rock sliders need recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eric818, Jan 16, 2024.
  1. Jan 30, 2024 at 8:30 AM
    #61
    BirchyBoy
    BirchyBoy Well-Known Member
    ‘20 Tacoma SR DCSB
    I had LOD sliders on my jeep and they had optional panels for the top and bottom. They looked great but loved to collect little stones and shit and were finicky to clean out.
  2. Jan 30, 2024 at 4:39 PM
    #62
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I am not a big mall fan but I'll take the Starbucks at the mall over the wooden hammer treatment.
    majpooper likes this.
  3. Jan 30, 2024 at 4:54 PM
    #63
    B6P6P6
    B6P6P6 Well-Hung Member
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
    Self Mutilation with an inanimate object seems to be a bit of a problem along with a $10.65 cup of coffee, who even has a mall in 2024?
    CaptainBart45[QUOTED] likes this.
  4. Jan 30, 2024 at 5:01 PM
    #64
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Another vote for RCI.........
    Their welding and powder-coating is a definite 10/10
    Kolter45, RotorRPM and majpooper like this.
  5. Jan 30, 2024 at 6:22 PM
    #65
    r3k
    r3k Well-Known Member
    RCI
    Kolter45 and Out2gtcha like this.
  6. Jan 31, 2024 at 10:11 AM
    #66
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Nice rig - reroute that exhaust - less than $200
    Out2gtcha[QUOTED] likes this.
  7. Jan 31, 2024 at 4:09 PM
    #67
    CaptainBart45
    Bart
    Work in progress...
    The coffee is not really expensive, about $2.50 a cup. It's the liquid candy bars that run up the tab.
  8. Feb 1, 2024 at 8:57 AM
    #68
    PacoTheTaco303
    PacoTheTaco303 Well-Known Member
    Colorado
    2016 White Tacoma TRD Off Road
  9. Feb 1, 2024 at 4:18 PM
    #69
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Definitely something I've noticed too, keeps the side of the track much cleaner for sure but also means it needs to be cleaned out with a hose and not just a drive through car wash too. Sliders also catch rocks and debris getting kicked up, great since it means it's stuff not hitting the door but not so great if you have steel that can rust if the powder coat starts chipping off.
  10. Feb 1, 2024 at 10:31 PM
    #70
    chuychanga
    chuychanga Well-Known Member
    2000 LX470, 2006 Tacoma Prerunner, 2023 Tacoma Off-Road
    Exactly. And there’s a Short cup, not listed on the menu, that’s 8oz for $1.75 - $2.00. 8oz used to be considered a perfectly adequate serving of coffee. Starbucks tastes burnt to me. I suspect it’s because they buy crappy beans in bulk and have to over roast them to make them all taste the same, but just my theory. But I’m in airports a lot and it’s often the only choice.
  11. Feb 2, 2024 at 10:59 AM
    #71
    Out2gtcha
    Brian
    Omaha, NE
    Thanks!
    - No need. After experience off road with the Taco, especially with our off-road trailer, I've already solved the only issue I had (bashing the stupid fat TRD tip on the quarter-panel) and done all the "rerouting" it needs........
  12. Mar 27, 2024 at 10:54 PM
    #72
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
  13. Oct 10, 2024 at 5:38 AM
    #73
    edward1171
    edward1171 New Member
    edward
    20 trd offroad
    n/a
    I'm not sure we all are shopping based on need... Personally, I'd like the on road protection just in case. That's not a need, per se, but if I'm spending the money anyways...
  14. Oct 10, 2024 at 9:45 AM
    #74
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    gottue likes this.
  15. Oct 29, 2024 at 6:20 PM
    #75
    gottue
    gottue Active Member
    Bay Area
    MonkeyChief[QUOTED] likes this.
  16. Oct 29, 2024 at 6:41 PM
    #76
    MonkeyChief
    ACORLR
    Thanks! 10 degrees. I like the taper versus the kick out, feels clean to me.
  17. Oct 29, 2024 at 7:33 PM
    #77
    gottue
    Bay Area
    Sweet! I'm trying to decide whether to do the 10 or 0 degree with fill plates. Was there a reason why you opted for 10 instead of higher angled or flat? I'm primarily using it as a step for family and doggo to get in and out of the cab safely. But would sacrifice some functionality for cleaner lines
  18. Oct 29, 2024 at 11:26 PM
    #78
    MonkeyChief
    ACORLR
    I know did a bit of research and came to the conclusion I wanted some protection against doors in parking lots. I think the 10 sticks out a hair more than 20, and seems to be a better step while staying tucked a bit. Felt like it hit all the marks for me, I didn’t see 0 degrees offered if I remember correctly, but it’s been awhile.
  19. Oct 30, 2024 at 11:06 AM
    #79
    gottue
    Bay Area
    I'm going with BAMF rock sliders as they're local for pickup. Jeff recommended 10 too. Do you mind sharing a pic of your foot on the rock sliders at eye level? I just want to get a closer look before purchasing.
  20. Oct 31, 2024 at 8:05 AM
    #80
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    Here are my 0 degree BAMF for reference. To your point, the piece of mind knowing no one can ding your doors is well worth the price. This is was an easy decision for me for first mod on mine.
    timw1, MonkeyChief and gottue like this.
