Rock chips from no mud flaps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigBearSpotted, Apr 2, 2020.
  1. May 29, 2020 at 3:04 PM
    #81
    kingjj
    kingjj Well-Known Member
    2020 Tacoma Off-road
    None yet
    TacoBuffet likes this.
  2. May 29, 2020 at 3:04 PM
    #82
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    Added mudflaps still was getting lots of chips on my steps on country paved yes paved roads. When I installed my sliders they needed to be removed in the front. Took the back ones off too.
    Personally I haven't noticed a ton of new chips. The most chips I have are on the hood of the truck..
    However I am considering the rokblox? Not sure the spelling. But the flexible ones if I ever try again.
  3. May 29, 2020 at 3:06 PM
    #83
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Same experience, chip amount was no different between flaps and no flaps for me on my various trucks, regular street roads, occasional dirt. If I lived on a gravel road, you bet your a**.
  4. May 29, 2020 at 6:53 PM
    #84
    IcxcTacoma325
    IcxcTacoma325 Well-Known Member
    Andrew
    Macon, Georgia
    2017 Tacoma Limited 4x2
    They are a must. I don't off road either but drive alot on the highway. The road debris hitting the underside is pretty terrible without the mudflaps. After I added them I haven't had any problems.
  5. May 29, 2020 at 7:09 PM
    #85
    TacoBuffet
    AL
    Gonna disagree on that must part there.
    kingjj likes this.
  6. Jun 3, 2020 at 9:35 PM
    #86
    kingjj
    None yet
    @TacoBuffet hey bud. Question. I contacted a pretty reputable shop about doing a 2in lift in the front. Told him I wanted a quote on the Bilstein 5100 like you said. Said I didn’t want to do anything lift wise that would hurt the truck etc. and that I do light off-roading.
    he immediately recommended that I do a Spacer in front and Not the Bilstein. I said really? Isn’t that not the best option for the truck. He said it was fine and that the Bilstein option would make the ride super stiff. Not as smooth as it is now. Thoughts?
  7. Jun 5, 2020 at 7:05 AM
    #87
    TacoBuffet
    AL
    "fine" is alot different than the best option, I don't know what he's talking about because from my experience spacers are a stiff and jarring ride unless you go top plate spacer route which is what it sounds like he's recommending, sure that maintains the ride, but then your moving the strut down and putting stress on it as it now becomes the bumpstop so to speak and risk failure. You could do a coil in spacer which does sort of what the 5100's do as far as increasing the preload on the stock spring but at that point you might as well upgrade the shock (5100's) which were designed for that increased preload and better than the stock bilsteins.
  8. Jun 5, 2020 at 7:14 AM
    #88
    kingjj
    None yet
    @TacoBuffet gotcha thanks that makes sense. Time to swing into another shop this week lol.
  9. Jun 5, 2020 at 7:17 AM
    #89
    TacoBuffet
    AL
    Ya sounds like they want to do the easy and cheap method. I would. Good luck! If you're somewhat capable with a wrench its not a bad job DIY, did a few even with sketchy backyard spring compressing.
  10. Jun 11, 2020 at 5:49 AM
    #90
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    This is after installing Rekgen mudflaps. Better-yes. Mud gone-no.
    Fast1, SilverBulletII and TacoBuffet like this.
  11. Jun 11, 2020 at 6:13 AM
    #91
    aahyut
    aahyut Well-Known Member
    Sweden, Maine
    2019 TRD OR DCSB
    YES, and I have the paint loss and nicks to prove it. I took mine off when I went to 285s. I have lost all the paint in certain parts of my sliders due to rocks/dust being thrown on them. I have some new ones coming to replace the thick stockers.
  12. Jun 11, 2020 at 7:21 AM
    #92
    kingjj
    None yet
    Simple. For $400 I put protective paint film on my rocker panels and I’m keeping a pair of sliders/steps on the truck. No flaps.
    Slick Taco likes this.
  13. Jun 11, 2020 at 7:30 AM
    #93
    TacoBuffet
    AL
    Again everyone's experience is different, I've ran flaps, no flaps, chips regardless or not at all. For people to just say you need them is a huge overstatement. Gonna depend on your tire/wheel setup, where you drive / live, etc.
    kingjj[QUOTED] likes this.
  14. Jun 11, 2020 at 7:35 AM
    #94
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    have you considered running boards? Maybe you could have the rocker panels Linexed?
  15. Jun 11, 2020 at 8:32 AM
    #95
    TacoBuffet
    AL
    Ya you'll be good with that setup, maybe some on the rear flare or higher up on the rear panel towards the light, but like I told ya, lived NJ/IL no flaps very few if any chips, AZ had flaps and still had chips on rocker panels, etc.
