Robmonster117's Little Monster Build Thread
Discussion in '1st Gen. Builds (1995-2004)' started by Robmonster117, Jun 20, 2016.
  1. Aug 10, 2022 at 8:32 PM
    #401
    Robmonster117
    Robmonster117 [OP] Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Bump mounts are done up in cardboard. Going to pick up some steel sheet next week for everything in the front plus to make some rear frame box/ reinforcement. Paint marked everything for grinding.
    Also picked up a set of bypasses that should be here this week. Front end is close to success. Motor is a different story…. The rabbit hole deepens
    BYJOSHCOOK, rob1208 and cbechtold like this.
  2. Aug 10, 2022 at 8:35 PM
    #402
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Front suspension is looking bitchen! What's the goal for the motor? Just freshen things up or doing a full rebuild?
  3. Aug 10, 2022 at 8:58 PM
    #403
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Going to start with the heads, there are noticeable seeping leaks. They definitely need a rebuild and clean. We shall see what we find when we open them up though, it may get worse
    rob1208 likes this.
  4. Aug 10, 2022 at 9:28 PM
    #404
    cbechtold
    Cory
    Pleasanton, CA
    Might as well do the head gasket when you're in there and have the block decked. If you need a guy to do the work, Kurt at Main Machine did a wonderful job on my full rebuild.
  5. Aug 10, 2022 at 9:34 PM
    #405
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Oh yea I’d definitely pull them completely off and refresh valves, springs, studs, gaskets etc. I have a feeling I might need new piston rings which will lead me to just strip the entire block and do a 100% rebuild. Ill keep their name in mind and reach out if it comes to that
    jubei and cbechtold[QUOTED] like this.
  6. Aug 11, 2022 at 7:49 AM
    #406
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Remind me why did you pull the engine?
  7. Aug 11, 2022 at 8:27 AM
    #407
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    The initial reason was the driver side engine mount perch on the frame sheared off. There was no easy access(at least with my skills) to cut, grind and weld a new plate onto the perch. @Bonzen recommended that I box the perches in as-well for added strength to go along with the solid mounts.
    The ability to look over the engine outside the truck is an added bonus
    jubei, Bonzen and BYJOSHCOOK[QUOTED] like this.
  8. Nov 1, 2022 at 5:54 PM
    #408
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Going to try to post an update soon. Heres a teaser in the meantime
  9. Nov 1, 2022 at 5:58 PM
    #409
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Oof. Whatta package. All of the suspension goodies
    jubei likes this.
  10. Nov 2, 2022 at 6:07 AM
    #410
    cynicalrider
    cynicalrider #NFG
    Jersey
    :yes:
    Also a key feature that I think would help others with their shock tower failures, even if they didn't want to run bypasses.
  11. Nov 8, 2022 at 9:31 PM
    #411
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Pedal box mod for T100 Booster & 1 1/16” bore Master Cylinder
    Im typing up a wrap-up on the LT build. Thats going to be a few days.
    In the short term I really like how this turned out so Im sharing my results as a quick little write up.
    Problem(s) 1: Mounting studs on MC too short & Booster rear shaft too long. Also I do not want to modify the booster
    Solution:
    1. Keep aluminum block spacer behind MC & cut booster shaft ~.52” off thread. This will keep the clevis in the correct position for brake pedal mating pin
    Problem 2: Mounting studs too short to go through firewall and pedal box/ bracket
    With the aluminum spacer and firewall I was left with about 15mm of thread barely poking through the firewall to use they came to a stop right before sticking through the pedal bracket.
    My solution was to drill open the pedal bracket to fit a 1/2” hex standoff (M8x1.25 internal thread)
    And weld washer to the base of the feet that pinch the Booster to the firewall.
    1st I had to add welds to the bracket feet to strengthen them
    2nd
    Drill open and grind bores with a carbide burr
    3. Weld washers to the feet. Make sure to check hole alignment w/ booster
    Results: It’ll work. Final assembly will have loctite and drill holes and add some safety wire. I dont see these backing out but might as well. better safe than sorry
  12. Nov 8, 2022 at 9:37 PM
    #412
    cbechtold
    Cory
    Pleasanton, CA
    Very interesting that you had fitment problems with the booster. I had zero issues with mine outside of the fact threads that the pedal attaches to being too long. I opted to go without the aluminum spacer that comes on the factory one and remove the extra brake pedal linkage for a smoother throw.
  13. Nov 8, 2022 at 9:52 PM
    #413
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Curious, Any pictures of your pedal mount? you drilled and mounted the clevis directly to the brake pedal is sound like? I'll keep/ try this setup to see how it feels when the rear brakes are done and make adjustments from there. I liked the fact that I could keep "stock" pedal components and positioning
  14. Nov 8, 2022 at 10:21 PM
    #414
    cbechtold
    Cory
    Pleasanton, CA
    I don't have any on hand. I'll get photos for you tomorrow. Clevis doesn't mount directly so you would need to weld the hole back up and drill a new one.
  15. Nov 10, 2022 at 8:57 PM
    #415
    cbechtold
    Cory
    Pleasanton, CA
  16. Nov 11, 2022 at 7:00 AM
    #416
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    cbechtold[QUOTED] likes this.
  17. Nov 11, 2022 at 7:19 AM
    #417
    cbechtold
    Cory
    Pleasanton, CA
    I'd be interested to see that. The slop was the reason I removed all of it in the first place.
  18. Nov 30, 2022 at 2:48 PM
    #418
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Still lagging on the front end “summary of fuckery” but Im keeping busy:
    SUA is underway- Full part out post will go up tomorrow but if anyones interested in any suspension bits or the axle lmk everything must go
    -02 axle with e-locker 5.29s
    -AP Expo Leafs
    -Bilsteins 5100 good bushing & pressure- cheap AF
    -Wheelers brakeline- free
    -any stock brackets
    -any stock brake components - minus e-brake cable3B9CCFD1-DC4C-4556-820B-4F7782AB7D48.jpg
    jubei, cbechtold and rob1208 like this.
  19. Nov 30, 2022 at 7:56 PM
    #419
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
  20. Dec 3, 2022 at 2:48 PM
    #420
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Smart Strip on the frame saves alot of flap discs and wire wheels
    rob1208, cbechtold and jubei like this.
