Rock sliders in snow/salt country
Discussion in 'Product Reviews' started by brow, Feb 22, 2011.
  1. Feb 22, 2011 at 4:05 PM
    brow
    brow [OP] Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    Hello all,
    Wasn't sure where to put this, so I took at stab at it. I am looking into getting some sliders for my truck.
    Does anyone have any info. on how long they last in states where they use ALOT of salt on the roads in the winter?
    I just don't want to buy something that will need to be replaced every two years when they rust through.
  2. Feb 22, 2011 at 4:07 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'll need to care for them. They're steel so they will rust. When you start to see rust appearing, sand them down and repaint them. The initial paint job will make a huge difference. If you take your time, you can make them last a while but eventually you'll need to repaint them, especially if you off road and the paint gets scraped off.
  3. Jul 12, 2011 at 9:41 PM
    xrhode
    xrhode Member
    seattle
    2011 TRD Access Cab Supreme
    wilderness package pimp out, sleeping platform, canopy, rack, debadge, tinted glass
    line x them!
  4. Jul 12, 2011 at 11:08 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Put a rust inhibiting primer down (I use TSC's) then paint ontop of it. make sure you prep them well so the paint doesnt just flake off when you wash them.
    Paint, powercoat, and linex will come off if you use them like they're intended to, and paint is extremely easy to touch up whereas the other two are not.
  5. Jul 12, 2011 at 11:19 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    line-x end of thread. in all seriousness have them shot in line-extra its line-x with a uv protectant it hold up awesome and looks even better!
  6. Jul 12, 2011 at 11:27 PM
    pittim
    Pennsyltucky
    Boujee Prius
    most sliders (that i've seen) are .120" thick, which is almost 1/8", which will take awhile to rust thru.
  7. Jul 12, 2011 at 11:33 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    As mentioned, just give them a little love now and then when you see surface rust start to rear it's ugly head. Scotch brite the area (or use a sanding wheel on a grinder for thicker scale) and hit that area with decent paint. If treated when needed, they'll last as long as your truck. Mine are 1-3/4" .120 and yep, about 1/8" thick. Best bang for the buck. Frame plates and gussets are all 1/4" thick.
