Rocker panel bolt hole patch
Discussion in 'Detailing' started by Amo-cat3, May 17, 2011.
  1. May 17, 2011 at 8:55 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.7" URD Pulley, APR X1, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Alcan aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, m/t atz 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    I am going to remove my Carr hoop truck step from my double cab and get some sliders. The truck step is bolted in to the bottom rocker panel and floorboard of truck. How should i patch up the bolt holes? I really don't want to patch the holes with bondo.
    I could just take off the step and put the bolts back in the hole with some silicone sealant. The bolts should not be very noticeable. any other suggestions to patch these holes?
    Thnx Tacoma World.
  2. May 17, 2011 at 9:20 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Put antiseize on the bolt and run it back in. Sealant will eventually fail and allow crap to get in. Antiseize will allow you to remove the bolt and use the hole for something later. Or, fill in with epoxy stick, prime, and paint.
  3. May 17, 2011 at 12:59 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Thank you sir for the quick response and for the anti-seize tip. The epoxy stick is a great idea to, but i'll pass on prime and paint. I can live with the small bolts.
    Have a good one!
  4. May 18, 2011 at 5:05 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    I'd recommend putting some paint on those bolts... The raw steel in the rocker is now exposed, and it's a rust-trap waiting to happen. If you throw some paint on there (even just touch-up) it will seal the bolts, and the bare metal, not allowing moisture in, and keeping rust away.
