Rocker panel repair/slider install dilemma - want advice/opinions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Aug 29, 2012.
  1. Aug 29, 2012 at 8:30 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    So my passenger side rocker panel has a huge dent in it. The paint got destroyed, my touch up job is already cracking off and tiny bits of surface rust are forming.
    I want to take care of the paint/rust first and foremost. The dent is something I would like to do but am not willing to shell out the money to fix it. Not worth it.
    So my intention was to RaptureLine the rocker panel and body line as a protective means (since that part of the body is already kind of chewed up from rock chips, etc)
    But I don't know how soon I can get to RaptureLining my truck and want to install the sliders I have.
    My question is, would it be a serious PITA to RaptureLine the rocker panel et al with the sliders installed?
    If anyone has any other advice I'm all ears
  2. Aug 29, 2012 at 8:33 AM
    Manwithoutaplan
    ID
    you have pictures???
  3. Aug 29, 2012 at 9:10 AM
    Madjik_Man
    Pictures of my damaged rocker panel?
  4. Aug 29, 2012 at 9:43 AM
    Streetsurfz727
    Streetsurfz727 Well-Known Member
    body work is easy man especially with some thing like this that dosnt have the be prefect since your just going to line-x over it. I would try and beat the the top where it meets the door as best possible with a ball-pin hammer and then come back with some bondo sand it down and be done with it. But then again this is the red neck in me talking.
  5. Aug 29, 2012 at 10:01 AM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    yeah thats a tough one, I sure wouldnt do whats mentioned above because 1. body work isnt easy if you do it the right way and 2. you have a big crease and all you would be doing it hammering that down and not taking any of the dent out. It would be a PITA if your doing weld on sliders ( I am assuming you are ) so yeah kind of a tough call.
  6. Aug 29, 2012 at 10:01 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I'd drill some holes in the dent (less the better)...
    and use a dent puller to pull out the dent and get that closer.
    Then fill the holes and surface area with bondo.
    Finally... sand the area to a reasonably smooth finish.
    ...all before laying the liner coating
  7. Aug 29, 2012 at 10:07 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    probably the best fix using a slide hammer, my rockers are totally fucked
  8. Aug 29, 2012 at 10:08 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I'd definitely wait to install the install the sliders until you've done the body work and painted the rockers. It will be much easier that way.
  9. Aug 29, 2012 at 10:14 AM
    Madjik_Man
    I already took a 2x4 and hammer to it so the door would shut and align properly. Then used touch up paint and clear coat nail polish to finish it off.
    I don't care about the dent, but I want to Raptor Line (got the correct spelling now) the rocker panels for protection.
    Just trying to figure out if I should/can do it before the sliders get installed.
  10. Aug 29, 2012 at 10:24 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Try not to use the Bondo on any low spots more than 1/4"!!! And like TacoDell says fill the holes you make pulling the dent, if theres any holes behind the Bondo it will fail.
  11. Aug 29, 2012 at 10:34 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Subbed. Maybe ask some 1st gens with the same sliders you have? Ask them to look at their truck and see how big a pita it'd be?
    I plan on having my sliders on in a few weeks. And can't afford line-x'ing my rockers til the fall.
  12. Aug 29, 2012 at 10:42 AM
    Streetsurfz727
    Ok so you dot care about the dent, and want the rockers sprayed with bed liner professionally correct? but you dont have the funds yet and want to go ahead and install your sliders. So your wondering how much of a pain it would be to line the rockers after you install the sliders? Ide say you be patient and save your money to have it done the way you want it rather than cause your self a possible headache.
  13. Aug 29, 2012 at 10:47 AM
    Madjik_Man
    Fack bondo and fixing the hole :)
    I'm just gonna prep and spray Raptor Liner over it
  14. Aug 29, 2012 at 10:48 AM
    Madjik_Man
    Yeah, I'm going to Raptor Liner it myself. Then get my sliders installed.
    I just got off the phone with the Raptor Liner rep and feel really good about this product.
  15. Aug 29, 2012 at 10:49 AM
    Madjik_Man
    Don't do Line-X (I have it in my bed FYI)
    It isn't urethane based, so it will fade no matter what. It doesn't flex as much as Raptor Liner. And Line-X is a serious PITA to touch up where as Raptor Liner isn't.
  16. Aug 29, 2012 at 11:09 AM
    Madjik_Man
    meant for another thread
  17. Aug 29, 2012 at 12:09 PM
    Streetsurfz727
    yeah then once you have your sliders on and the dent is still there you can tell everyone your so extreme even sliders cant protect you from the shit your crawling on.
  18. Aug 29, 2012 at 12:21 PM
    Madjik_Man
    As I flex my stock Tacoma on a curb at the mall
  19. Aug 29, 2012 at 1:02 PM
    License2Ill
    Ian
    I have Line-X in my bed too. I like it. Been on 3 years hasn't faded too much.
  20. Aug 29, 2012 at 1:24 PM
    Madjik_Man
    I have my bed Line-X'd for 11 years now, with a topper on 99.9% of the time, and it has faded to a light gray.
