Rock sliders/ steps in the winter- dual fill plate idea.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bobcdn, Feb 25, 2019.
  1. Feb 25, 2019 at 8:32 AM
    Bobcdn
    Bobcdn [OP] Well-Known Member
    WTB; 2nd gen well built Tacoma
    I am planning to put sliders on the truck at some point- more to use as steps and ward off door dings.
    I seen a post on here where the guy had to pick all the frozen road slush and ice out of his sliders. Does everyone (in cold nasty weather locations) with sliders have to deal with this issue?
    I was planning on fill plates with the swagged holes and started to wonder if putting the same fill plate on the bottom of the slider and then weld a tube to connect the top swagged hole to the bottom swagged hole. Fully weld them out so that they are sealed. Lots of extra welding and a bit more weight but I think these would be better for winter than what is available now.
  2. Feb 25, 2019 at 9:19 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I have expanded diamond shape heavy metal sheet as filler on mine and haven't run into any problems. Old truck had running boards and they were fine too. Snow will build up along the front of the mud flap but not too bad on the sliders. I'm about 20 miles from the coast so the snow tends to be a bit sticky vs the dryer stuff further inland.
  3. Feb 25, 2019 at 9:48 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Snow/ice packs up under mine a bit but it's never been an issue. It usually melts off on its own within a week (just not cold enough consistently here to have it build up more).
    I don't see how a 2nd fill plate would prevent that though.
  4. Feb 25, 2019 at 9:52 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    I get plenty of snow and ice and mud buildup on mine, but its not really ever been an issue. Usually melts off pretty quick. Worst case, I swing by one of those DIY carwash bay places and hit it with the powerwasher real quick. Mobtown sliders with fill plates for reference.
  5. Feb 27, 2019 at 2:36 PM
    Bobcdn
    Sounds like it is a none issue.
    Thanks.
