Rock solid toys/ FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Feb 10, 2018.
  1. Feb 10, 2018 at 11:22 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Anyone know what's up with RST? I've tried to contact them through their website and Facebook. No response. I'm trying to see if I can find part numbers and a proper write up for an FJ case swap into an auto 09 TRD sport. Apparently their forum had a good write-up and all the information necessary but everytime I try to access the forum I get a forum is under construction notice and a blank page. I tried searching the forums on Tacoma world but no luck. If anybody has a working link or knows of anywhere where there is a good write-up it would be greatly appreciated.
  2. Feb 10, 2018 at 1:32 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Bumpity
  3. Feb 10, 2018 at 1:47 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    They are probably at KOH right now. Might not be a good time to contact them, maybe wait a few days?
  4. Feb 10, 2018 at 2:16 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. Don't know what is, but I'm guessing it's an event. I'll try again in a couple of days. thanks for the info.
  5. Feb 10, 2018 at 2:18 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    King of the Hammers!
  6. Feb 10, 2018 at 2:19 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I just went yesterday. Pretty sweet
  7. Feb 10, 2018 at 3:16 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    There a write up on here too but since you're auto and not manual it's gonna be real easy. To get you started get the Tcase from an automatic FJ and straight swap it for yours. Cut your floorboards for the shifter. Sort the electrical last, KOH will be over by then. You'll need a switch to activate ADD and then you can remove your 4wd ECU and sell it (unless you have the elocker and no 2hi mod for it yet that is)
  8. Feb 10, 2018 at 3:29 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    What do those 4WD ECUs sell for? I still have mine, and the selector switch, in a box somewhere.
  9. Feb 10, 2018 at 4:34 PM
    TireFire
    Olympic Peninsula
    Idk, check car parts dot com?
  10. Feb 10, 2018 at 6:45 PM
    Pigpen
    Dan
    Northwest Montana
    If I was doing this, I'd delete the ADD too
    hoverlover and TireFire[QUOTED] like this.
  11. Feb 10, 2018 at 6:55 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Any specific years I should be looking at? I have a sport so no elocker. Is it worth it to do dual stick while I'm at it?
  12. Feb 10, 2018 at 7:33 PM
    TireFire
    Olympic Peninsula
    Any year FJ Cruiser works, dual stick depends on your needs but then it's a lot more work
  13. Feb 10, 2018 at 7:37 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks for all the info. This is hopefully my next big purchase.
  14. Feb 10, 2018 at 7:38 PM
    Pigpen
    Dan
    Northwest Montana
    some years the 4runners used the same t case
  15. Feb 10, 2018 at 7:41 PM
    TireFire
    Olympic Peninsula
    If your 4wd shit the bed it's still the easiest to buy another actuator. I personally prefer the modern wheel over a manual shifter but I'm in SoCal and not into hardcore off-roading
  16. Feb 10, 2018 at 8:09 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm just planning ahead. One of the guys I wheel with had the vacuum line on the actuator freeze and crack causing it to die. $600 CAD for just the actuator lead me to a search for a more robust solution. I figure for about $800 USD I can have a bulletproof solution. I seldom go for easy.
    tacoma16 and hoverlover like this.
  17. Feb 10, 2018 at 8:11 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    This had me confused. Alot of the eBay listings had the 4runner as a compatible vehicle.
  18. Feb 10, 2018 at 8:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    The only real issue with this swap is the T case shifter. It comes through the floor in the same location as the Taco trans shifter. It would be nice if someone would sell a T case shifter that is made to fit this swap. If someone prototyped it and bult a jig, mass producing them would be easy.
  19. Feb 10, 2018 at 8:50 PM
    aaol1
    aaol1 Well-Known Member
    sam
    victoria BC
    10' TRD sport DCLB
    Rear diff breather Plasti dip emblems and rims Garmin glo GPS receiver + ram mount with tablet Toytec BOSS lift with rear AAL Custom steel bolt-on sliders with kickout Custom aluminum bed rack Wild Coast Tents Sundog RTT mounted to rack 2 x Treds PRO Lime green mounted to rack Shovel + Hi-lift mounted to rack Cheap bush bar 2 x CREE LED light pods with hood mounts 265/75R16 Hercules Terra Trac ATII
    possible to get the stick to fit through where the slit is, next to trans shifter? ( slit that fits your phone or whatever else goes there)
  20. Feb 10, 2018 at 8:54 PM
    Muddinfun
    Yes, but from the pics I have seen, it takes a lot of cutting and tack welding of the shifter inside the cab to get it to fit right.
