Rocker Switch wiring question
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Jan 17, 2017.
  1. Jan 17, 2017 at 11:35 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Below is how I currently have the Hella 500 lights wired up. Using a Toyota fog light switch (Part #00550-35976) to power on/off. I plan on adding another Toyota fog light switch next to it to power on/off some interior led lights.
    For the second switch, can I run a wire for each connection over from the first switch?
    Thanks for your help.
  2. Jan 17, 2017 at 11:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    You don't want the red wire connected on the right switch. That wire should go to your interior lights.
  3. Jan 17, 2017 at 11:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    Like this...
  4. Jan 17, 2017 at 11:44 AM
    jammer
    Ben
    Bentonville, AR
    Good catch. That will be going to the Interior LED Lights. I'll edit the pic.
    d
  5. Jan 17, 2017 at 12:41 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    The fuses are on the ground side? Shouldn't it be fuse>relay>switch>ground? I suppose it ultimately doesnt matter, just goes against typical practice, to have the breaker after the load.
  6. Jan 17, 2017 at 12:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    Wire color means nothing
  7. Jan 17, 2017 at 12:44 PM
    Caligula
    Los Angeles, CA
    Ehh ok.
  8. Jan 17, 2017 at 1:31 PM
    Wulf
    rock raisin
    Though the diagram has a poor color choice it is fused on the positive and fine as it is.
  9. Jan 17, 2017 at 1:39 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yea fuse the Pos off the battery and you should be fine.
  10. Jan 17, 2017 at 2:10 PM
    jammer
    Ben
    Bentonville, AR
    Appreciate the help guys
    98tacoma27 likes this.
