Rock lights on when approached with key fob, HOW?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hotrod 15, Oct 1, 2022.
  1. Oct 1, 2022 at 7:28 PM
    caribe makaira
    Caribbean, Puerto Rico
    OP, have you read the instructions of the sPOD version you have to move jumper to select a negative input? It's required for tying into the violet (On/OFF @ unlock/lock) or the yellow wire (dimming ON/dimming OFF).
    hotrod 15[OP] likes this.
  2. Oct 1, 2022 at 7:38 PM
    hotrod 15
    hotrod 15 [OP] Well-Known Member
    Robert
    2017 Toyota Tacoma trd pro
    I'm working on it, I'm a novice when it comes to electronics, I've only had the bantomx installed 2 days, I'm trying now to learn what a “Trigger” is and how it works. I will not stop reading until I understand though, I’ve got a long way to go, I don’t even know how I’m going to get all eight wires from the rock lights on one switch, I have virtually no experience in wiring.
  3. Oct 1, 2022 at 7:39 PM
    caribe makaira
    :popcorn:
  4. Oct 1, 2022 at 7:56 PM
    hotrod 15
    Robert
    When I move the jumper to negative input will this have an affect on my already installed ditch lights? And as far as basic wiring goes, What would be your best suggestion to get all eight wires from the rock lights on to one switch, can I join all the positive wires from all eight rock lights into one, and then one wire into the panel? I don’t know what gauge the rock light is going to come with yet but it just seems like I’m not going to have enough room
  5. Oct 1, 2022 at 8:04 PM
    hotrod 15
    Robert
  6. Oct 1, 2022 at 8:09 PM
    caribe makaira
    I think the sPOD will not work for what you want since the jumper affects ALL 8 inputs. If it had a jumper per input you'd be golden.
  7. Oct 1, 2022 at 8:10 PM
    caribe makaira
    If you follow what the video fella did, then every circuit addition would need to be negatively actuated.
  8. Oct 1, 2022 at 8:12 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I believe the DSIM converts it to a positive switched circuit. I could be wrong as I’m also fairly new to wiring.
  9. Oct 1, 2022 at 8:13 PM
    hotrod 15
    Robert
    This is what i thought, back to drawing board
  10. Oct 1, 2022 at 8:17 PM
    caribe makaira
    hotrod 15[QUOTED][OP] likes this.
  11. Oct 1, 2022 at 9:42 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Good for you man! That kind of attitude will get a fellow a long way in life. :thumbsup::thumbsup:
  12. Oct 11, 2022 at 9:47 PM
    hotrod 15
    Robert
    Update. Purple wire at cargo switch as a trigger on sPod works activating rock lights anytime you unlock doors with key fob, also when you open any door, and will also turn on when you turn on the cargo light switch. However doesn't work in proximity, dome light only still. Must...keep....reading, brain is turning into mush
    Baja Designs likes this.
  13. Oct 11, 2022 at 10:08 PM
    caribe makaira
    If we had the TechStream Menu maybe we'd find the missing setting.
  14. Oct 11, 2022 at 10:20 PM
    hotrod 15
    Robert
    I'm going to keep at it, I have some progress now, and like how it's set up, however, I know me, I won't stop until rock lights turn on as I approach the truck
  15. Oct 12, 2022 at 3:28 AM
    #35
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
  16. Oct 12, 2022 at 2:24 PM
    #36
    MGMDesertTaco
    I wonder if the bundle #3 (switch pro bundle) would work with the Auxbeam AR-800 switch panel?
  17. Jan 25, 2023 at 12:20 PM
    #37
    Puga10
    Puga10 Active Member
    oscar
    2019 Toyota Tacoma
    What wires do I have to tap into if in not using the T connector? Looking to get this the universal bundle.
  18. Jan 26, 2023 at 2:24 AM
    #38
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have the Toyota courtesy light kit, took about 4 hours to install. I love the way mine turn on when approaching the truck and how they dim off. Maybe look at the install instruction and see if anything in there might help.
  19. Jan 26, 2023 at 2:47 AM
    #39
    wee
    wee Well-Known Member
    Puga10 likes this.
  20. Jan 26, 2023 at 2:58 AM
    #40
    VaToy
    Parts Unknown
