Rockauto part issues
Discussion in 'Technical Chat' started by Tnt tacoma, Mar 11, 2018.
  1. Mar 11, 2018 at 6:49 AM
    Tnt tacoma
    Tnt tacoma [OP] Member
    Does any one have luck with rockauto parts or any problems with quality
  2. Mar 11, 2018 at 7:14 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Never had any issues, bought from them several times. They don't have all the OEM parts for every vehicle but they are good. Depends what you are looking for but if you need a OEM part you might want to try @gunny1005 @Camelback he has helped me out a couple times and at a very good price and we get a discount here on Tacomaworld.
    NoOne likes this.
  3. Mar 11, 2018 at 9:19 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I've bought many, many parts from Rockauto over the years. Never had a problem. Recently, I've ordered less from them as their shipping has gone up - or at least it seems that way.
  4. Mar 12, 2018 at 1:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You do get what you pay for!
    Good Parts for a decent price but cheap China made junk as well.
    Watch the Shipping one order coming from 3 places gets real expensive fast
  5. Mar 12, 2018 at 2:12 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    You select the brand. There’s no blanket statement for the quality of parts.
    vern650 likes this.
  6. Mar 12, 2018 at 2:58 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    I have used them several times with no issues. As stated above, you choose the brand. Google the brand and part number you are considering and read reviews before buying.
    NoOne likes this.
  7. Mar 12, 2018 at 8:37 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Many of their parts are available in different levels of cost/quality. I usually avoid the cheapest option, and get the best option.
    vern650 likes this.
  8. Mar 14, 2018 at 2:20 PM
    BamaToy1997
    Bill
    Navarre, FL
    I order from them a lot. Usually don't have problems, but every once in a while there are issues. about 3 weeks ago I ordered 70 seals. I ended up getting a big box with an AC refrigerant line instead. Took them about 5 days to fix the situation, but they did take care of it.
  9. Mar 14, 2018 at 3:06 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Order form them all the time. Good selection. No problems...
    NoOne likes this.
  10. Mar 17, 2018 at 8:41 PM
    redzmvt
    redzmvt Well-Known Member
    Scott
    Western Wisc.
    2011 Regular Cab 4x4 Auto stock
    Bone stock for now
    I have ordered a lot of oddball parts that can't be had at the local yokels,mainly for older vehicles.Their shipping can add up,as stuff comes from different locations.
    It seems like the front ADD actuator is constantly sold out,must be a high failure part?
  11. Mar 18, 2018 at 5:27 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I’ve ordered quite a bit, radiator came with a hole in box and damaged core, they sent replacement after requested pictures, did not request original back. no issues,
    same order I had ordered DENSO plugs, received NGK with same item number, entirely wrong plug. Once we figured out what happened, they sent correct plugs and I got to keep the wrong ones ( anyone need 6 spark plugs for a 2stroke motorcycle ? )
    No issues ordering from them, just minor inconvenience
    I did use the DJ Rock head gasket set for the 3.4L been doing fine for the last 4 years. Half the price of the big name gasket sets. I used to be a Fel-Pro follower, got let down to many times
  12. Mar 24, 2018 at 12:37 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    No issues with Rock Auto,I just ordered a Dorman wheel hub assay for the passenger side, I replaced the driver side a couple of weeks ago.Their price was 30 bucks cheaper than the one I bought from Advance Auto. Arrived in time, no issues
  13. Jun 7, 2018 at 9:36 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I have used them and they seem pretty good. I got a pair of rear shocks for my truck and one of the shocks was defective. I filled out the return form but forgot to pack it with the defective shock when I sent it back. I emailed the form to them and they sent out the replacement no questions asked. I think they are pretty good.
  14. Jun 8, 2018 at 7:11 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    I have ordered lots of hard to find parts from them, I have the item within 4 days.
  15. Jun 11, 2018 at 1:08 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I just ordered lower control arms and one was packaged wrong. They will take it back and ship a new one or let me refund it. I was in the middle of the job so I tried to get one from Advance Auto and they had the same issue, wrong part inside corecr part number box. So it was a Moog problem and not rock auto. And yea the shipping can add up, but I usually find a coupon code that offsets the shipping anyways.
  16. Jun 19, 2018 at 7:39 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    What he said.
