Rock Crawlers
Discussion in 'Wheels & Tires' started by nugget68, Mar 24, 2009.
  1. Mar 24, 2009 at 6:23 PM
    nugget68
    nugget68 [OP] Member
    what size spacer is necessary size spacer to fit 15x8 rockcrawlers on a 2001 4x4 tacoma? And would 32x11.5 fit with no lift?
  2. Mar 24, 2009 at 6:26 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    i dont think you'd need a spacer...well...you wouldnt if you bought the 15x8 wheels from Wheelers Offroad...i dunno about Rockcrawlers
    that size SHOULD fit...but you may have some rubbing...especially if your suspension is worn out...might have to do some trimming
  3. Mar 24, 2009 at 6:34 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    If they require spacers, you'll need at least 1/4" spacers and with those, I would recommend 1/4" longer studs. You could also go with the thicker spacers(spidertrax) that bolt on and have studs built in.
    My guess is yes, you will need spacers for those 15" wheels.
  4. Mar 24, 2009 at 8:20 PM
    nugget68
    they hit the caliper...
  5. Mar 24, 2009 at 8:23 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    1/4" spacers at least. I had 15" Cragars that hit the caliper.
  6. Mar 25, 2009 at 5:31 AM
    nugget68
    what size spacers are you running? whats you backspacing? I am actually trying to figure this out for a buddy, he ordered the wheels, they told him they would fit fine but they hit the caliper...
  7. Mar 25, 2009 at 12:14 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    1/4" spacers. The wheels were 15x8 and I think the B.S. was 4". The spacers are only needed for the front. Alot of guys don't like those thin cheap spacers, but after a year, I didn't have any problems.
  8. Mar 25, 2009 at 1:05 PM
    nugget68
    his back spacing is suppose to be 3.75...where your lugs long enough?
  9. Mar 25, 2009 at 7:30 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    If you mean studs, I would recommend longer ones. I didn't get longer ones and didn't experience any problems, though. Make sure he has the conical lugnuts. The shaft style lugnuts from the alloy wheels won't work.
  10. Mar 26, 2009 at 5:30 AM
    nugget68
    he had the 16 inch alloys, so i'd say he needs to replace the studs...any idea where to get them?
  11. Mar 26, 2009 at 12:22 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    You(he) can get lugnuts just about anywhere that sells autoparts. Shop around. As for studs, talk to the parts guy at the dealership. If you replace the studs, you'll want ones that are a little longer than the original to make up for the 1/4" of spacer.
