Rock Slider Install Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTabe, Apr 12, 2011.
  1. Apr 12, 2011 at 10:12 AM
    TacoTabe
    TacoTabe [OP] Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    Hey guys- I got a set of weld-on sliders from Avid Off Road and I'm having my neighbor weld them on for me. He has considerable welding skills, but he is a 'car' guy, not an offroader. So he asked me to get him some step by step instructions/tips for welding them on. If one of ya'll could give me a quick install guide I would greatly appreciate it! (Yes i did search for a write-up already, couldnt find one :()
    The sliders have to be welded to the support legs still, according to Avid they provide them this way so that I can angle them if I want. My question to you is, how much of an angle is good?
    I appreciate the help fellas!
  2. Apr 12, 2011 at 10:14 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    doesnt matter too much. as long as it clears your door, just make them look appealing to you.
  3. Apr 12, 2011 at 1:30 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The legs should have 1/4" to 1/2" clearance under the body pinch weld, otherwise, as the cab rocks on the rubber mounts and the frame flexes, the sliders will hit the pinch weld making a startlingly loud noise.
    The legs should be gusseted to the frame, and the gussets go on top of the legs.
  4. Apr 12, 2011 at 1:34 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    ^ and also make sure you plate the frame and weld the legs to the plates.
  5. Apr 12, 2011 at 4:13 PM
    TacoTabe
    Kevin
    Northeast PA
    '93 pickup
    Thanks guys. As for the legs and gussets and such, the legs came welded to square plates, and they are gusseted. I will make sure I weld them with the gussets facing up, though. Thanks.
    Anything else I should know?
  6. Apr 12, 2011 at 4:17 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just make sure you like the placement and have the clearance and open all doors to make sure they don't touch the sliders before you burn everything in. Oh and if you don't already know disconnect your - battery terminal before you do any welding on the truck.
  7. Apr 12, 2011 at 4:23 PM
    TacoTabe
    Kevin
    Northeast PA
    '93 pickup
    How'd ya'll do yours to make sure that both sides are the same angle?
  8. Apr 12, 2011 at 4:28 PM
    CopDoctor
    08 335i
  9. Apr 12, 2011 at 4:41 PM
    TacoTabe
    Kevin
    Northeast PA
    '93 pickup
  10. Apr 12, 2011 at 4:46 PM
    JLee
    Jerry
    Bay Area NorCal
