Rock Sliders for ALL Toyotas
Discussion in '4x Innovations' started by traxman25, May 4, 2010.
  1. Nov 6, 2013 at 4:48 PM
    #321
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    Looking good guys, thank you for sharing your pics!
  2. Nov 14, 2013 at 2:37 PM
    #322
    mromeo
    mromeo Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    Which sliders are those?
  3. Nov 14, 2013 at 3:10 PM
    #323
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I believe they are 4x innovations sliders
  4. Nov 15, 2013 at 6:49 AM
    #324
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    I figured that, i wasnt sure if they were the DOM or the HREW set that they sell
  5. Nov 15, 2013 at 8:25 AM
    #325
    Numbnutz
    Numbnutz Well-Known Member
    Oregon
    Slow work in progress
    Yes they are 4xInnoation sliders and are HREW in the weld on version
  6. Nov 15, 2013 at 8:15 PM
    #326
    adrenalinejunkie
    adrenalinejunkie Well-Known Member
    seth
    Washington
    2001 tacoma SR5 TRD 4x4
    What is DOM..?
  7. Nov 16, 2013 at 6:44 AM
    #327
    traxman25
    Adam
    Platteville Wi
    Too Many!
    We offer two different types of tubing for our rock sliders and roll cages, HREW and DOM.
    The HREW stands for Hot Rolled Electric Welded. This tube starts as a strip of flat plate that is heated, rolled, and welded into a tube shape. The shape of the tube is determined by the rollers that roll it and no second operations are performed. It is also typically rolled from a softer steel.
    The DOM stands for Drawn over Mandrel. First off, DOM IS still welded seam tubing, just because you can't see the weld seam doesn't mean it isn't there. The only tube that is seamless is actually called Seamless Tubing. Seamless is VERY expensive and mostly only stainless steel or large tube sizes. Don't let others fool you about that. DOM starts it's life as either HREW or CREW (Cold Rolled), depending on who is rolling it, that has been rolled oversize. That oversize tube is then sent through a die and mandrel that shape the tube into it's final size. This process is done cold which work hardens the steel, making it significantly stronger. The process of resizing and cold working the tube gives a more uniform shape and size and smooths the weld seam. The DOM we use is also made from a higher grade steel that is stronger to start with. Over all the DOM is going to be around 30% stronger than the HREW tube.
    DOM is significantly more dent resistant and is strongly recommended as the material of choice for heavier trucks such as the Tacoma. It is also strongly recommended as the material of choice for any roll cage. The draw back is that it has a higher cost than HREW (that just jumped 18% in the last month).
  8. Nov 16, 2013 at 7:09 AM
    #328
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    do they weigh the same?
  9. Nov 16, 2013 at 7:20 AM
    #329
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Yes, the HREW and DOM weight the same.
  10. Nov 16, 2013 at 9:16 PM
    #330
    adrenalinejunkie
    seth
    Washington
    Hey thanks a bunch for the info! After cold working the dom it is left as is right? Not annealed
  11. Nov 17, 2013 at 7:08 AM
    #331
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Thanks for making me write it down, I've been meaning to for a long time...
    Correct the DOM we use is not annealed, so it keeps the extra strength gained from the cold working.
  12. Nov 17, 2013 at 10:47 AM
    #332
    adrenalinejunkie
    seth
    Washington
    Haha no problem! I understand all of that only because I'm an engineering student. 3 years ago that wouldn't have meant nearly as much to me haha. Funny when you get to use what you've studied in real life situations
  13. Nov 21, 2013 at 3:35 PM
    #333
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    :D
    Just wait till you aren't a student anymore. It doesn't stop. It just gets worse :eek:
  14. Nov 22, 2013 at 6:08 AM
    #334
    traxman25
    Adam
    Platteville Wi
    Too Many!
    The best sliders on the market just got even better! We are now offering our off road industry leading Rock Sliders with a 2inch square wall main tube. Check out the first post or our Rock Sliders section for pricing information.
  15. Nov 23, 2013 at 8:57 PM
    #335
    95 taco
    95 taco Battle Born
    Adam, can you guys do filler plates? or would i have to do them myself if i wanted them?
  16. Nov 24, 2013 at 9:22 AM
    #336
    traxman25
    Adam
    Platteville Wi
    Too Many!
    We do offer expanded steel fill plates that add the additional area for a step yet don't add a lot of weight and are open so water and debris will not get trapped. Adding the expanded steel fillers is $79 for sliders 76" or less in length or $99 for 80" and longer sliders. This option is not on the website so give me a call if you'd like to add that.
    Here's a photo of the Tacoma Bolt On sliders with the expanded steel filler.
  17. Nov 25, 2013 at 7:44 AM
    #337
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    What's the "spring hanger skid" option?
  18. Nov 25, 2013 at 8:17 AM
    #338
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Good question. I've yet to get photos of this little dude, but it is an additional attachment for the back of the bolt on sliders that will protect your front spring hanger. The bracket bolts on using the lower slider mounting bolt and is held in place by an alignment pin. The alignment pin engages the slider mounting plate to keep it from spinning.
    I'll get some pictures this afternoon, but here's a quick shot of the cad model.
  19. Nov 25, 2013 at 8:24 AM
    #339
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Thanks....
    Still waiting on you call, .... :D
  20. Nov 25, 2013 at 8:26 AM
    #340
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Give me a call. I tried to call back, said it could not be completed.
