Jun 20, 2016.
  1. May 17, 2021 at 5:28 PM
    #361
    Robmonster117
    Robmonster117 [OP] Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    she lives. Feels good to have solid responsive steering again. Now back to roof rack designs and new rtt/ bed rack
    63954229-5080-48C5-B6FE-3BDAD92C9604.jpg 92373707-C671-4C48-89DD-7636C2AA7D64.jpg
    Pay no attention to the weld quality:anonymous:
  2. May 18, 2021 at 7:03 AM
    #362
    cynicalrider
    cynicalrider #NFG
    Jersey
    There is something so satisfying about a fresh front end, isn't there?
  3. May 18, 2021 at 10:20 AM
    #363
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Very much so, just adjusting the rack guide roller tightened things up a bunch. I’m much more confident that my alignment will hold now with the TC cam tabs too.
    I was able to talk shop with the new alignment tech at the shop I take my cars to. Hes a toyota guy too so that was rad. I got some pretty good numbers. Caster maxed out around 2.4deg.
  4. Jun 3, 2021 at 2:16 PM
    #364
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Im Supposed to go camping today. :burp:
    I modeled this thing at 10am. And 4 hours later is is all tacked together. Other that the fact that my chop saw is cutting everything at an angle instead of straight, Im very pleased with my caffeine induced creation.
    follows the cab angle pretty well
    Diablo169, cbechtold, rob1208 and 2 others like this.
  5. Jun 3, 2021 at 2:36 PM
    #365
    cynicalrider
    cynicalrider #NFG
    Jersey
    what saw? I’ve never gotten mine to cut absolutely straight on my evo.
  6. Jun 3, 2021 at 3:08 PM
    #366
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Its an older craftman laser trac. It was cutting fine 2months ago when I was chopping tubes :notsure: I got it done. A little eyeball alignment and big welding magnets helped me tack the cross bars together. Now Im just filling gaps
  7. Mar 12, 2022 at 12:05 PM
    #367
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    New ride height?
  8. Mar 13, 2022 at 4:47 PM
    #368
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Yearly update? KOH was insane this year Not many pictures but I'll post what I got. Gave me more of motivation to bring life to this truck and toss some lunch money at it.
    First start projects will be fixing issues/ future-proofing: I'm moving the front Cab mount out of the way for good.
    Ill be sending out some files for cut this week. My truck will be the test dummy for now but I may cut a few extra kits if there is any interest. Made it simple so its 100% laser friendly. This moves it way back out of the way... enough to clear 37s, 40s? whatever your heart desires. There will also be plate inside the cab to further reinforce the cab, and avoid any bending or buckling in the new location
    jubei, betterbuckleup and cbechtold like this.
  9. Mar 13, 2022 at 4:50 PM
    #369
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Already interested. :popcorn:
  10. Mar 13, 2022 at 5:00 PM
    #370
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Horrible pictures but this is the Location of the mount. Forgot how much I like designing thing like this, its great practice. Spot is perfect behind the cab gusset that wasn't chopped off when I did the Tub, and the load support grooves of the cab floor provide great distribution of the load.
    27FD9EC1-7EF9-424C-BABD-33EBCC2599EA.jpg 2F46A36B-9FAF-4BB2-823A-4B62CF396B67.jpg
    jubei and cbechtold like this.
  11. Mar 13, 2022 at 5:03 PM
    #371
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Lol I thought you would be. Ill keep you posted on the prototype results.
    If you know any friends with a laser cutter handy I’d be interested in meeting them:D
  12. Mar 13, 2022 at 5:05 PM
    #372
    cbechtold
    Cory
    Pleasanton, CA
    Well seeing as I might possibly be dumb enough to throw 37s on mine, and the body mount is my biggest obstacle; yeah, definitely interested. I know a guy with a 3Dprinter if that helps.
  13. Mar 14, 2022 at 8:46 AM
    #373
    cynicalrider
    cynicalrider #NFG
    Jersey
    :popcorn: Also potentially interested.
  14. Mar 22, 2022 at 4:28 PM
    #374
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    From model to reality.
    these turned out perfect.
    plus side is super easy to fixture-up off the truck burn them together on the weld table and then align and weld to frame
    I even put tabs on the sides and back plate for perfect vertical alignment
  15. Mar 22, 2022 at 7:01 PM
    #375
    cbechtold
    Cory
    Pleasanton, CA
  16. Mar 22, 2022 at 7:47 PM
    #376
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Lmao if your ready to send it ill get you a set. The real test if if the cab buckets will stand the fatigue load in this location. Im already thinking about another redundant triangular gusset behind the new cab bracket
  17. Mar 22, 2022 at 7:55 PM
    #377
    cbechtold
    Cory
    Pleasanton, CA
    I definitely want to see it in action first. Still super interested, but I've already got enough projects on my hand right now with all new suspension and a full motor rebuild.
  18. Mar 23, 2022 at 6:13 AM
    #378
    cynicalrider
    cynicalrider #NFG
    Jersey
    Does it seem like the sheet metal on the cab is reinforced where it's current mount location is? I am not sure I saw the whole mount was moving back, I assumed it was a lower profile of the current mount. But I guess that makes sense.
    So the way I see it the one corrugated piece will get welded to the cab and hopefully evenly distribute the load there, with a thicker plate also sandwiching the sheet metal. And the frame is one beefy mount protruding off the frame. Only concern I think I have now is if a slider leg might need to be cut/in the way. With a frame mount that wide I can see that being a concern.
    I can almost see a leg here:
    Without the truck I can't measure but I can kinda get an idea of where the leg hits the frame here:
    Robmonster117[OP] likes this.
  19. Mar 23, 2022 at 11:13 AM
    #379
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    The factory location (corner of the cab) had alot more structure build in. I’d have to see an un modified cab without a tub to truly confirm this. But by cutting out the corner of my cab it was significantly weakened. On mine i can see where the floor has actually raised up and the Front of my cab is basically resting on my sliders.
    You raise a good point there, i did not take into consideration where others mounted their slider legs. I chose this spot because it cleared my slider and is is the next most supported position of the cab
  20. Apr 18, 2022 at 5:39 PM
    #380
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Cab mount relocation project spiraled a bit, progress has been slow, and direction has changed again. Welding brackets to the thin floorbards upside-down underneath the cab proved to be insanely difficult especially with sliders in the way, so I lost faith in my skills to do that. . So I am In the process of rebuilding/ reinforcing the existing cab mount and cab corner so I can maintain factory location, and redoing my my tub because some idiot did a real shit job several years ago :anonymous:
    I’ll be adding one more gusset to brace the front of the corner, then chop/ modify the frame side for maximum clearance
    Also (by accident) I discovered my driver side engine mount was no longer connected to the frame :rofl:
    the bolt flange ears completely tore from the frame tower.
    So engine pull will be happening sooner than expected.
    cbechtold likes this.
