Rock lights on when approached with key fob, HOW?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hotrod 15, Oct 1, 2022.
  1. Jan 26, 2023 at 3:03 AM
    #41
    wee
    wee Well-Known Member
    I don't think so....I know he pulls the drivers side a-pillar trim and taps into the wiring harness. I don't think he uses a plug-in-play harness.
  2. Jan 26, 2023 at 6:01 AM
    #42
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The Toyota one is not that much plug and play. I had done all the install and was putting everything back while my Toyota mechanic friend was wiring everything up and he was wiring in the same location in the pillar area and also in the footwell. Seems like all I need to do is splice a few wires and add the switch. However I don't like wiring things.
  3. Jan 26, 2023 at 11:16 AM
    #43
    caribe makaira
    Caribbean, Puerto Rico
    Video fella doesn't know that he is still using the small gauge yellow wire to the added higher draw LEDs. Relay in that circuit provides no "protection".
  4. Jan 26, 2023 at 11:28 AM
    #44
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Step's 26 & 27, along with Figure 18 in the attached file are what you're looking for.
    Also, it is important to note what @caribe makaira said in the post just above mine.
    Puga10[QUOTED] likes this.
