Rock Sliders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BrownBear80, Mar 16, 2020.
  1. Mar 17, 2020 at 6:20 PM
    #61
    tcjacado
    tcjacado Well-Known Member
    @Shmellmopwho
    OnHartung'sRoad likes this.
  2. Mar 17, 2020 at 7:08 PM
    #62
    SmileyGuy
    SmileyGuy Well-Known Member
    Darrin
    Nova Scotia
    20 Tacoma Off Road Voodoo Blue DC SB TRD Premium CAN
    I purchased the RCI after searching multiple sites. Some manufacturers use different materials and you pick the options. I liked the combination of square and round tube. I preferred the full inside support parallel to the outside. One other consideration was the size and location of the triangle gussets that give the slider extra strength. I also opted for a top plate as I plan on using these to stand on when reaching above the cab. With that option you still get the short cross tubes welded the same as without top plates. Most pictures you can't see the cross tubes because of the to plate. These also have angled ends which may avoid catching undesired objects.
    Lots of styles to choose from and options to select. I choose standard 20 degrees bolt on so they can be removed easily if I want to refinish them.
    20200314_165315.jpg 20200314_165330.jpg SmileyGuy RCI 20 Degree.jpg SmileyGuy RCI 20 Degree Slider.jpg
    Wise Wolf and GillyLink like this.
  3. Mar 18, 2020 at 6:42 AM
    #63
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    On my personal Tacoma, I have switched them about 4 times :rofl: When its summer dimple down and in the winter/ spring dimple up.
    JK likes this.
  4. Mar 20, 2020 at 8:51 AM
    #64
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thank you very much!:thumbsup:
