Rock Slider Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TL697, Aug 23, 2009.
  1. Aug 23, 2009 at 7:46 PM
    TL697
    TL697 [OP] Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I really need a set of rock sliders for my '09 DC SB...
    I wheel alot here in the CO mountains...
    I would like a set of bolt-on sliders to be able to remove them for repair and/or refinishing...
    Take me to school on the bolt-on and weld-on sliders...
    Thanks in advance,
    ~Troy
  2. Aug 23, 2009 at 7:48 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Demello has some nice bolt on sliders. They are a vender here on TW.
  3. Aug 23, 2009 at 7:49 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
  4. Aug 23, 2009 at 7:51 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    bolt-on vs weld-on is a never ending argument...
    some say welding is stronger...so say welding to the frame weakens that point...
    if done right i would think the argument is null
    cbi also makes really nice ones...and being in colorado...there should be plenty of local fab shops that can build you what you want
  5. Aug 23, 2009 at 7:52 PM
    TL697
    Jacksonville, FL
    I've checked them out, and they just seem a little expensive for the bolt-on sliders...
  6. Aug 23, 2009 at 7:54 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I also think that once you get them bolted up, you may not want to remove them just to refinish them. I have weld on sliders that im planning to put on when i get time. If they get scratched or what not while on the ruck i am just going to fix it on the truck.
  7. Aug 23, 2009 at 7:55 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Bolt on are always going to be more expensive. They need sleeves, bolts, and what not. Thats another advantage to the weld on
  8. Aug 23, 2009 at 8:03 PM
    TL697
    Jacksonville, FL
    I know...
    I'll probably end up with weld-on's, Obviously I would pre paint them, but touch up would have to be done w/ a brush or roller to avoid overspray... :confused:
  9. Aug 23, 2009 at 8:17 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Or just hold up cardboard behind the spot you are spraying.
  10. Aug 23, 2009 at 8:25 PM
    TL697
    Jacksonville, FL
    That is semi-effective... But unless you mask the truck completely with plastic, overspray finds its way onto other paint surfaces... I'm pretty finicky...
  11. Aug 23, 2009 at 8:48 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    08 tacoma 4x4
    ARB locked front and rear URD MAF Calibrator 3 in. lift Icon coil overs front Icon rear add a leafs airbags AFE stage2 si cold air intake DT Headers 02 sensor URD y-Pipe URD turbo Muffler
    Try trail gear sliders i got mine from ECGS east coast gear supply for bout $250 or $275.00 bolt on unfinished I rhino lexed mine this weekend.:) However, in order to get them to fit you're going to have to shave a bolt and tap or drill the holes into your frame yourself:D lots of work:eek: i was starting to drill the holes and found it easier to take them to the weld shop.$100.00
  12. Aug 23, 2009 at 8:55 PM
    TL697
    Jacksonville, FL
    So you welded on your bolt-on sliders?
    I have access to a full welding shop at work, and I've done a fair amount of cutting/welding... I wonder if I could just get some weld-on sliders and modify them myself to be bolt-on?
  13. Aug 23, 2009 at 8:59 PM
    mpleitez
    valencia
    08 tacoma 4x4
    Looks easy but i dont have skills like that I guess before welding the gussets you would just drill the holes into them?
  14. Aug 23, 2009 at 10:51 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    No it doesn't... I do mine all the time with this in flat black. Just hold up a piece of cardboard about 2'x2'.
  15. Aug 23, 2009 at 11:36 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I would do weld on, But I would also add a 3/16 plate along the side of the frame then weld it to that for added strength to the frame.
  16. Aug 24, 2009 at 4:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    +1- Make sure it's not a high wind day or an real enclosed space...Use a decent size piece of cardboard and you are good to go.
    I've touched up tires, frame, grill. and painted my sliders after install and the only time I masked off was for the sliders. Painting the pinch weld and another coat for the sliders in the near future that I'll mask off for.
  17. Aug 24, 2009 at 5:04 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    I prefer the bolt on option. Should you ever decide to sell your truck you can simply take them off without cutting stuff up. If I decide to weld them on later I still have that option.
  18. Aug 24, 2009 at 5:42 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    Mine are bolted and welded :) They are not going anywhere. To touch up the paint cut open trash bags and tape them down the side of the truck from the top window down to the pinch weld.
